gotta ask again, good stand for xbr960n? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 9 Old 08-17-2006, 10:49 AM - Thread Starter
irhxcbcziuzxs's Avatar
Preferably something glass and modern looking, i cant STAND the look of the stand made for it...
any input awesome
getting my tv back from the shop tomarrow =D
irhxcbcziuzxs is offline
post #2 of 9 Old 08-18-2006, 09:26 AM
Istari1's Avatar
I had the same problem buddy. I really dont see spending $200+ on a stand made of plastic and glass. Glass shelves = a PITA to keep clean (unless you live in a dust free clean room). I went to every furniture store and electronics store in my area. If something looked nice, it usually could not hold the weight of this beast. I finally went to IKEA and they have a newer line of furniture called "Markor" (2 dots over the "o"). They make 2 TV stands/entertainment center type things that are 100% solid wood and come in a dark black/brown stain (which I bought) or a lighter brown "antique" stain. Both will hold 220lbs on top. I went for the one with the 2 glass inset doors and open center, adjustable shelves. This thing has enough room for all your AV stuff, DVD, CD's....etc. I even got the matching coffee table so my living room hasne ever looked better. They have bookshelves, diner tables, etc all in this style if you want to go with something you could match up later.
EDIT: well maybe I should have read your post better first, seems you want something modern. This is a bit more old fashion, but check it out anyway.
Istari1 is offline
post #3 of 9 Old 08-19-2006, 11:50 AM - Thread Starter
thanks for your suggestions guys, unforutnatley when i made the post, i had to go out that night and get one... i ended up getting
http://www.circuitcity.com/ssm/Z-Lin...oductDetail.do
which holds 250, and i just love it...
thanks again though
post #4 of 9 Old 05-21-2007, 04:07 PM
gamegod2x's Avatar
any more ideas for a xbr960 34" tv?
gamegod2x is offline
post #5 of 9 Old 05-21-2007, 05:30 PM
Voyeur's Avatar
This is the one I bought for my XBR970. Now normally (a) I wouldn't have gotten something glass and (b) I would never have spent that kind of money...
...but (a) it was the only one at the store I knew could hold up to 260 lbs and (b) I'm lazy and made the store deliver it along with the TV. Meh, I got them to drop the price on the TV $200 so I thought I could spend a little more on the stand:
http://www.sears.com/sr/javasr/produ...cemldffidfki.0
Voyeur is offline
post #6 of 9 Old 05-22-2007, 05:21 AM
wrwine3's Avatar
wrwine3 is offline
post #7 of 9 Old 05-22-2007, 05:50 AM
gamegod2x's Avatar
What do you guys think about this stand?
Bush TV Stand at Best Buy
post #8 of 9 Old 05-22-2007, 06:39 AM
gamegod2x's Avatar
btw, anyone know if i can use "sliders" with this stand?
post #9 of 9 Old 05-22-2007, 08:38 AM
gamegod2x's Avatar
Originally Posted by wrwine3 View Post
BB Clearance Stand
Picture of the stand with an XBR970 on it
Click on Sony TV on Bush stand link.
i need something alittle wider. I will keep looking
Reply Direct View (single tube) CRT Displays
