looking for tv suggestions... $200-$300 - AVS Forum | Home Theater Discussions And Reviews
post #1 of 14 Old 12-27-2006, 08:24 PM - Thread Starter
wayfast's Avatar
my one year old jenson 27" is dead.... so i'm in the market for a new tv. this time i will be buying some extended warrenty.
any suggestions? looking for something at least 27". $300 max.
wayfast is offline
post #2 of 14 Old 12-27-2006, 08:47 PM
King-Reyes's Avatar
Why don't you convert yourself to a HDTV and up your money...... in 2 years that $300 will go down the drain.
King-Reyes is offline
post #3 of 14 Old 12-27-2006, 09:25 PM - Thread Starter
wayfast's Avatar
yeah but right now, 300 is really killing me, and i can't go more than that.
wayfast is offline
post #4 of 14 Old 12-27-2006, 09:36 PM
King-Reyes's Avatar
SAVE... trust me it will give you a lot more. Try Samsung 27" 4:3 HDTV.
post #5 of 14 Old 12-28-2006, 08:25 PM
justsc's Avatar
You don't need to get an HD set to get a good picture and a digital tuner.
Both Sony and Samsung offer digital SD sets at 27". Both are $399, the lowest prices available.
Sony KD-27FS170 #399 Samsung TX-S2783 $399
I recommend the Sony.
justsc is offline
post #6 of 14 Old 12-29-2006, 08:47 AM
heyjoe's Avatar
check this thread out
http://www.avsforum.com/avs-vb/showthread.php?t=730691
I just love mine its great
heyjoe is offline
post #7 of 14 Old 12-29-2006, 11:37 AM - Thread Starter
wayfast's Avatar
yeah i actually saw that thread, but was a lil worried about buying a re-newed tv
wayfast is offline
post #8 of 14 Old 12-30-2006, 10:03 AM
heyjoe's Avatar
Ya! Me thinks for just under $200, the 3 months full coverage that it comes with is good. I probably could get an extended warranty if i wanted to spend the extra money. I dont see any reason for that expenditure, as this set looks great and the warranty would prabably be almost as much as the cost of the set.
Remember this is the philips 27 inch flat tube tv 27PT9015D/37B with free delivery, sdtv, with both tuners for under $200. GL in your search HTH
heyjoe is offline
post #9 of 14 Old 12-30-2006, 04:04 PM - Thread Starter
wayfast's Avatar
yeah, but after reading reviews for it and almost everyone dying after 10-13 months, i think ill pass...
wayfast is offline
post #10 of 14 Old 12-31-2006, 05:35 AM
heyjoe's Avatar
ohh ohh did i miss something! were did you find these reviews that say the tv is dying after 10-13 months! thanks for any links you can provide
heyjoe is offline
post #11 of 14 Old 12-31-2006, 03:35 PM - Thread Starter
wayfast's Avatar
i can't post links till i have 5 post so....
wayfast is offline
post #12 of 14 Old 12-31-2006, 03:35 PM - Thread Starter
wayfast's Avatar
wayfast is offline
post #13 of 14 Old 12-31-2006, 04:41 PM
King-Reyes's Avatar
Thats a waste of money. Who the hell spends more than $300 on a SD CRT. You can get a cheap used HD which is way better than that on ebay or craigslist.
post #14 of 14 Old 01-01-2007, 11:03 AM
InYourEyes's Avatar
$300 is way too much. You can pick up an Orion TVD2710 27" SDTV CRT right now at Wal-Mart for $150. It works pretty much like a Toshiba (also made by Orion) but in a different brand. And I have one right now.
For more info on this TV, go to http://forums.slickdeals.net/showthread.php?t=368652
InYourEyes is offline
Reply Direct View (single tube) CRT Displays
