Sansui HDTV2600 - $300 - AVS Forum | Home Theater Discussions And Reviews
post #1 of 10 Old 01-22-2007, 11:23 PM - Thread Starter
Crakaveli's Avatar
Crakaveli is offline
post #2 of 10 Old 01-23-2007, 01:30 AM
infinitespecter's Avatar
No form of digital input is an automatic disqualification, imho.
infinitespecter is offline
post #3 of 10 Old 01-23-2007, 02:02 AM - Thread Starter
Crakaveli's Avatar
can you explain?
post #4 of 10 Old 01-23-2007, 12:54 PM
InYourEyes's Avatar
Originally Posted by Crakaveli View Post
worth it?
http://www.electronicexpress.com/product?prod_id=8306
This TV is identical to Toshiba 26HF66 but with no HDMI input. Both the Sansui and Toshiba are made by Orion. If you don't need HDMI input, then it may be worth it, especially when you are getting Toshiba-like quality at a lower cost.
InYourEyes is offline
post #5 of 10 Old 01-23-2007, 02:15 PM - Thread Starter
Crakaveli's Avatar
it still be good for playing a ps3 or 360 on wouldn't it?
post #6 of 10 Old 01-23-2007, 02:27 PM - Thread Starter
Crakaveli's Avatar
there's one available about an hour away. it's a display model.
post #7 of 10 Old 01-23-2007, 04:43 PM - Thread Starter
Crakaveli's Avatar
why would I need digital input?
post #8 of 10 Old 01-23-2007, 04:57 PM
like.no.other.'s Avatar
It's not good to play PlayStation 3 or Xbox 360 since it's 480i. It's good to play
Wii, PlayStation, PlayStation 2, DreamCast, Xbox, GameCube, etc. Get a good
HDTV if you want picture benefit out of HD gaming. I would suggest a HD CRT
from Samsung defaulting to your budget. 30" HDTV 16:9 is your best bet. If
you can go a full $800, get a Sony KD-34XBR970 or KD-34XBR960.
There is always someone out there that gives you opinion of a product that they don't even own.
like.no.other. is offline
post #9 of 10 Old 01-23-2007, 05:37 PM - Thread Starter
Crakaveli's Avatar
i thought it could work with 720p. oh well
post #10 of 10 Old 01-23-2007, 08:40 PM
InYourEyes's Avatar
It's decent, and the max resolution you can get is 480p on component video.
Reply Direct View (single tube) CRT Displays
