can someone tell me if this sony tv is native? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 6 Old 07-04-2007, 07:22 PM - Thread Starter
poonman's Avatar
the model number is KV-40XBR700 and also what picture mode should it be on when im playing xbox 360?
poonman is offline
post #2 of 6 Old 07-04-2007, 08:02 PM
RWetmore's Avatar
Quoted: 393 Post(s)
Liked: 210
What do you mean by "native?"
RWetmore is offline
post #3 of 6 Old 07-04-2007, 08:09 PM - Thread Starter
poonman's Avatar
sorry i meant to say 1080i native
poonman is offline
post #4 of 6 Old 07-04-2007, 08:11 PM
RWetmore's Avatar
Quoted: 393 Post(s)
Liked: 210
I think so, yes.
RWetmore is offline
post #5 of 6 Old 07-05-2007, 02:11 PM
theroys88's Avatar
Quoted: 172 Post(s)
Liked: 59
That model is can display 1080i. It will take a 720p signal and upconvert it to 1080i. You can set your XBOX to 1080i or 720p. You might want to select each one to see if your XBOX upconverts better then the 700.
theroys88 is offline
post #6 of 6 Old 07-05-2007, 03:07 PM
fugiot's Avatar
It probably does. Use 1080i.
Sony XBR960n - nice to rods, mean to cones.
fugiot is offline
Reply Direct View (single tube) CRT Displays
