Help, my Sony KD-34XS955 died - AVS Forum | Home Theater Discussions And Reviews
post #1 of 17 Old 11-08-2007, 07:05 PM - Thread Starter
avhed's Avatar
I just turned it on and all that happened was the red standby LED did its usual flashing and set made the usual turn on sound but the screen remains blank.
Maybe my heater I installed two feet away did not help it any. The heater has only been on the last few days. Any advice will be appreciated.
avhed is offline
post #2 of 17 Old 11-08-2007, 07:57 PM
au revoir's Avatar
Just the usual advice. Leave unplugged overnight with all audio and video inputs and coaxial cables detached. Then try turning it on again in the morning. Maybe say some nice things to it as well.
au revoir is offline
post #3 of 17 Old 11-09-2007, 05:52 AM
raouliii's Avatar
How many flashes?
Those who would give up essential liberty to purchase a little temporary safety, deserve neither liberty nor safety. - Benjamin Franklin
raouliii is offline
post #4 of 17 Old 11-09-2007, 12:43 PM - Thread Starter
avhed's Avatar
Twenty flashes.
Looks like I need to get someone on the other end to lift it to the repair shop.
I was hoping never to have to lift this beast. I bought it 2.5 years old, half a year ago. I have had it only 200 days and my warranty was 90 days. TVs are no where as reliable as I am used to.
I am reminded how good this set is though when I watched my Panasonic CT30WX15 last night, for the first time since getting the Sony SPF.
avhed is offline
post #5 of 17 Old 11-11-2007, 03:58 PM
Mark Goetz's Avatar
Originally Posted by avhed View Post
Twenty flashes.
You sure it is 20? Make sure by letting the normal turn on procedure, then count flashes.
Mark Goetz is offline
post #6 of 17 Old 11-13-2007, 01:24 PM
gopher2k's Avatar
sounds similar to what happened to my 36xs955. Turned out to be the psu...
gopher2k is offline
post #7 of 17 Old 11-27-2007, 04:56 PM
SithLord's Avatar
This has happened to me 2 or 3 times since I bought the set a couple years ago. I have it plugged into a power bar/surge protector. To remedy, all I did was unplug it from the power bar and plug it directly into a wall outlet. The set should power back on fine. Turn it off, plug it back into the power bar. This seems to do the trick for me.
SithLord is offline
post #8 of 17 Old 11-27-2007, 05:21 PM - Thread Starter
avhed's Avatar
You are more like a Jedi Master to me my friend. And a fellow Canadian at other Canadian Naval Base City.
You have made my week. After not having use of the set for a few weeks, I was just about to line someone up to help load the set to the repair shop. That would of been a pain and minimum shop charge on top.
I neglected to cancel my Zip Blu-Ray service. So now I can watch those two and the dozen new titles I bought. I will be toasting you when enjoying those fabulous Blu-Ray .
I realise now that I erred by ignoring the labels on the Monster Power HTS1000 Power Bar. I had it in Tape, and I am quessing that outlet is only meant to support the draw of a Tape of similar device and not the big surge for a CRT powers on. (I know its even big after turn on compared to a Tape player. Normally I am careful about this stuff, but I really messed that one up.
Before I had the problem, I was plugging and unplugging the set to degauss. I wonder if this set it off?
avhed is offline
post #9 of 17 Old 11-27-2007, 10:31 PM
PimpUigi's Avatar
So it works now and is OK?
PimpUigi is offline
post #10 of 17 Old 11-30-2007, 01:31 PM
SithLord's Avatar
Great, glad it worked out!
Can't say it won't happen again, but at least you know you won't have to break your back lugging it to a shop.
Enjoy that Blu-ray, this set is absolutely amazing and this is the only annoyance I have had with it. Seems ok now, haven't had that issue for a long time.
Cheers!
SithLord is offline
post #11 of 17 Old 07-18-2008, 10:19 PM
kannansid's Avatar
Did this issue happen again? I am considering purchasing this TV from a local person and he said he seen this issue about 3-4 times a year. Is this normal?
Should I buy this TV with this issue or look out for something else.
Is this issue gonna manifest later as the classical D-Board issue mention in this forum.
Thanks for your advice.
kannansid is offline
post #12 of 17 Old 07-20-2008, 12:14 AM - Thread Starter
avhed's Avatar
Read the above, A power bar problem, not TV.
avhed is offline
post #13 of 17 Old 07-20-2008, 02:53 AM
kannansid's Avatar
So in your case, you plugged-in the TV in the incorrect slot. Once you fixed that, the problem never occurred after that. Is that right.
I am not sure if that is case with the person that has this. He is willing it let it go for 200$. Should I buy? Decisions? Advices?
post #14 of 17 Old 07-04-2010, 01:37 PM
kippercal's Avatar
My Sony Wega wont turn on - 6 red flashes - any advice?
kippercal is offline
post #15 of 17 Old 03-18-2011, 10:18 PM
sleepykidX's Avatar
Hi guys, my TV also has the same problem. After pressing the power button , no image shows up on my TV. The red led blinks several times and then nothing happens. I will try this unplug trick however. Any advice would be good
sleepykidX is offline
post #16 of 17 Old 04-02-2011, 10:38 PM
music_to_my_ear's Avatar
Quoted: 185 Post(s)
Liked: 90
34XS955 vs 34XBR800 vs 34HS510
If you could choose anyone, which set is better and why?
More importantly, the 34XBR800 vs 34HS510? Read that the HS510 is an older version of the xbr800, both are identically equipped, just one was released before the other set and had more expensive parts due to its early release.
music_to_my_ear is offline
post #17 of 17 Old 04-02-2011, 10:46 PM - Thread Starter
avhed's Avatar
Firstly, I do not know what the above post has to do with this thread, other than being Sony CRT Widescreen.
34XBR800 was started around 2002
34HS510 was started around 2003, when the 34XBR910 was out
avhed is offline
Reply Direct View (single tube) CRT Displays
