Sony 34XBR970 Black and White only with component video - AVS Forum | Home Theater Discussions And Reviews
post #1 of 6 Old 04-01-2007, 03:26 PM - Thread Starter
wjalex4's Avatar
Just got my new Sony KD-34XBR970 connected. When I connect DVD to the TV using the 3-component video connection, I get black and white only. Even the DVD menus are black and white (not just the actual video playing). Tried both inputs that have component video... verified cables (R, G & B) connected to proper ports on both ends. Tried two different DVD players, went and bought a new Phillips component video cable... still no luck. Any ideas what I could be doing wrong? Thanks a lot! DVD players are both RCA DRD-232N models. I don't have another TV with component connectors, so I can't test until I carry the player to work tomorrow (I think our TV there has component ports). Thanks a lot!
wjalex4 is offline
post #2 of 6 Old 04-01-2007, 05:31 PM
RWetmore's Avatar
Quoted: 360 Post(s)
Liked: 198
Weird. No ideas.
RWetmore is offline
post #3 of 6 Old 04-01-2007, 08:49 PM
G-Bull's Avatar
There may be a setting within the DVD player's setup menus where you can specify that you're using component cables...
G-Bull is offline
post #4 of 6 Old 04-02-2007, 09:59 AM
daschrier's Avatar
Make sure the DVD player is set to y/y-r/y-b not RGB.
daschrier is offline
post #5 of 6 Old 04-02-2007, 01:56 PM - Thread Starter
wjalex4's Avatar
Brought one of my RCA DRC232N DVD players to work, tried it on a component-video TV here... same thing (just black and white).
According to the clearplay web site, here is the fix:
- STOP the DVD Player
- Press and Hold the PREV/Video button for 3 seconds
- Extra menu text will appear
- Press the PREV/Video button again to cycle through 3 different video modes
(S-Video, Component Video and Progressive Scan)
The reason I was getting black and white (as opposed to nothing at all), is that the composite Yellow output is ALWAYS active.
Both of my DVD players are this same model.
I'll try this when I get home tonight... I am optimistic this is the fix.
wjalex4 is offline
post #6 of 6 Old 04-03-2007, 09:04 AM - Thread Starter
wjalex4's Avatar
Got home last night and hooked up my RCA DRC232N DVD player to the 34XBR970 using component video. All is good.. the problem WAS the DVD player after all.
Thanks for the posts!
wjalex4 is offline
Reply Direct View (single tube) CRT Displays
