Scratch removal? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 02-09-2007, 05:57 AM - Thread Starter
Vegeta's Avatar
Quoted: 25 Post(s)
There is a scratch on my bedroom Sony TV thats about 3cm long. What product would you recommend to remove the scratch and would removing the scratch cause any problems such as causing a permanent mark on the glass, a bright spot or removing the anti-glare coating or would the scratch disappear like magic? The scratch doesn't seem deep, looks to be on the surface otherwise I'd call it a crack.
The TV is a Sony 21" KV-21LS30U. I don't even think the TV has anti-glare coating but its 4 years old.
Vegeta is offline
post #2 of 3 Old 02-09-2007, 10:12 PM
SkateZilla's Avatar
Lens Doctor or Clear Hard Deodorant...
Skate Zilla
Skate Zilla HD Studios - VA Beach, VA
SkateZilla is offline
post #3 of 3 Old 05-10-2007, 12:48 PM
rfin16's Avatar
I have an indentical problem. Did you find any solution? Thank you for your advice
rfin16 is offline
Reply Direct View (single tube) CRT Displays
