THE SONY SERVICE CODES - Articles, Comments, Discoveries - Page 85 - AVS Forum | Home Theater Discussions And Reviews
 2Likes
post #2521 of 2973 Old 06-11-2007, 02:35 PM
duwdu's Avatar
Originally Posted by Nitewatchman View Post
Oh no ... You wouldn't see a test pattern at all if something like THAT were happening ...
Have never seen that happen either(the pattern covering up the SM menus), and don't know how you would know you were in SM if you couldn't see the menus ... Turning All the guns off (2170P1/RGBS=0) is the only thing I have come across which "turns off" the SM menus (and everything else! )
What happens if you are on an input Other than HDMI when you try to enter SM ? If you haven't tried it, maybe try that -- such as the RF input (ANT button), or an S-video/Composite video input (video 1~3) ... Then, maybe you could switch to HDMI input within SM+hopefully then still be able to see the menus in order to write QM/PATN To "0" ...
You are da bomb Nite! I selected another input - just pressed the TV/Video button once after turning on the TV normally, as I had previously disabled all but the HDMI and one other input, switched off, then re-entered the SM - and Viola! my SM UI is back.
You've saved me a lot of aggravation Nitewatchman (and G-Bull). Many many thanks to you and the community.
duwdu
My audio listening nirvana is best served rich ... with bass very well done.
duwdu is offline
post #2522 of 2973 Old 06-12-2007, 10:23 AM
Shifty_Effect's Avatar
I was tweaking my picture using the service menu and decided to change back all of it to default values. Then i "WRITE" the UCP value back to 33 and doing so changed my screen to what looks similar to a checkers board from eye view, full size of the screen and has a black background. I can't do anything else with my remote other than going into the service menu and changing values of codes (which im definetly never touching again). What did i do? How do i get out of this! All i wanted to do was fix some geometry issues!
BTW i was using my DVE disc at the time and i noticed in the service menu its changed from 480i to 1080i.
Shifty_Effect is offline
post #2523 of 2973 Old 06-12-2007, 07:27 PM
bassface's Avatar
It has taken me a few weeks, but I have finally read all 85 pages and discovered many helpful hints to fine tune my XBR970. I've been able to adjust the overscan down to about 4%, fixed a horrendous tilt problem, and the picture geometry is now pretty darn good...THANK YOU to everyone here who contributed expert advice.
However one thing I have not been able to fix is a vertical position difference between my DVD player (input #4, component cables, 480p) and my satellite receiver (input #5,component cables, 1080i).
If I center the image (up and down) from the DVD player the broadcast TV image does not go quite to the top of the screen. Is there a way to adjust the vertical position of these inputs independently?
bassface is offline
post #2524 of 2973 Old 06-12-2007, 07:56 PM
jpl3447's Avatar
Can you disconnect the DVD player and insert the satellite there, to see if the shift still occurs? Or the other way around? That way you can rule out a signal discrepancy.
jpl3447 is offline
post #2525 of 2973 Old 06-13-2007, 09:17 AM
G-Bull's Avatar
I think DHVP within MID2 will do what you're trying to do, but you'll have to try it out to be sure. It has been a while since I messed around in the SM... I don't recall whether input4 and input5 can be adjusted independently, or if it adjusts both of these "component video" inputs at the same time. I do believe, however, that it treats each resolution independently, so the setting for 480p can be adjusted separately from 1080i...
G-Bull is offline
post #2526 of 2973 Old 06-14-2007, 04:56 PM
bassface's Avatar
Well I tried adjusting the vertical position with DHVP (in MID 2), but that moves the image up or down within the raster. It's the raster which does not reach the top of the CRT. The same thing happens when I try to fix this using SCRL or ASPT.
The only way I have found to make the raster meet the top of the picture tube is to adjust Vertical Correction in the User Menu to +4 or +5 when watching the satellite dish, then resetting Vertical Correction to 0 when watching DVD's.
bassface is offline
post #2527 of 2973 Old 06-17-2007, 12:26 PM
Jetra Vard's Avatar
This is my first post in this forum. I've been able to get a great picture from all the tips in this thread on my 34hs420 but I feel I've just dodged a bullet.
I had my set turned on and left the room for about 40 minutes. A thunderstorm caused the power to go off for about 5 seconds. When I returned to my set I noticed that colors were distorted. Normally green text was blue and there was a halo of green and pink tints surrounded the outer edges of the screen.
Searching the net I attributed this to overheating & warping of the aperture grill. Hopefully not too late I realized I should turn the set off to let the grill cool down. Luckily when I turned it back on a few minutes later the colors were back to normal.
What can I do to prevent permanent damage to the grill? Did the power suddenly turning off and then coming back on abruptly cause the set to send to much current from the electron beam and overheat the grill? Or is there a service menu contrast/white level adjustment that is possibly set too high? Thanks.
Jetra Vard is offline
post #2528 of 2973 Old 06-17-2007, 07:09 PM
raouliii's Avatar
Originally Posted by Jetra Vard View Post
...I had my set turned on and left the room for about 40 minutes. A thunderstorm caused the power to go off for about 5 seconds. When I returned to my set I noticed that colors were distorted. Normally green text was blue and there was a halo of green and pink tints surrounded the outer edges of the screen.....
Is it possible that the power bump was multiple, quick power fluctuations? If so, then its very possible that what you initially saw was an interupted cycling of the degaussing circuit. Incomplete degaussing of crts can create the symptoms you describe. The degaussing circuit operation is the surging sound heard at initial powerup.
BTW, The degaussing circuit heats up when it cycles on, therefore it has a cool down period of 5 to 10 minutes before it will cycle again.
Those who would give up essential liberty to purchase a little temporary safety, deserve neither liberty nor safety. - Benjamin Franklin
raouliii is offline
post #2529 of 2973 Old 06-17-2007, 11:10 PM
Jetra Vard's Avatar
Thanks Raouliii. I see you've helped others with their magnetic problems.
I don't think there was a rapid power cycling. The lights went off once for a very short time and then came back on. This never happened to me during a storm before but maybe a nearby lightning strike created an emp and magnetized the screen. I'm guessing the set was still "on" even though the power was out so it didn't degauss when the power came back on a few seconds later....if degaussing only occurs when you manually power up that is. I'm just guessing because I know very little about the technical side of this.
post #2530 of 2973 Old 06-18-2007, 04:29 PM
Dr. Spankenstein's Avatar
Quoted: 80 Post(s)
Liked: 55
Originally Posted by duwdu View Post
Thanks Nite, am not just turning on the TV normally, am entering the SM from the standby state as G-Bull has enumerated, and have been successful before this problem started. Thanks anyways. I'll probably have to try another remote, may be indeed some of the buttons have suddenly gone bunkers, it's just that this set is so brand new...
duwdu
Another thing to be aware of is the "Device" the remote is trying to send the commands to (ie. DVD, ANT, CABLE or TV). You will know by looking at the remote when you press the button, a red light will flash rapidly above the device it is sending commands for. (Sorry for two sentences in a row ending with prepositions! )
This can be a simple, yet confouding detail to note while mucking about in the SM.
Cheers,
Bryan
Dr. Spankenstein is online now
post #2531 of 2973 Old 06-18-2007, 04:40 PM
Quoted: 80 Post(s)
Liked: 55
Sounds like the classic case of an internal pattern being saved before exit.
Indulge me and enter the SM and page back (5 button) until you reach the group labled "QM" the page forward within the group (1 button) until you reach the PATN group then lower the value (6 button) until it reads zero.
Hopefully, your picture should have returned. If it has, SAVE (MUTE then ENTER)!
Let us know if this helps.....
Bryan
post #2532 of 2973 Old 06-21-2007, 01:18 PM
apoll134's Avatar
Originally Posted by John K. View Post
My Sony KDF-60XS955 took a crap today. all i can say is that the red stanby led flahes 6 times, and repeats itself. any help out there on what this may mean
John my tv did same thing. tech came in replaced the fuse in back. its a heat fuse gets too hot it burns out. It is on a wire that is about 2 ft long 1 white whire 1 gray wire. has red tape taping them together last 8 to 10 inches is black with a small black piece of plastic on the end . that is the fuse. on the wire(black part of wire) it says e30522 hi-tube-n 105c 300v vw-1 -f- hrakawa-l. its aplug in wire did not see where it plugs in. at same time they blew dust out of tv that can cause it to overheat. was also told the lamp when it burns out will do same thing. the lamp is an easy replacement. (SONY will replace within first yr) on the front of the tv, at the botttom where it says HDTV that piece of plastic pops off. lamp is behind that allen screw on left side has to be removed. new bulb comes with an allen wrench. new bulbs online for about $160
the fuse doesnt seem that hard to replace take back lower plastic of tv off look for 1 gray wire and white wire that has 3 pieces of red tape on it and the last 8 to 10 inces is black with the little black square plastic piece on the end (small) about 1/4 inch square.
hope this helps
apoll134 is offline
post #2533 of 2973 Old 06-26-2007, 12:25 PM
Psythik's Avatar
This question may have been answered before, but it would take me forever to dig through 85 pages of text to find it...
Anyhow, when watching a 4:3 program in normal aspect mode, the vertical gray bars on each side of the picture cut off a little more than I would have like them to (the picture looks more like a 5:4 image rather than 4:3). Is there a parameter in the SM that allows me to either adjust the size of the grey bars, or remove them completely?
Psythik is offline
post #2534 of 2973 Old 07-11-2007, 07:45 AM
tpfaz's Avatar
Is there a list of the service menu items that can be adjusted for the KDL46XBR2? I can see the menu items, but I can't decifer what they mean.
I'd like to adjust the vertical and horizontal size of the display a couple of pixels, in order to remove some junk at the top of the display when in "full pixel" mode. I like full pixel mode better than normal mode, because it shows quite a bit more of the actual frame on all sides.
tpfaz is offline
post #2535 of 2973 Old 07-11-2007, 09:57 AM
au revoir's Avatar
That model does not sound like a CRT. Since this is the CRT forum, you might have better luck posting in the forum for your particular TV type.
au revoir is offline
post #2536 of 2973 Old 07-12-2007, 03:37 AM
tpfaz's Avatar
Whoops! I saw "Service Codes" in the forum title, but didn't see the CRT Displays. I'll look for something in the LCD forums. Thanks.
tpfaz is offline
post #2537 of 2973 Old 07-17-2007, 10:21 PM
bclare's Avatar
Hi
I after some help with my Sony 32" running 720p from a HTPC.
I have used the service menu in the past to correct geometry and color decoding with success.
However the current problem has occurred after moving the TV to a new house. So the TV is now in a different orientation and I can see some geometry flaws due to the earth's magnetic field.
The problem that I don't know how to fix is a flickering of the image from left to right. The image flickers back and forth in the horizontal direction, and is worse in the top left and bottom right corners. At the seating position the horizontal flickering causes a flickering of intensity in the 2 corners.
It only does this in 60Hz and not in 50Hz mode.
Has anyone seen this problem before and have a potential solution?
Brad
bclare is offline
post #2538 of 2973 Old 07-18-2007, 07:33 AM
au revoir's Avatar
Does this occur on all inputs?
What about when you use the TV's tuner?
How are you switching from 60hz to 50hz? From your PC?
Hopefully this interference is coming from your video source rather than the TV itself. Or maybe there is some electrical equipment nearby causing the problem. Or the electrical power in the new location is unstable.
Do you have a good power strip for protection against power surges?
Maybe someone else has some better ideas, but that's about all I can come up with ATM.
post #2539 of 2973 Old 07-18-2007, 01:37 PM
WJonathan's Avatar
There is a guy on Ebay selling PDF files of the 970 service manual for $12. I bought one and it seems to be the real deal. Most of the manual is devoted to diassembly and physical testing and repair, but there is a nice section on the service menu. To me it was well worth $12. Just search "kd 34xbr970" and see Store results.
WJonathan is offline
post #2540 of 2973 Old 07-18-2007, 07:04 PM
bclare's Avatar
Thanks for the reply.
I only use the vga input, but can check the RF input.
It does occur on 60Hz 720p and 30Hz 1080i, but not 50Hz 720p or 25Hz 1080i from the PC.
It's possible that the power is not great, but I am using a belkin surge protector power board.
I would've thought that the most likely problem is something that is common to the 60Hz 720p and 30Hz 1080i, modes on the TV. Hence there might be something in the service menu that can be changed
bclare is offline
post #2541 of 2973 Old 08-08-2007, 12:17 AM
NextGen's Avatar
Did anyone in this thread ever fully explain the DCTR (Dynamic Picture)? I recall a post or two about it by Kentech, but I don't think anyone fully explained the proper *middle* settings for DCTR. APED, and DSBO. I know that BLK? holds the different settings for these values, but I'd really like to know the proper starting point.
And help?
NextGen is offline
post #2542 of 2973 Old 08-08-2007, 04:30 PM
Mark_Likes_Games's Avatar
Quoted: 31 Post(s)
Quick questions:
KD-30XS955. Service menu.
I got in there and got familiar with it and exited without saving any changes. I will gain more experience before I save anything.
1- Is the only way to leave the service menu to turn off the TV?
2- If I make some changes to parameters and NEVER WRITE them to memory, what does the command [8] then [enter] do? Does this reset even things I didn't adjust to some other default values? Or does this only return anything I might have changed to the last memorized values?
Sorry if this seems basic. I hit many of the links and did quick search, but couldn't find this. Also in the post "02 - Navigating Service Menu" it says press - Enter to reset settings but this resulted in a message something like "feature not available" (I don't quite remember).
Thanks for the help. I'm confident that with a bit more research I can improve a slight convergence issue and some overscan. Nothing major. Thanks!
How DARE you question my ignorance!?!
Mark_Likes_Games is offline
post #2543 of 2973 Old 08-08-2007, 05:18 PM
Nitewatchman's Avatar
Quoted: 33 Post(s)
Liked: 25
Yes, at least that I'm aware of.
I don't know, nor do I know why you would press [8] then enter, but then again it's been quite some time since I've worked in the Sony's SM ...
I've only used the 1+3, 2+5 and 3+6 number keys when working in SM. 7~9 keys were "off limits" for my fingers
.... From KenTech's "02-navigating Service mode" post :
Originally Posted by KenTech View Post
CAUTION: AVOID keys 7 and 9, as they are part of a key-sequence that can reset all of the deflection or image-decoding settings back to a "factory-newborn" state. If you think you've hit any key by accident, STOP. In a few seconds it will revert back to SERVICE mode, as you'll see at the right side of the screen. All dangerous key-sequences are combinations of *three* keys, by the way.
The key combination that does that is the one Ken Mentions as quoted above. Don't do it . Going from others who did make that mistake(after many warnings here cautioning them NOT to do it), The "other default values" are not the defaults as they were "adjusted" at the factory, instead they are likely some set of useless(except perhaps for those at the factory starting on every set with the "same" set of values to start with) defaults present BEFORE any factory adjustments were made.
FWIW, I think I may have tried that once+ I think it may worked on my XBR960, but other than testing it, I never used it as I preferred, basically, not giving myself that "option", although on occasion for testing some things out(w/o writing any values) I did use the power cycling option to clear my "new" values(often on those occasions I wanted to power back up outside of SM anyway) ..... And instead, was sure to be careful enough to log everything as necessary and it was easy enough to change values back if I had already written them+ended up wanting to use something different or the "factory adjusted" default values ...
Hope some of that helps ....
Not at all.
Jeff
Nitewatchman is offline
post #2544 of 2973 Old 08-08-2007, 05:46 PM
Quoted: 31 Post(s)
Jeff,
Thanks man - glad to see you're still enjoying being a source of help on this!
I got this from the notes at the bottom of the 34XBR910 spreadsheet: "Restore Factory Defaults = [8] - [ENTER]". So that's why I was asking about that.
Don't worry, I have NO intention of resetting to the "newborn" state with the 7 and 9 buttons - I WON'T do that!
post #2545 of 2973 Old 08-08-2007, 07:42 PM
Quoted: 33 Post(s)
Liked: 25
^ No problem Mark -- I probably won't be too active on this thread in future as I am starting to get "rusty" on this stuff, as it has been quite a while since I've worked with any of it! I do enjoy looking at some fine looking video on the set, however+appreciating the info from this thread which helped me to get it looking like that!
Also, although I have some important stuff such as the XBR960 SM codes pages and the geometry+other pages from Service manual, as well as my notes/files on my sets factory default settings+my changes as well as important test patterns+info from this thread(Including various charts+posts from Ken), easily accessable some of the other stuff I had looked at but really didn't use has gotten archived onto DVD/CD's, and in some cases it would take quite a bit of searching to dig any of it up ....
Jeff
Jeff
post #2546 of 2973 Old 08-14-2007, 12:40 AM
NextGen's Avatar
Not really sure if this is adding to the thread much or not, but I thought I'd talk about the ENHA settings that are on my 34xs955 and how they have helped me achieve a better focus and sharpness of my picture without having to do the manual focus adjustment.
ENHA
HSHP - settings are from 0 - 255 and I've set mine at 0 since I'm not entirely sure what this setting does. It was set at 50 from the factory.
HSFO - Seems to be a focus offest parameter. I haven't really had to time to test out some theories I have for this setting, but I do know that the settings are from 0 - 15 (blurred to focused) and 15 really helped my focus tremendously. However, I didn't find the setting until after I had done a dynamic focus adjustment, so it is entirely possible that this code could be used in conjunction with a dynamic focus to get even more precise results. For instance, you could set HSFO to 7 and then do a focus adjustment, then readjust HSFO to your liking.
HPOR - No idea what it does, but 0 seems to be off which is where I have it at.
HLTL - This one, combined with HLTM appear to be either a focus shift? or a parameter that can be used to center any doubling of lines. Excuse my terminology, but to give an example of how this worked for me...
I always saw double lines, or a faint shadow from everything that I couldn't get rid of. It was easy to spot with dark text on a white background. All of the letters had this astigmatism to them. (This may have been caused by some sharpness offsets I used in my earlier adjustments for this set) Anyway, to make a long story short, I was able to try different combinations of HLTL and HLTM until I removed the doubling of lines. HLTL is from 0 - 3 and HLTM is either 0 or 1. My settings ended up at HLTL 3 and HLTM 0.
With my new settings for this set, it's harder to see what HLTL and HLTM do. Maybe Kentech or someone can explain it, but when HLTL is set to 3 and I switch HLTM to 1 I can see any sharpness pattern I have up change from very white lines to very dark lines. It almost resembles turning the sharpness down on the user menu, but I think it is something more than that. I'm just not sure, but I'll keep experimenting.
HAPL - Seems to work like a sub picture level of some kind. 0 is off which is where I have it set for now.
HAPA - Not really sure what this does, maybe it's an Amplitude for one or some of the other ENHA settings. I have set it at 0.
HCTL - unsure, so I set it at 0
HCTM - unsure, so I set it at 0 as well.
NextGen is offline
post #2547 of 2973 Old 08-15-2007, 06:20 PM
Quoted: 31 Post(s)
Well, I'm happy to report that by using the service menu (D-CONV) I was able to tweak out some annoying convergence on the left side of my newly acquired 30XS955. It's not perfect, but significantly better.
I also had a go at trying to reduce the overscan. My results were mixed. I was totally able to optimize it for an Xbox set to 16:9 mode. (I compared it to my projector at 0% overscan - very close.) However, that resulted in widescreen output from a PS2 being too small with the sides of the image itself visible. So I had to compromise and increase the HSIZ and VSIZ again slightly so both would be OK.
I expect I'll have to adjust this again when I finally hook up an Xbox 360 to the set. I've heard that I might have to use the MID3 group to adjust 1080 input. (By the way, is there no way to see what the input signal format is other than being in the service menu?)
I was really glad I could adjust out that convergence error. All this is a bit more inconsistent and finicky than my 1280x720 projector, but hey this is about as good as it can get on a CRT (TV) as I understand it, so I can "put up" with small issues.
One thing I'm worried about is whether or not I have maintained a correct aspect after playing with HSIZ and VSIZ - that is, I hope circles are still truly circular! It looks fine, but I haven't measured it yet. Part of the problem is that the DVD playback from PS2 is weird. I put the THX optomizer in there from a movie and could not get the circle in the widescreen check to be circular. For some reason it was still letterboxing in my 16:9 screen - lame. Game material does not look stretched or squished (I didn't try the actual movie).
One thing I noticed last night is when I changed a PS2 game to run progressive (there are a few) the image shifted to the right so now I have a small gap of black on the left side...huh? (I was not in the service menu - no other changes than going from 480i to 480p.) This did bug me - any ideas?
Well, I'm not intending to tweak forever (addicting as it is) but sometimes I just don't get why the image is so inconsistent across inputs/sources/formats. (All the above is on component connections via inputs 5 and 6.)
I labeled PS2 input 5 "Beta" just to give Sony props (and because, yes, I actually was a Beta user...)
post #2548 of 2973 Old 08-15-2007, 08:11 PM
DSperber's Avatar
Quoted: 227 Post(s)
Liked: 186
Don't be embarrassed. You should be proud!
I'm STILL using an HFR-900 Super-Beta (vintage 1984, and still working perfectly) as my "D* composite pass-through" for one of my SD TV's. It doesn't have S-video, but neither does that TV... just composite.
And I STILL use an EDV-9500 ED-Beta (vintage 1989) as my "D* S-video pass-through" for another SD TV, and an EDV-7500 (vintage 1990) in a similar use for watching D* via S-video on my PC (which has an ATI TV Wonder 650 PCI TV card, also supporting OTA via built-in ATSC tuner and amplified indoor antenna).
All of these Sony Beta machines are still working flawlessly, both electronically and mechanically. I don't use them for recording any longer but definitely still use them for the occasional playback of Super-Beta and ED-Beta recordings made many many years ago (and which still have not yet disintegrated into dust, but still play perfectly). For actual recording of SD from D* I have a Hughes E45 receiver and Hughes HDR-205 D-VHS VCR at each TV node. This gives me digitally perfect recordings and playback from D*, which is why I no longer use analog VCR's to record.
I do have JVC S-VHS VCR's (9400U and 9800U) also available on these same SD TV's and PC, so I can watch anything I want on any TV. And I have JVC D-VHS VCR's (40K and DT100U) for offloading HD content to D-VHS tape from my DCH3416 from TWC. If I'm going to be away from home for several weeks, I'll use the JVC D-VHS VCR's in LS3 mode to record SD from D*. That gives 21 hours of better-than-Svideo quality LS3 recording on a DF420 tape (which would provide 7 hours of D-VHS recording from D* on my HDR-205 machines).
So yes, I'm a Beta man too. And I even have a second "spare" EDV-9500 and EDV-7500 that are simply sitting on a shelf, in case I ever need parts (since you can't get them any longer), along with six brand new still-in-wrapper never opened ED-Beta blank tapes... maybe for some possible future use someday.
But JVC has made giant progress in the quality of their S-VHS machines over the past 10 years (although I've stopped buying them), and now with their HD D-VHS machines (which have super-fabulous S-VHS picture quality as well). So I now do any VCR recording on JVC machines, either in S-VHS or D-VHS.
DSperber is offline
post #2549 of 2973 Old 08-15-2007, 10:56 PM
NextGen's Avatar
Try adjusting your MID2 settings as a last resort, that is what I ended up doing on my 34xs955.
NextGen is offline
post #2550 of 2973 Old 08-27-2007, 12:12 AM
NextGen's Avatar
I've finally accomplished what I thought would be impossible with my 34xs955. I made it look very similar to my 24"FW900 computer monitor. Took me forever and a day to get here, but now that I'm here I'll never go back to a downgrade in technology. I truly hope SED gets here soon or my tubes last forever.
These are my final~ settings for the 34xs955 HDMI input. I only use this input because that is what my Pio 91 connects to, and I like having the HDMI conversion since it forces my 480i connections to 480p with the proper 4:3 ratio with black bars, or 16:9. Most of my settings came from reading, and seeing first hand, what some of the service codes do to the image, and other settings came from the 34xs955 service manual. I tried to eliminate any instance of video source alteration to get as true and clean a signal as possible.
The key here is to get the MID1 codes right, then adjust the MID2 codes. If you have either group too far off the focus and resolution is very far off and the Sharpness = Min will not work. The ENHA settings are also key here too. Combining all of these correctly will allow you to keep the sharpness slider set to Min or off.
I don't like to add sharpness, personally, for three important reasons.
1. It makes jagged lines stand out more.
2. It alters the source material. (My FW900 computer monitor doesn't even have a sharpness slider on it.)
3. It is a bad compensator for focus.
I've attached a text file with many of the codes I use for my TV.
I will be uploading some images later to show how great this set looks, especially for video games.
Please keep in mind that these settings are for those of us that normally play video games on this TV. These settings are probably not optimal for low to medium quality broadcast material.
34xs955_8_28_07.txt 2.3876953125k . file
NextGen is offline
Reply Direct View (single tube) CRT Displays
