THE SONY SERVICE CODES - Articles, Comments, Discoveries - Page 99 - AVS Forum | Home Theater Discussions And Reviews
 2Likes
post #2941 of 2973 Old 01-31-2012, 06:35 PM
ADU
ADU's Avatar
Quoted: 313 Post(s)
Liked: 519
You should never reset the SM on the Sony HD CRTs, under any circumstances.
Resetting the SM will not restore the TV to the original settings when you bought it. It will erase all data in the SM, including settings/tweaks made at the factory which are crucial to the TV's basic operation.
NEVER...
EVER...
EVER...
EVER... reset the SM.
If that's what you've done, then I think these your basic options:
a) Try to find a professional calibrator who knows his way around the Sony CRTs, and thinks he can fix it (which is becoming somewhat hard to find).
b) Take it to a Sony authorized repair shop, and hope they know what they're doin.
c) Contact Sony Parts, and ask if they still have a "900" (ie fee-based) nonauthorized technical support line where you can get some help. (Note: you may need a copy of the service manual for this as well.)
d) Order a service manual and try to fix it yourself (which may make matters even worse if you are not a very technical person, because there aren't really any detailed instructions included in the service manuals).
e) Try to find someone else with the same model, who's written all their original settings down (like you should have done in the first place), and has the time to help you figure it all out.
f) Accept that you made an unfortunate mistake and look for another similar TV on Craigslist to replace it, or get a shiny new plasma or LED TV instead.
barrelbelly likes this.
ADU
ADU is offline
post #2942 of 2973 Old 02-25-2012, 06:34 AM
sumguy99's Avatar
Getting back to my SD Wega (36FS10) - I get it that it might not be able (or even desirable) to enable 480p in the service menu (even if that were possible). Enabling V compression would be useful - has anyone ever seen that as a setting in the service menu?
What I'm really interested in is -> has Sony ever put PiP (enable/disable) in the service menu for any of these Wega TV's?
sumguy99 is offline
post #2943 of 2973 Old 02-27-2012, 10:39 PM
djvasco's Avatar
Originally Posted by xomoi View Post
Why is it that some service menu codes are locked or do nothing on smaller sony crts? I have a sony model kv-13m40 and another small sony crt in which some common values do nothing. Values such as hsiz, cpin, pamp, trap, and some other do nothing to change the geometry. The numbers can be adjusted but they do not change the picture. I assume that this is done intentionally since I have two sets in which those same values are locked. It's not that big of a deal, but I would like to know why it set this way.
I have this exact problem. I can't change the geometry of my old 20 inch Sony Trinitron because adjusting the HSIZ value does not change the picture at all. The HSIZ code seems to be locked.
I really need to unlock the HSIZ. Can anyone help me?
djvasco is offline
post #2944 of 2973 Old 05-03-2012, 03:08 PM
Partyslammer's Avatar
Quoted: 14 Post(s)
Liked: 43
I have a KV34XBR800 with a build date of Nov 2002 and I've noticed it recently shutting down while viewing. My initial guess is that it's the two IC parts that seem to be the typical cause of this sort of problem. However, when turning it on, it's inconsistent as far as how many "blinks" the red standby light flashes before it starts up. Sometimes it's as little as a couple up to 9 flashes. The other thing - the last couple times it's shut down, the screen kind of flashes to a near solid red as it shuts down. Removed the back and wound up spending a lot of time thoroughly cleaning out the dust. Checking the onscreen maintenance/status display, this is what I get:
Version 0 0 Service
F/A: 11111111 10111111
CBA: 11111111 10110001
Anyone have any ideas what that means?
Partyslammer is offline
post #2945 of 2973 Old 07-17-2012, 11:41 AM
jameslieb1's Avatar
i have the kd-34xbr960. im using it for xbox.360 hdmi gaming. i switched hdpt to 0 and input lag went.away, but gave me a picture with part of the left chopped off, flunctuating brightness as stuff on the screen moves, and the infamous vertical right-to-left scrolling bar. i managed to fix the picture position thru the service menu but i still have those other 2 problems. plz help!
jameslieb1 is offline
post #2946 of 2973 Old 07-29-2012, 10:59 PM
jillybran's Avatar
jillybran is offline
post #2947 of 2973 Old 07-29-2012, 11:03 PM
jillybran's Avatar
Thank you! This info helped me too
post #2948 of 2973 Old 07-30-2012, 05:06 AM
Vic12345's Avatar
Quoted: 72 Post(s)
Liked: 29
Hi any service mode tweaks for old sony kv36fs13? I've tried a lot of them.
Vic12345 is offline
post #2949 of 2973 Old 08-16-2012, 11:44 PM
turnkit's Avatar
Oh, please somebody help!
I made my final service mode screen adjustments on my KD-34XBR970 and saved the parameters to non-volatile RAM (+) and within a second or so the screen flipped into a GRID PATTERN and the television started producing a TEST TONE!
Now when I turn on the set I can see my DVD component input for about one or two seconds but the television immediately switches to a blaring TEST TONE and this GRID TEST PATTERN.
I can go into service mode again but the whole time the tv's blares the test audio tone and the video input cannot be switched.
I hope someone knows how to adjust this!
The internal grid pattern would have been really useful to know how to turn on when calibrating but now that I'm done I really need it off!
turnkit is offline
post #2950 of 2973 Old 08-16-2012, 11:48 PM
turnkit's Avatar
Oh, and yes, I already tried unplugging the set for a few minutes and plugging it back in... it still came up and switched right into test tone mode.
While the service mode works, if I don't choose service mode I can't do simple things like change the volume level. I think I bricked my whole TV.
turnkit is offline
post #2951 of 2973 Old 08-17-2012, 02:07 AM
turnkit's Avatar
Sorry for the noise! I found the solution here:
http://www.avsforum.com/t/531494/the-sony-service-codes-articles-comments-discoveries/1700_100#post_7940621
http://www.avsforum.com/t/531494/the-sony-service-codes-articles-comments-discoveries/1400_100#post_7472949
THANK YOU AVSFORUM!
In the blue colored text section -- the QM section -- it's the service code PATN. It needs to be set to 0.
turnkit is offline
post #2952 of 2973 Old 08-25-2012, 11:29 PM
kevers7290's Avatar
Hey everyone. I'm having some focus issues with my KV-30HS420. The edges are really blurry. I understand that these CRTs all have this to some degree, but I watch a lot of anime/subtitles movies and it is noticeable and annoying. I have used the service menu and made the screen size nearly perfect (as it too was off) and tried adjusting the "focus settings" like QPAM, QPAV etc. to no avail. I know others have posted with similar problems, but I was wondering if anyone else with this set had some service values that I could use to help with this focus issue. Feel free to reply or PM me.
Edit:
It appears that the focus problem extends beyond just the edges of the screen. The text on the XMB menu of my PS3 looks kind of blurry. Are there any service mode values that I can tweak to correct for this (preferably less invasive settings as I'm afraid of bricking my TV)? I would rather not open up this television as I'm not the most technologically inclined when it comes to this kind of thing.
kevers7290 is offline
post #2953 of 2973 Old 09-07-2012, 06:52 PM
banjo86's Avatar
Hello! my tv model is a sony wega kv30hs420 does anyone know how to deal with a wave effect on bottom of the screen? it only appears on hd sources (component and HDMI) but not on 480i or 480p. I've tried adjusting it in the service menu but nothing seems to help.
EDIT: it only seems to appear at 1080i and not 720p.
banjo86 is offline
post #2954 of 2973 Old 11-25-2012, 06:01 PM
jameslieb1's Avatar
Im having a problem with my XBR960. There is a layer of static over the picture. This is regardless of source and the static goes over not only the actual video feed but also things like the user menu. I'm worried this might be a problem with something inside the set but does anyone know if this is something that can be fixed through the service menu? I'm really frustrates because I don't want to go through all the trouble of acquiring a new one of these. Thanks.
post #2955 of 2973 Old 01-06-2013, 07:36 PM
jassiji's Avatar
Hi,
I searched this thread & cannot locate a similar problem.
My 34xbr960 remote has become unresponsive & the set is changing input to memory stick mode while watching TV.
First I thought it was my remote & changed the batteries, but using the manual controls does not help.
Is it toast or is there any solution?
I am watching Sony 40" Google TV but it's pathetic compared tomy XBR.
Can anyone point me to a thread where this has been discussed. Thanks.
jassiji is offline
post #2956 of 2973 Old 07-09-2013, 03:02 PM
NextGen's Avatar
I have some new settings I've been tinkering with in regards to lower resolution video games.
Specifically PS1 which outputs 240p. The TV seems to scanrate convert the signal to 480i, I guess?
If anyone else knows what other settings do inside the DRCMFV1 and DRCV code groups I'd love to understand them more.
So the object here was to lessen the impact of blurriness from the DRC (Digital Reality Creation) processing.
*My set is the 34xs955 16:9 model.
*I used a real PS2 console with Component into Video 6
*DRC mode set to Progressive
*PRO setting
There are no adjustments for DRC on the user menu unless you change the ID7 code to 25 which I do not recommend you save it as if you do as it might ruin the TV. However, if you do set ID7 to 25 you can go into the user menu and adjust all three user DRC modes to 1 and 1 and they will save. No idea if this actually effects anything I just figured it wouldn't hurt. I did not save ID7 to 25 as I was afraid it could damage the TV.
With a service manual, and Doom for PS1 I did some testing and here is what I found.
First of all, I set a lot of stuff to 0 in the 2103-1 and 2170P-3 code groups. (My settings are nothing like they were before so disregard previous post settings)
Keep in mind I have all sharpness settings at 0 on my set and all Velocity Modulation Turned Off/bypassed/disabled in the service menu as well, I think that's why having settings like PREO and SYSM to 0 seem to work fine, as in have no effect on the image.
For 2103-1 = SHAP, PREO are all now set at 0
The 2103-1 SHFO code is now set to 3 (It appears SHFO shifts focus. It's easily recognizable on text like the Avia II DVD menu in 480i when set to 3 everything looks centered to me. Not sure if PREO needs adjusting after this or not, it's hard to tell) (However, I did my testing of the DRC groups with it set to 0 as I think it makes it easier to see differences when adjusting)
For 2170P-3 = SYSM, ALL VM codes, SHOF, SHFO, PROV, F1LV, LTLV, LTMD, and CTLV are all set to 0
When playing Doom for PS1 here is what I notice...
Inside DRCMFV1 I have noticed that when MFVR is set to 1, assuming other codes are set per the service manual, text is easier to read. However, there is a blur of all the textures and what appears to be severe lag when playing the game, it's an almost watery look to everything during movement. When I set MFVR to 0, text is harder to read as it is blocky compared to 1. Textures appear sharp, almost too sharp and that is where i think I am on to a discovery.
In DRCMFV1 I have codes FMTH, FSEL, LMIT, LMLV, LMSL, VDLY, VDPR, WPLL, CRCT, VRA all set to 0
In DRCV I have codes ORES, VRB, and ONCT set to 128. NRA is set to 0
Inside the DRCMFV1 code group:
*With MFVR set to 1 and VRB set to anything the game itself looks and feels watery and laggy during movement.
(Watery is the only way I can describe the effect.)
*With MFVR set to 0 and VRB set to 0 textures look sharp but blocky, and text is harder to read.
(The game as a whole appears too sharp as if sharpness is turned up on the set.)
*With MFVR set to 0 and VRB set to 128, factory, textures look good but still slightly blocky.
*With MFVR set to 0 and VRB set to 255 not only do textures look smooth instead of blurry, but the blocky-ness seems to be alleviated to a good extent.
The game feels less laggy as if the frame-rate has increased even though I know it hasn't, and I don't get that watery look while playing.
Another way to show the effects is if you look at the little man face and the text at the bottom of the screen in Doom 1.
MFVR=0 + VRB=0 The guys face looks blocky and text is blown out.
MFVR=0 + VRB=128 The guys face looks slightly blocky compared to VRB @ 0, text looks fine, textures do gain some detail but the entire game still looks slightly blurry.
MFVR=0 + VRB=255 The guys face is clearer, I can see the white inside the eyes, text is clear as well, textures do appear slightly soft but still full of detail, as in they do not look blurry.
This leads me to believe that VRB interacts with MFVR as some kind of blur filter combined with sharpness or possibly they interact like the Wet/Dry of an effect processor.
VRB @ 255 and MFVR @ 0 seems to do the least amount of processing to the signal. I notice less lag, clear text and textures, with no watery look during movement. There is a slight softness to the textures, but I believe this is actually what the textures should look like to begin with since fine detail is still present.
And this last part could be my imagination but, for some reason setting all the DRCV codes to 0 appears to help too. I can't really explain it, but it seems to clean up more of that watery movement feeling I get from low res games. However, this could all be my imagination or simply more interaction with the DRCMFV1 code group which could complicate everything even more.
Then again, setting the first DRCV code to 128 or 255 and the rest to 0 may also be cleaning up the image a bit too.
I really don't know to be honest. It's somewhat subjective to test some of the settings in regards to motion and such low res imagery.
I have these adjustments for all inputs.
As of now I have left the DRCV codes set as follows:
ORES, VRA, ONCT = 0 and VRB = 128
The DRCMFV1 codes are:
FMTH, FSEL, LMIT, LMLV, LMSL, VDLY, VDPR, WPLL, CRCT, VRA = 0 and VRB = 255
Perhaps it is just my imagination but this seems to be the optimal DRC settings for my set.
I hope this helps someone, and if anyone has more info on what each the DRC settings do I'd love to hear about them.
I even notice the difference in PS2 games that run in 480i. Games like Ridge Racer V are actually playable now although I'm sure true 240p on an SD set would look better.
And yes Doom 1 still looks like a pixelated mess, it's just now a more tolerable pixelated mess.
I suspect it would look worlds better on an SD set or possibly converted to 480p with a better converter like an Extron Emotia or VSC unit to bypass the TV's DRC engine.
NextGen is offline
post #2957 of 2973 Old 07-16-2013, 07:56 PM
Kelegacy's Avatar
EDIT: I guess I was in the factory mode and not service mode, which I was able to find. Factory mode has White Balance settings however, and that is what I wanted to tweak. Service menu seemed pretty empty.
I was able to find the Factory Menu code for my KDL46453A, but I can't seem to save anything. I see that other models let you hit 0 and then muting, but it doesn't seem to work for my set. I can't seem to figure out how to save any changes. There is a Data Backup option that is set to OFF, do I need to activate that?
Any help would be appreciated! I've tried other combos I've seen in this thread, such as Muting then Enter (I don't have an Enter button, but I guess it's the "center" button), or 0 then Muting, etc. but nothing has worked yet.
Kelegacy is offline
post #2958 of 2973 Old 03-16-2014, 08:48 PM
NextGen's Avatar
Maybe I'm tripping.
But i just made a custom resolution of 1440x810@ 60hz progressive scan in nvidia control panel and the tv accepted it.
Did this on a 955 while trying to find custom resolutions that were 16/9 .
sorry for the bump but seemed mind blowing at the time.
I just tested it by using a 1280x720 image and displayed it as Actual Size in the windows photo viewer and got space around the whole image.
Other modes that allowed 16/9 60hz Progressive Scan went all the way to 1840x1035. Any higher and the screen blanked out.
I have no idea how to tell if the display is actually running at these resolutions in true progressive scan other than by nvidia control panel.
can others confirm?
http://pacoup.com/2011/06/12/list-of-true-169-resolutions/
After spending time with it, and going back and forth to interlaced mode, it appears that the xbr960/955 models will do 1840x1035 progressive scan. I had no idea a CRT TV could do this. I wonder what resolution the xbr800s will do in progressive scan? would be nice for down sampling video games
homerging likes this.
NextGen is offline
post #2959 of 2973 Old 10-08-2014, 12:00 PM
jtown017's Avatar
Quoted: 13 Post(s)
I have a KV-34xbr800 tv that had overscan issue when switched to directv. it was only bad on menus and news tickers as the edges would be cut off.
The tv recently had a IC repair for 6 blinking lights. It worked. However, at the top of the screen there is a little tilt. It is not noticeable with regular picture. But when there is a logo, news ticker, or scoreboard at the top of the screen you can notice the tilt. its slight but it is a concave/convex issue.
Is this something that has to be fixed in the service menus? I am hoping not. Or was some component bumped when the IC repair was made?
i will get a picture tonight
jtown017 is offline
post #2960 of 2973 Old 10-10-2014, 08:26 AM
homerging's Avatar
Quoted: 31 Post(s)
It isn't the answer you want to hear but there is no way of dealing with geometry and overscan without going into the service menu.
It is possible things have moved slightly because of the TV being moved but it sounds like the TV was shipped with poor geometry.
If you post pictures of the whole screen that show the problems I may be able to figure out which settings may help. There isn't a very clear and unified novice-friendly guide in this thread about dealing with geometry.
Usually pay TV receivers will not do HD over component with most or all channels as content providers strictly prohibit it. Devices may say they're outputting 1080i but still output SD or 480p/576p over analogue connections. It's important to be able to send a 1080i signal to the TV for setting geometry as there are many more options with SD.
homerging is offline
post #2961 of 2973 Old 10-10-2014, 10:10 AM
Floydage's Avatar
Quoted: 147 Post(s)
Liked: 64
Good point on the output type but this TV has a DVI input. Of course what is the DirecTV output?
Shouldn't the TV repair person have fine tuned the TV if anything shifted? (not a full-on calibration but...). How much did this cost?
Floydage is offline
post #2962 of 2973 Old 10-13-2014, 04:30 PM
jtown017's Avatar
Quoted: 13 Post(s)
I have attached a photo. I took this the other night real quick. Don't mind the artifacts caused by the camera.
I will try to get better pictures tonight.
The more I watch tv, the less i see problems with the tilt. It definitely has overscan. I only notice it on tickers (see bottom of pic) and im assuming its because i wouldnt notice picture being lost unless it was text. hope that makes sense.
you can kinda see the curve illusion. its almost like due to glass but maybe its due to the overscan.
i dont think i understand your HD over component deal. Right now, I have a DirecTV genie box hooked to the TV w component cables. i also have a xbox 360 hooked to the tv thru components. the directv output is set to 1080i. i can go to an HD channel and would assume i am getting HD 1080i. i go to a non hd channel (SD) and it looks like crap. so i definitely notice a difference and know i am getting HD.
i guess thats where i am confused. so am i getting 480p max?!
on xbox 360 was i only getting that as well? the xbox was set to 1080i. and when it was set lower it looked like crap.
the repair for the ICs was 225 for an in home service. the only problem was the tv was on a channel without any news tickers or logos that the overscan would be noticeable. its hard to notice the overscan unless there is something you know is getting cut off like text instead of picture. i just assumed thats the edge of the picture until i see a news ticker then i know there is overscan.
DirecTV output is set to 1080i but like i mentioned above, i dont think i understand fully
jtown017 is offline
post #2963 of 2973 Old 10-13-2014, 05:06 PM
Floydage's Avatar
Quoted: 147 Post(s)
Liked: 64
Wow at that price I'd think they'd bring a generator or disk to verify/tune. I mean I'm not expecting a full-on calibration but...
I borrowed a neighbor's Sony movie Blu-ray disk and it has a test pattern section. Something to think of if you can play those; I don't know about DVD movies. There are special cal disks out there. Sometimes I stumble across a vacant DTV sub-channel that is displaying test patterns of sorts. On the fly I'll tune into a local station weather sub that has a nice stationary frame to use, it might be provided to the station by The Weather Channel or the like.
Yeah your source devices should have a way to fix their outputs, most likely in the menu although I have a sat./HD tuner that does this via a front panel button (some really old stuff was on the back). Now on my Panasonic HDTV, which is akin to this TV, I know it's receiving 1080i by virtue of the Aspect button on my remote won't do anything (i.e. only changes aspect below 1080i and this TV can't do 720p). Might check your manual to see if your Sony does the same.
You mentioned tilt in another post. You might see if it has a tilt adjustment in the user menu. On my Panny it's within a function called Geomagnetic Correction.
Floydage is offline
post #2964 of 2973 Old 10-21-2014, 09:10 PM
fkie's Avatar
Anyone knows how to disable the AUTO 16:9 enhancement on a KV-27HS420?
fkie is offline
post #2965 of 2973 Old 10-24-2014, 10:43 AM
fbov's Avatar
Quoted: 262 Post(s)
Liked: 150
Originally Posted by jtown017 View Post
I have attached a photo. ...It definitely has overscan. I only notice it on tickers (see bottom of pic) and im assuming its because i wouldnt notice picture being lost unless it was text. hope that makes sense....
Two things.
Since fixed pixel displays have become commonplace, producers are no longer respecting image boundary specs, running program right to the edge. A properly set up HD CRT will crop the edge of the image, and you don't want to completely fix that because ...
I did the adjustments in service mode when my 34XBR970 was new, and could get good image out to the 95%. That last 5% was badly distorted if I made it visible, thus the 95% setting. It still cropped many tickers, but at least you could read the text...
HAve fun,
Frank
fbov is offline
post #2966 of 2973 Old 10-30-2014, 10:08 PM
NextGen's Avatar
Originally Posted by fbov View Post
Two things.
HAve fun,
Frank
It could also be his DirecTV unit. We have dish here at my house, and I always got a picture that was shifted to the right and down with our old unit. The new unit does not have this problem and displays everything correctly. I have about 1-2% over-scan on my set.
NextGen is offline
post #2967 of 2973 Old 11-13-2014, 02:36 PM
IrishLuck's Avatar
Helllo everyone. I own a KV-34HS420 and the HDMI port does not appear to be working. I have tried various cables and devices to no avail. I have entered the Service Menu and changed the HDMI settings but nothing seems to be working. Any suggestions?
IrishLuck is offline
post #2968 of 2973 Old 11-15-2014, 12:59 PM
blue_z's Avatar
Quoted: 12 Post(s)
Any suggestions?
Don't use 1080p.
Maximum accepted resolution is 1080i.
Regards
blue_z is offline
post #2969 of 2973 Old 11-16-2014, 11:26 AM
Floydage's Avatar
Quoted: 147 Post(s)
Liked: 64
Good one blue_z. Also, I don't know about this model but many HD CRTs won't accept 720p either.
Floydage is offline
post #2970 of 2973 Old 02-17-2015, 07:25 AM
jhunterthompson's Avatar
I have these light blue discolorations on my XBR960
They are in the upper right and lower left when the screen is list. I am unable to adjust it away with the lading setting. Does anyone have any other ideas.
http://imgur.com/2H8msYZ,oS2FLfv,uDUutq7#0
jhunterthompson is offline
Reply Direct View (single tube) CRT Displays
