upside down projector image - AVS Forum | Home Theater Discussions And Reviews
post #1 of 13 Old 08-11-2008, 05:50 PM - Thread Starter
pdean's Avatar
I just ceiling mounted a new Panasonic PT-AE2000U projector. The image is upside down. How can I fix this? Manual describes installation procedure for setting projection method. (front/desk, front/ceiling, etc) I don't know if this would change anything, but I don't know how to accesss this control. I am mounting in the front/ceiling mode. Would appreciate any advice. thx
pdean is offline
post #2 of 13 Old 08-11-2008, 06:48 PM
mjg100's Avatar
I do not have this projector, but most if not all projector are set up so that you select the setting that you want. You want to set it for front ceiling. Go to where it shows projector method in the menu and press the right or left arrow button on the remote control. It will cycle through each of the choices. Once you have front ceiling showing press enter.
mjg100 is offline
post #3 of 13 Old 08-11-2008, 07:23 PM
Sheridan1952's Avatar
Those ARE the settings for changing the image orientation. They are accessed through the projector menu. I don't have that projector, but the manual will tell you how to get to those settings. Select Front/Ceiling.
Sheridan1952 is offline
post #4 of 13 Old 08-12-2008, 02:39 AM - Thread Starter
pdean's Avatar
It works fine. thanks much
pdean is offline
post #5 of 13 Old 08-12-2008, 02:40 AM - Thread Starter
pdean's Avatar
Thanks for quick fix, everything seems to be working now
pdean is offline
post #6 of 13 Old 08-12-2008, 09:37 AM
TF Ghost's Avatar
I disagree. Clearly pdean needs to flip his screen upside down so the image will be right-side up.
TF Ghost is offline
post #7 of 13 Old 08-12-2008, 09:43 AM
ionyou's Avatar
Uh.....are you nuts? Why would you do that when you can simply turn the whole house upside down instead?
ionyou is offline
post #8 of 13 Old 08-12-2008, 09:47 AM
victor-eyd's Avatar
I'd simplify things and move to Australia
Free cake! Free cake!
- Mordecai and Rigby
Big Screen/Small Space! My 13x12 Bedroom HT
Think small, project big!
Small theaters gallery
victor-eyd is offline
post #9 of 13 Old 08-12-2008, 11:06 AM
Lukom's Avatar
clearly there is an easier solution. simply flip your eyes upside down
Lukom is offline
post #10 of 13 Old 08-12-2008, 11:06 AM
bud16415's Avatar
Quoted: 784 Post(s)
Liked: 277
Flipping the screen wont work because the image will then be switched right to left. Turning the house over will work but do you have any idea how much something like that will cost. Moving to Australia is the best solution so far but all that Blokes and Shelia and G'day stuff would get to me.
Everyone has missed the easy solution and what many have done and that is to simply bolt the couch to the ceiling and install seatbelts.
Bud
bud16415 is online now
post #11 of 13 Old 08-12-2008, 11:30 AM
TF Ghost's Avatar
Right, but how would you get up there? And what about when you want to eat and drink? I can think of some solutions but none of them seem easy...
TF Ghost is offline
post #12 of 13 Old 08-12-2008, 12:09 PM
Of course, I completely overlooked the obvious solution. Thanks.
post #13 of 13 Old 08-12-2008, 12:16 PM
goldy001us's Avatar
goldy001us is offline
