Marantz Vp8600 - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 09-25-2008, 08:05 PM - Thread Starter
agray105's Avatar
Is the Vp-8600's 800 Ansi lumens bright enough for my room? I have a 1.3 gain screen, with a little ambient light, just enough to read with? thanks for the help.
agray105 is offline
post #2 of 4 Old 09-25-2008, 08:12 PM
JeffKB's Avatar
Before anybody can answer that, you'll need to provide your screen size.
JeffKB is offline
post #3 of 4 Old 09-26-2008, 10:30 AM - Thread Starter
agray105's Avatar
92"
agray105 is offline
post #4 of 4 Old 09-26-2008, 03:41 PM
mjg100's Avatar
In economy mode you should have around 20 FL. on your screen. When the lamp is at half power (+ 2,000 hours) then you might need to go to normal lamp mode.
mjg100 is offline
