Loewe Aconda Owners - Page 2 - AVS Forum | Home Theater Discussions And Reviews
post #31 of 97 Old 06-10-2008, 11:32 PM
miata's Avatar
Quoted: 65 Post(s)
Originally Posted by forkeye View Post
Someone mentioned the VGA port earlier-- here's directions on how to make your own component video->VGA cable:
http://myhometheater.homestead.com/vgacable.html
I'm going to try it out next weekend. By all accounts it should give my Aventos two separate 1080i inputs without buying a switchbox.
Component video switches are going for awful cheap on ebay though.
I love the set. I'm going to ride it until it konks out. I hope it lasts a long time.
Great info. Switches may be getting cheaper, but they add another potential point of failure and force you to use the same calibration settings for all inputs. It is nice to be able to have at least two settings in case you have different source needs.
miata is offline
post #32 of 97 Old 06-11-2008, 06:41 AM
Ratman's Avatar
Quoted: 1487 Post(s)
Liked: 1191
Take careful note of this statement, "This cable is used to connect a component video source ... to a projector, RPTV, LCD or Plasma that accepts componet video via an HD-15 port. In some models, you will have to set this input to "component" via the menu system, others will auto-sense the input."
Does the Aconda's (or Aventos) VGA input have a 'selectable' option between VGA and component (YPbPr)? If not... then this cable won't work properly. You will need to purchase a transcoder.
An example:
http://www.datapro.net/products/vdig...nt-to-vga.html
If you can’t explain it simply, you don’t understand it well enough – Albert Einstein
Ratman is offline
post #33 of 97 Old 06-16-2008, 10:49 PM
forkeye's Avatar
blast, the simple cable does not work. Just a bunch of green squiggles. Apparently the Aventos does need some kind of sync signal on the vga input
forkeye is offline
post #34 of 97 Old 06-17-2008, 12:17 PM
MrGonk's Avatar
owned a loewe aconda 38" for several years and adored it -- there's no other picture quite like it. warm, lush, natural, vivid colors, flawless contrast, incredibly natural and pleasing imagery. still haven't seen anything like it since. then, one day, out of the blue, only weeks after the warranty was out, it went *zzzzzzt* on me and never worked again. loewe's american operation had already closed, and i couldn't find anyone anywhere who could service the thing. a new motherboard w/ voltage regulators would have cost $800 anyway. i went out and bought a floor model 34xbr960 for $700 bucks, and had it ISFed for another $265. it still doesn't have that "it" quality that the aconda always had, but it's decidedly more detailed, and has got to be the most precise HD picture i've ever seen.
"There's a... big machine in the sky... Some sort of... electric snake. It's headed right for us..."
"Shoot it."
"Not yet. I want to study its habits."
MrGonk is offline
post #35 of 97 Old 06-17-2008, 04:42 PM
CHASLX200's Avatar
I just had my 38" Aconda fixed under warranty. It had it's board replaced, this was back in JAN of this year.
So far it works like a dream.
CHASLX200 is offline
post #36 of 97 Old 07-22-2008, 07:48 AM
kidkoala's Avatar
Aconda 30" owner here. Is the Aconda really 1080i? I have a Samsung 1080p DLP now, and the resolution is so much higher than the Loewe that it makes me wonder. I hooked up PS3 bluray to it and the resolution is definitely less (from what I can see) than a HD-DVD player on my Samsung.
I agree though, the Loewe was a great for it's time. There's an "it factor" to it, and I still miss the image quality. Wish Loewe was still in the States.
kidkoala is offline
post #37 of 97 Old 07-22-2008, 10:27 AM
fugiot's Avatar
Like all HD CRTs, the Aconda does not have full horizontal resolution. It's most likely around 900x1080. The highest resolution CRTs were the Sony SFPs with 1440x1080.
Sony XBR960n - nice to rods, mean to cones.
fugiot is offline
post #38 of 97 Old 08-28-2008, 10:56 AM
Dave Long's Avatar
There is NO Sony CRT that is more detailed than a Loewe. I've owned and sold both. Any Loewe owner will agree. If you saw one with a dull picture, I'll bet the user put the connected DVD on progressive scan. You don't do that with Loewe's. You let the Loewe do the work.
I'm also the Loewe expert for Canada and I didn't go there because there were better sets! I run my PS3 at 1080i into the VGA input as well as HD satellite and people cannot believe the PQ.
Dave Long is offline
post #39 of 97 Old 08-28-2008, 03:10 PM
CHASLX200's Avatar
I agree nothing can touch my 38" Loewe Aconda when it comes to blacks and just eye popping colors!
But the Loewes can't do 1080P.
post #40 of 97 Old 09-09-2008, 09:00 AM
chammers's Avatar
Any chance anyone out there has the IR codes for their Loewe? I am trying to set up an automated system with one. Thanks for the help in advance.
chammers is offline
post #41 of 97 Old 09-10-2008, 11:42 AM
Oldfart's Avatar
I believe that Loewe used the same IR codes as Goldstar, so you might try the LG codes.
Alan
Oldfart is offline
post #42 of 97 Old 09-24-2008, 08:38 AM
beagan's Avatar
I purchased an Aconda 38 about four years ago and love it. However, about six months ago I had to access something in the back of my entertainment center and had to remove the Monster component inputs on the Loewe. Those damn Monster cable connectors were so darn tight that it pulled the whole component jack out. Now my HD input is useless. I was able to find one person that might look at it for about $100 and can't guarantee a fix. Plus, this thing is way too heavy to bring anywhere. I've since been using S-Video for my HD channels and am not pleased with the downgrade. I discovered the VGA input and ordered a VGA-to-Component cable that can hookup with my Samsung DirecTV HD box. Sadly, I'm only getting the squiggly green lines that a previous poster mentioned. Others have stated they're using this VGA input for their PS3. What can I do to get this to work? Please help!! Thank you!!
beagan is offline
post #43 of 97 Old 10-04-2008, 07:55 PM
ptrivelas's Avatar
This is a new question. I thought this may be a good thread to join because of all the Aconda lovers here. Am I too late?
Suddenly, right after I moved to a new apartment, my 30" Aconda has developed a problem.
In the middle of the screen is a big black square which obscures almost all of the video. I can see image only around the edges of this black block. The audio is fine.
My best guess is that I inadvertently changed a setting, but I can not figure out what that might be.
Any clues?
I have not had any problems at all with this television since I bought it many years ago, but now this.
Thank you.
ptrivelas is offline
post #44 of 97 Old 10-04-2008, 09:14 PM
Symbios's Avatar
Interesting... Perhaps you turned teletext on?
Symbios is offline
post #45 of 97 Old 10-04-2008, 09:20 PM
ptrivelas's Avatar
Thanks for replying.
I don't see any setting for teletext or for closed captioning. Would that function be called something else?
post #46 of 97 Old 10-04-2008, 09:25 PM
ptrivelas's Avatar
I FOUND IT!
It was the closed caption function. Thank you for your help. Case closed.
post #47 of 97 Old 10-04-2008, 09:26 PM
Symbios's Avatar
Heh, glad I could help.
Symbios is offline
post #48 of 97 Old 10-16-2008, 05:16 AM
brandbos's Avatar
Would anyone know how to change the input without the loewe remote. My remote broke and somehow the input switched and now reads no signal. Is there a reset button or something I can do?
brandbos is offline
post #49 of 97 Old 10-16-2008, 07:24 AM
Oldfart's Avatar
Try unplugging it for 15 seconds. It should reset.
Alan
Oldfart is offline
post #50 of 97 Old 10-18-2008, 06:38 PM
Maria Geisler's Avatar
I have the Loewes Anaconda TV and I think its one of the greatests TV's. Other than it being difficult to move since its extremely heavy, it is such a great set. We have had the TV for about 4 years now. All of a sudden the TV remote broke. I programmed my Comcast remote to the Loewes TV but I can only get the volume and channels change. I need to change the individual inputs. Does anyone know how I can get the inputs to change or be able to use the menu options?
Maria Geisler is offline
post #51 of 97 Old 10-18-2008, 06:42 PM
miata's Avatar
Quoted: 65 Post(s)
The best thing to do would be to get one of the Harmony remotes. Their database has codes for all of the buttons. You will also be able to access discrete on/off and inputs -- not more toggling through inputs.
miata is offline
post #52 of 97 Old 10-28-2008, 07:15 PM
bighickey's Avatar
As I have read, my Aconda has finally had the power failure issue many of you have spoken of. I hit the main power button on the front, the green light comes on and it makes a sound like it's powering up, and then it goes back to red. Is this a part you can order and fix yourself or am I just SOL? I really love the TV, and I'm not ready to part with a $4000 TV after 6 years. I'm in the Dallas/Fort Worth area of Texas. Any assitance is grealty appreciated.
bighickey is offline
post #53 of 97 Old 10-28-2008, 07:51 PM
miata's Avatar
Quoted: 65 Post(s)
Flyback transformer. Mine went out out after 4 years and cost $400 to get fixed by Magnolia. You might try a Magnolia in the area.
miata is offline
post #54 of 97 Old 11-02-2008, 10:33 PM
edgarpoe's Avatar
With technology advancing there must be better sets, flat panels, etc, out there. Any ideas. My Aconda is fuzzy on the far left and right sides for about 4 inches in from the side any way to fix.
California, USA
edgarpoe is offline
post #55 of 97 Old 11-11-2008, 01:24 PM
Nalod's Avatar
Quoted: 18 Post(s)
Check on E-bay, they often have the remote you need. I bought one a few years ago. I check from time to time, and they appear.
Nalod is offline
post #56 of 97 Old 11-30-2008, 03:41 AM
Moro28's Avatar
plz i need ur help guys i had my aconda about 4 years ago and now my tv turning to pink or magenta hole screen on and off only on the free to air not on any av like dvd video or sat so plz if someone had z same prob let me know.
Moro28 is offline
post #57 of 97 Old 12-22-2008, 12:53 PM
TxDuke's Avatar
Is this a dead thread? I have a Loewe Aconda 38" Wide screen am going to have to part with. This is truly one of the best tvs I've owned. Any one know what they are going for?
TxDuke is offline
post #58 of 97 Old 12-22-2008, 01:59 PM
miata's Avatar
Quoted: 65 Post(s)
Of course, Loewe stopped marketing these in the US, so Ebay is the primary
avenue in the US.
miata is offline
post #59 of 97 Old 01-06-2009, 03:07 AM
Moro28's Avatar
Moro28 is offline
post #60 of 97 Old 01-11-2009, 01:15 PM
TLacefield's Avatar
Quick question regarding a Loewe Aconda purchased in 2001. Hub seems to recall that it claimed to be digital ready. True? So I don't need to get a converter box for next month?
TLacefield is offline
Reply Direct View (single tube) CRT Displays
