Reset lamp hours on Sanyo Z2000 ? - AVS Forum
post #1 of 3 Old 07-27-2008, 10:04 PM - Thread Starter
taubenspikes's Avatar
hi all,
i have to reset the lamp hours from my sanyo z2000, how can i do this ?
regards
taubenspikes
taubenspikes is offline
post #2 of 3 Old 07-27-2008, 10:33 PM
Sheridan1952's Avatar
That procedure is covered in your manual and is accessed through the projector menu. The reset is under the Settings selection of the menu.
And if you don't have the manual, it can be d/l from the manufacturers website.
http://sanyoservice.com/pdf/images/PLVZ2000.PDF
Sheridan1952 is offline
post #3 of 3 Old 07-27-2008, 11:11 PM - Thread Starter
thank you very much
User Tag List
