Can i Transport a TV on it's side or back over long distance? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 8 Old 04-30-2007, 11:49 AM - Thread Starter
ducati998ss's Avatar
My parents gave me there 32" Sony Trinitron XBR to take home with me on a trip. Now the tv is attaced to a base that has a sub woofer. I own a Subaru Outback and need to travelfrom Washington to So. California. Would the the TV be safe enough if i lay it on its side or back and secure it with pillows and blankets? Or is there a way to remove the base so i can just set it upright. the model # for the TV is Sony KV-32XBR85 if that helps. If you know how to remove the base please let me know, from what i can see there is no screws to take the base off.
ducati998ss is offline
post #2 of 8 Old 04-30-2007, 12:08 PM
cavu's Avatar
I'm sure the base will come off somehow but I have always found it best to transport TVs face-down on appropriate blankets. The face of the picture tube is the heaviest and strongest part.
"The greatest obstacle to discovery is not ignorance  it is the illusion of knowledge." - Daniel Boorstin
"Our lives begin to end the day we become silent about things that matter.
" - MLK
cavu is offline
post #3 of 8 Old 04-30-2007, 12:11 PM - Thread Starter
Ok so it woud be safe and fine if i transport it on its tube. Right now its in the car on its Tube, but i keep hearing from people that its not safe to transport the tv that way and to put it on its back. I found the TV and Stand are a single unit. It wont mess up the TV now if its on its rested on it tube for a long time?
post #4 of 8 Old 04-30-2007, 12:26 PM
InYourEyes's Avatar
It's always best to put the tube facing front of the car seat with the tube touching the seats. Putting the tube face down may cause the buttons at the front of the TV to be pushed in a little. You don't want that.
InYourEyes is offline
post #5 of 8 Old 04-30-2007, 12:29 PM - Thread Starter
The buttons are located on the top of the TV. Unfortunately because of its height it can only being placed in the car laying down. Ok beside the buttons, is it still okay to transport it tube face down?
post #6 of 8 Old 04-30-2007, 12:34 PM
cavu's Avatar
I've been transporting TVs for 42 years. That's the best way. Just make sure that whatever you lay the face on is soft and has no grit/garbage in it which can scratch the glass and that the TV itself cannot slide around! Seat belts or straps can be used.
" - MLK
cavu is offline
post #7 of 8 Old 04-30-2007, 12:45 PM - Thread Starter
im laying the tv on an air mattress with a blanket on top of it. Thank you all for your help. You have saved me from having a very big head ache.
post #8 of 8 Old 04-30-2007, 12:51 PM
cavu's Avatar
Perhaps put a thick, soft bath towel between the air mattress and the TV glass.
" - MLK
cavu is offline
Reply Direct View (single tube) CRT Displays
