The Official Samsung SlimFit HDTV Thread... - Page 95 - AVS Forum | Home Theater Discussions And Reviews
post #2821 of 2867 Old 02-08-2010, 01:00 PM
Sunshine2's Avatar
My 3 year old Samsung txt2793hx/xaa Slimfit started acting up last week. While watching the TV lines suddenly appeared across the top of screen and then it shut off. I unplugged the TV and DVR and the picture returned, but no sound. The next morning I unplugged again, turned on the TV and sound and picture worked fine.
Happened again about a week later, unplugged and got both sound and picture right back.
Last night, no sound or picture. Now I hear the annoying noise that accompaines turning the TV on, but no picture or sound. Any ideas?
Sunshine2 is offline
post #2822 of 2867 Old 03-27-2010, 05:27 PM
bogardboy's Avatar
Can you pleeeeaaase tell me ur Deflection and Line correction values! PLEASE I'LL DO ANYTHING I've been trying to fix my TXT3093WH for a whole year now with no luck.
bogardboy is offline
post #2823 of 2867 Old 03-27-2010, 05:28 PM
bogardboy's Avatar
Originally Posted by Nicksterr View Post
I got a TX-T3093WH last month for $500 new and am very satisfied watching it with the standard picture mode. HD on this set is better than any LCD I've seen.
I picked up a Panasonic upconvert dvd player yesterday and I'm not sure about a few of the audio settings:
Audio:
PCM Output: Up to 48kHz or Up to 96kHz? I can't seem to find this specification in the tv manual, or anywhere for that matter.
Dolby Digital: Bitstream (default) or PCM
DTS: Bitstream (default) or PCM
Any help would be greatly appreciated.
post #2824 of 2867 Old 03-27-2010, 05:48 PM
The Lizard King's Avatar
http://www.avsforum.com/avs-vb/showt...post18390362#8
TLK
The Lizard King is offline
post #2825 of 2867 Old 03-28-2010, 12:13 PM
bogardboy's Avatar
As i said in that other site. Values for TXT3092WH do not work for my model TXT3093WH. If anyone can please post their Deflection values for this TV this would be the best thing that could happen in life.. i'm tired of trying to fix this. There's GOTTA BE SOMEONE OUT THERE WITH THIS TV!
post #2826 of 2867 Old 04-24-2010, 01:33 PM
Phlogiston's Avatar
I know I'm bumping a really old thread, but I need help.
I completely screwed up my Deflection Menu, from top to bottom. I have a 30" Slimfit, the 82 series. If someone could copy theirs for me I would really appreciate it.
Phlogiston is offline
post #2827 of 2867 Old 05-09-2010, 10:13 AM
http://www.avsforum.com/avs-vb/showt...7#post17598337
TLK
post #2828 of 2867 Old 06-02-2010, 10:03 AM
neologizm's Avatar
hello all, I have searched far and wide for a service manual for any Slimfit tv (I own a txt3093). I can't find any online! please, if you have one, could you post a link, or email me a copy at mehulmalik(at)gmail.com? pretty please? thanks!
neologizm is offline
post #2829 of 2867 Old 11-21-2010, 03:18 PM
Ikabob's Avatar
I have not visited this forum for a couple years. I have a Samsung Slimfit HDTV. I wanted to attach a radio's line in from tha audio out jacks on the TV. The radio accepts analog signals. I plugged the RCA cables into the tv and a 3/8" plug into the radio but no signal. Do I have to do something to activate the audio outputs on the back of the Samsung? I canny find the owners manual. The reason I want to go to the radio in is because the radio has a subwoofer and some additional speakers and so might add some additional fidelity. The tv is attached to a cable box. The cablebox outputs provides a signal but the signals do not synchronize by a fraction of a second which is not good. Thanks.
Ikabob is offline
post #2830 of 2867 Old 07-16-2011, 08:18 PM
seatacboy's Avatar
Quoted: 46 Post(s)
Liked: 29
I just acquired a used TR3079WHX minus an owners' manual and remote. Any suggestions where I could find an owners' manual and the appropriate codes for a universal remote?
seatacboy is offline
post #2831 of 2867 Old 09-03-2011, 01:13 PM
nyc791's Avatar
Hi, I have the TX-T3092WH, and it's also connected to a Scientific Atlanta Explorer 8300HD cable box from Cablevision (iO).
Just bought the Samsung Blu-ray BD-D5100 Disc Player, and not sure how to connect all of them together. Right now I have a GO VIDEO DVR5000 TV/VCR Combo connected.
With so many wires, I'm kind of confused on how to connect that Blu-Ray player. Any advice and/or help would be greatly appreciated.
nyc791 is offline
post #2832 of 2867 Old 09-05-2011, 10:33 AM
shwru980r's Avatar
Use an HDMI cable.
shwru980r is offline
post #2833 of 2867 Old 11-27-2011, 02:22 PM
WaveBoy's Avatar
Quoted: 134 Post(s)
Liked: 43
Hands down thee' best CRT I've come across, speaking of the 27" Slim Fit Samsung CRT. The Color gamut is great, there's zero color crushing when going farther and beyond over the mid point, no color bleeding and the blacks levels are great as well. Plus you get a great set of temperatures like Warm1, Warm2, Neutral, Cool1, Cool 2 ect.
It puts my Sony 32" Wega to shame....Which i'm not happy with. Considering the Greens are far too dark, and the reds boarder a bit into organge territory. plus when you amp up the color or even to the max the colors barely change, everything just becomes intensified....
the downside is that it doesn't come in 32".....I'd say it's the perfect set to game on as far as the Wii is concerned. It's just lacking Progressive Scan. And forget Widescreen, since the wii does anamorphic stretching cause the image to look soft and jaggedy which even hampers the motion resolution....It just doesn't look right.
WaveBoy is offline
post #2834 of 2867 Old 12-15-2011, 12:18 PM
buggatti's Avatar
hey guys i have messed up can someone please post the default deflection setting for slimfit tx3082whx
THAnks You
buggatti is offline
post #2835 of 2867 Old 01-11-2012, 06:16 AM
seatacboy's Avatar
Quoted: 46 Post(s)
Liked: 29
I acquired a used TR3079WHX, and while it has a very good picture quality, the set requires several minutes before either the Cable or Antenna tuners recognize any stations. It takes between 5 and 10 minutes before a picture shows up on the screen. Any ideas on how to repair/remedy this problem?
post #2836 of 2867 Old 03-21-2012, 04:51 PM
bigpoppa206's Avatar
Anyone know how to tighten up the HDMI connection on a Samsung TX-R2678WH? Remove the back and do it?
bigpoppa206 is offline
post #2837 of 2867 Old 05-10-2012, 09:16 AM
kenichi32's Avatar
Can anybody give me DEFLECTION setting for TX-T2082 samsung .
kenichi32 is offline
post #2838 of 2867 Old 07-22-2012, 08:47 PM
Wishing i knew this one myself, Mine fell inside or something.
post #2839 of 2867 Old 05-03-2013, 06:48 AM
tinpanalley's Avatar
Quoted: 84 Post(s)
Hello... if anyone's around...
Does anyone happen to know what settings in the service menu of the TXT3092WH Slimfit can be used to address tiny convergence issues?
tinpanalley is offline
post #2840 of 2867 Old 07-15-2013, 03:54 PM
post #2841 of 2867 Old 09-25-2013, 06:10 AM
seatacboy's Avatar
Quoted: 46 Post(s)
Liked: 29
My Sammie 3079 remains pretty darned impressive in terms of PQ. Checking out most other entry-level LED and LCD sets, they aren't superior to this six-year-old CRT.
Curious as to tips some of you have for keeping the Samsung 3079 going for a couple more years.
post #2842 of 2867 Old 10-19-2013, 12:47 AM
If anyone is looking for one as is or for parts, I have one in the Pacific Northwest I'm getting rid of. Best offer.
post #2843 of 2867 Old 11-05-2013, 04:50 AM
ID4
ID4's Avatar
Hi!
I have Samsung Slitfit WS32Z419T, and it have dameged the part numbrer "AA95-03482B", it is the "ASSY SUB PCB-FEATURE BOX".
The problem is that is is very difficult to power on the TV, the red led blinks but no power on, you need to try a lot to get the TV powered on.
¿Where to get the damaged part "ASSY SUB PCB-FEATURE BOX"? ¿Anyway to repair the part in case I can get a replacement?
Thanks!!!
ID4 is offline
post #2844 of 2867 Old 02-01-2015, 09:57 PM
seatacboy's Avatar
Quoted: 46 Post(s)
Liked: 29
We still enjoy our Slimfit 3079 and were wondering who else out there is still using these Samsung televisions?
post #2845 of 2867 Old 08-24-2015, 08:58 PM
Liked: 0
Does anyone know of a way to disable this T.V. from up converting 480i to 480p? I'm guessing that's what it's doing to make my DIRECTV SD service picture quality look like crap (worse than on a regular SD CRT). I think the DIRECTV SD MPEG-2 signal is too compressed to have enough data to be upconverted well. Wish I could get the DIRECTV SD service to look good on this TV, then I could watch DIRECTV SD, OTA HD, Blue Ray, etc. all on one TV.
JohnHammock is offline
post #2846 of 2867 Old 08-25-2015, 05:44 AM
Ratman's Avatar
Quoted: 1487 Post(s)
Liked: 1191
Do you own this TV too?
I understand you're desperate for an answer, but asking the same question in various old threads will not help. Stick to your original thread.
Ratman is online now
post #2847 of 2867 Old 08-25-2015, 09:45 AM
Floydage's Avatar
Quoted: 161 Post(s)
Liked: 70
And there's gotta be a KV-30HS420 thread or something close like KV-34HS420. Here's the list of models:
https://en.wikipedia.org/wiki/FD_Trinitron/WEGA
Worked your way around in models, then up if nothing around.
Floydage is offline
post #2848 of 2867 Old 08-25-2015, 10:54 AM
Liked: 0
Well I looked through the first 10 pages of the CRT forum and I still haven't found an official thread for the Sony. But yes I do have this Samsung as well. My brother found it at a yard sale thinking that the 4:3 screen size would fix the glitch problem, but didn't. The Sony is widescreen. Apparently theyre both upscaling no matter the screen size and shape. So I found a few threads that were actually talking about resolution to post in. But thanks for the advice guys. If you happen to run across a better thread please let me know. Thanks.
post #2849 of 2867 Old 08-25-2015, 11:28 AM
Ratman's Avatar
Liked: 1191
Apparently, there may be bad cables or flaky tuner if it happens on both TV's.
post #2850 of 2867 Old 08-25-2015, 11:38 AM
Liked: 0
The cables are good, and the DIRECTV receiver is operating as it should as well. The receiver outputs 480i analog, and a very compressed one at that. What's making it look bad is the TV's deinterlacing the signal to 480p, as you said in a different thread. I need to know if it's possible for a CRT HDTV to display in 480i, and if so how can I get it to do that.
Reply Direct View (single tube) CRT Displays
