Panasonic PT-AE3000 info and video here - Page 46 - AVS Forum | Home Theater Discussions And Reviews
 6Likes
post #1351 of 1358 Old 01-14-2011, 07:36 PM
m. zillch's Avatar
Quoted: 1958 Post(s)
Liked: 1247
Originally Posted by epayne11 View Post
Do you think maybe I have to tilt the projector mount down a little??
No, not tilt. You need to mount it lower on an extension pole. It looks to me as if you are having to project downward at an angle. That's a no no. In order for the auto zoom feature to work the center of the lens can be no higher than the top edge of the screen. [People who don't use that feature can indeed project from higher hence the manual's implication that it is OK to mount it up higher than that.] That is my understanding at least.
[Edited from previous version]
In A/V reproduction accuracy, there IS no concept of "accounting for personal taste/preference". As art consumers we don't "pick" the level of bass, nor the tint/brightness of a scene's sky, any more than we pick the ending of a novel or Mona Lisa's type of smile. "High fidelity" means "high truthfulness", faithful to the original artist's intent: an unmodified, neutral, accurate copy of the original master, ideally being exact and with no discernable alterations, aka "transparency".
m. zillch is offline
post #1352 of 1358 Old 01-14-2011, 08:26 PM
erkq's Avatar
Quoted: 658 Post(s)
Liked: 462
Originally Posted by m. zillch View Post
No, not tilt.
You'll also get keystoning if you "tilt" it.
erkq is offline
post #1353 of 1358 Old 01-15-2011, 08:01 AM
epayne11's Avatar
I don't think I could possibly move it down any further, you almost hit your head on it as it is now. Maybe I could go down a half inch or something, but I wouldn't be able to lower it enough to have the lens right at the top of the screen. Too me the picture looks great and I don't notice any issues with it, it is just the one button to switch back and forth. So I am stuck with manually shifting then?
epayne11 is offline
post #1354 of 1358 Old 01-15-2011, 11:32 AM
Philnick's Avatar
Quoted: 245 Post(s)
Liked: 110
To invert the old line that "If you can't raise the bridge, lower the river!":
How about moving the screen up to meet the projector?
Philnick is offline
post #1355 of 1358 Old 01-15-2011, 04:18 PM
epayne11's Avatar
With the top of the stage the way it is no I can't, i need room to put the screen on the wall and snap it down into the track.
So I can't tilt the mount down and then shift the lens up??
epayne11 is offline
post #1356 of 1358 Old 01-15-2011, 04:34 PM
kriktsemaj99's Avatar
Quoted: 653 Post(s)
Liked: 377
I don't think I could possibly move it down any further, you almost hit your head on it as it is now...
If you tilt the projector the image won't be a perfect rectangle, so it won't fit the screen exactly (even if you use lens shift). But if you mount the projector directly over a seat, there's no way you can walk into it even if it's mounted lower. I can see how that would be a pain if it means moving it forwards or backwards from its current position, but it works for me in a basement with a low ceiling.
kriktsemaj99 is offline
post #1357 of 1358 Old 01-15-2011, 04:44 PM
epayne11's Avatar
actually the projector is mounted right over a seat right now and although you don't hit your head right now but worried if I lower it anymore you might hit it. That being said I would have to lower it about a foot if it is suppose to be in line with the top of the screen.
epayne11 is offline
post #1358 of 1358 Old 01-15-2011, 05:25 PM
Philnick's Avatar
Quoted: 245 Post(s)
Liked: 110
The shift controls are designed to do for a projector what a "rising and falling back" does for architectural photographers: enables you to keep the various elements parallel to each other and to the vertical. For a photographer, this enables a "virtual" -instead of real - tilting of the camera up to get a tall building in the image without the "keystone" distortion produced by tilting the whole camera.
If you visualize the keystone that caps an arch at top center (also called the "capstone"), it's broader at the top than it is at the bottom. That's where the term "keystone" comes from. By keeping the film and lens vertical and parallel to the building, but moving the film up and down behind the lens, the building can be brought into view without introducing that distortion, which would make the top and bottom of the building different widths, and the sides no longer parallel.
That's what both the mechanical and electronic shifts are modeled on - you keep the imaging panels parallel to the screen while moving the image up and down or side to side behind the lens, avoiding the geometric "keystone" distortion that tilting the projector would introduce.
That's why you shouldn't tilt the projector.
End of pedantry (for now).
Philnick is offline
