Official Planar PD7130 owners thread - AVS Forum | Home Theater Discussions And Reviews
 2Likes
post #1 of 1584 Old 10-02-2008, 10:28 AM - Thread Starter
two-rocks's Avatar
Mine should be here shortly...thought I'd get the official thing going I'll be installing into a dedicated HT, Phifer SheerWeave 4500 AT screen
Translated review link here
Owners manual:
http://www.planar.com/products/docs/...50-english.pdf
Firmware: (no updates listed for this model)
http://apps.planar.com/downloads/hometheater/
HDMI - DVI adapter (TBD if this is an OK solution)
http://www.avsforum.com/avs-vb/showp...4&postcount=16
Bulb and/or extended warranty - for those concerned about replacement cost:
http://tapeworkstexas.com/mack_warra...tor_combo.html
http://www.newworldvideodirect.com/p...productid=1001
Mack 1065
more...
current threads:
http://www.avsforum.com/avs-vb/showt...0#post14785480
http://www.avsforum.com/avs-vb/showthread.php?t=1071920
two-rocks is offline
post #2 of 1584 Old 10-02-2008, 10:41 AM
E-A-G-L-E-S's Avatar
Nice first post!(official )
I'm in.
Hopefully woo? doesn't take too long.
E-A-G-L-E-S is offline
post #3 of 1584 Old 10-02-2008, 10:45 AM - Thread Starter
two-rocks's Avatar
I'm in.
Thought you had a 7060?
(also fixed the spelling, guess spell check missed the title )
post #4 of 1584 Old 10-02-2008, 10:45 AM
I do.
But as of 10 minutes ago I own a 7130.
post #5 of 1584 Old 10-02-2008, 10:47 AM
dysfunction26's Avatar
I do.
Is the 7060 that good? Also, how is the brightness?
dysfunction26 is offline
post #6 of 1584 Old 10-02-2008, 10:49 AM
A little better than my Marantz VP4001 was - imo.
The 7130 should be better except a little dimmer than the 7060.
All three are fantastic for the prices.
*I need to order a male DVI to female HDMI converter or full length DVI cable.
Which is more reliable?
post #7 of 1584 Old 10-02-2008, 10:53 AM
How much better than an IN72 in your opinion, do you think I can get $400 for my used IN72 with 2 years left on the Best Buy warranty with one bulb replacement?
post #8 of 1584 Old 10-02-2008, 10:56 AM
Tough call just because I've actually never seen a IN72 in person.
But from the reviews the 7060 outclassed the IN72 and was compared favorably with the 78....so that bodes well for the 7130.
I would think you should easily be able to get $300-$500 for your IN72.
Take a quick look at what they have gone for on ebay, videogon and other sites by googling.
post #9 of 1584 Old 10-02-2008, 10:56 AM
Here's a link:
http://www.monoprice.com/products/su...02&cp_id=10231
Don't the converters/adapters put more stress on the connector?
post #10 of 1584 Old 10-02-2008, 10:58 AM
More stress on the connectors? What do you mean?
Thanks for the link.
post #11 of 1584 Old 10-02-2008, 11:05 AM
I guess it's like a torque wrench in theory. The DVI connector on the back of the projector, by adding an adapter you increase the stress put on that port, because it adds another 1" or so in length, before the cable is attached.
post #12 of 1584 Old 10-02-2008, 11:08 AM - Thread Starter
two-rocks's Avatar
I think the stress on the connector is a moot point in a fixed mount installation. No problems for my 4801 M1 - HDMI adapter.
My concern with the adapter is that the rear door might not close on the connectors with the added depth of the adapter. My conduit run to the ceiling will not handle another cable (and I even have a long DVI cable somewhere collecting dust).
post #13 of 1584 Old 10-02-2008, 11:08 AM
Oh, gotch-ya....yeah maybe a full length DVI from monoprice is the ticket.
BUT...any signal loss issues at 40' with DVI? I'm currently using a 40' HDMI with no issues and a 25' DVI with no issues.
post #14 of 1584 Old 10-02-2008, 11:15 AM
I'm not sure about that, my cables are only 35/25 feet, I run a component (Wii) and an HDMI (from audio receiver) and they both seem to work fine. I do notice banding with the 25' component, but I think that's due to the extension connectors I have to use connecting the Wii cable to the longer component cable.
post #15 of 1584 Old 10-02-2008, 11:19 AM - Thread Starter
two-rocks's Avatar
For the DVI - HDMI adapter I'm going with the items below to insure that the cable door will close and keep a clean look:
post #16 of 1584 Old 10-02-2008, 11:38 AM
bosng's Avatar
chiming in here
got mine ordered early this morning. what a deal.hoping to be pleasantly surprised.
pairing it with a 65x115 high power screen @ 13ft seating distance.
bosng is offline
post #17 of 1584 Old 10-02-2008, 11:45 AM
new media's Avatar
I alway wanted a PJ and I jumped on this woot deal , My first PJ .
I have a dedicated room with 50" plasma TV on stand now, I wanted to use this PJ for night time viewing..How would you set this up while keeping the plasma TV in same side wall?
the room is 20'X20' with windows on the right side only.
thanks
home along again!!!
new media is offline
post #18 of 1584 Old 10-02-2008, 11:50 AM - Thread Starter
two-rocks's Avatar
Block out the light from the windows and move the plasma elsewhere!
Size matters
post #19 of 1584 Old 10-02-2008, 11:51 AM
Either what he said or build a moveable screen or buy a motorized one.
My plasma had to come off the wall and onto a stand with wheels so I can cart it out of the way when needed.(extra long HDMI to allow for this)
post #20 of 1584 Old 10-02-2008, 12:06 PM
anotherhawkeye's Avatar
I pulled the trigger this morning as well. First time projector owner.
I have a really huge room in the basement and I'm going to build my own screen. What screen size should I shoot for ?
anotherhawkeye is offline
post #21 of 1584 Old 10-02-2008, 12:16 PM
Baement equals light controlled.
How far will you be sitting from screen wall?
What type of seating arrangement?(one couch, several recliners, rows?)
post #22 of 1584 Old 10-02-2008, 12:53 PM
new media's Avatar
I have one sofa 12 " away from Plasma TV, love seat 8" away from TV , table set up or ceiling mount?
Most likely set will be install wheels on Plasma TV stand...LOL
OR
buy a retractable screen which I really do not want to spend more than $100....LOL
home along again!!!
post #23 of 1584 Old 10-02-2008, 12:57 PM
Well, say 10' away from a 768p image I would stay 120" or smaller. Too big and you have to turn your head to pan the screen which leads to not so good feelings.
I'm 13' from a 110" and love it.
post #24 of 1584 Old 10-02-2008, 01:40 PM
Got it......720p/48Hz for 1080p/24Hz sources.
Two-rocks...what lens will you be using to get the 7130 to do 2.35:1?
post #25 of 1584 Old 10-02-2008, 02:09 PM
Michael F.'s Avatar
I called Planar Tech support and he said to get a DVI-D MALE to HDMI (Whatever end you need) I got one to the HDMI female.
Also, using the Right Angle turn down will direct it at the Power cord plug-in socket so I got the right angle adapter that turns left. I won't need the Component 2 inputs so I'm OK if I block them.
So everyone please double check the connector/adapters before you make your choice and purchase. (because I'm not even sure I'm right)
Mike
Michael F. is offline
post #26 of 1584 Old 10-02-2008, 02:15 PM
Are you speaking of the angled one?
The female HDMI to male DVI straight connecter seems like the right one...I ordered one.
post #27 of 1584 Old 10-02-2008, 02:18 PM
DaGamePimp's Avatar
Quoted: 360 Post(s)
Liked: 381
The best solution is to use direct cables when possible and avoid the adapters , the adapters can introduce issues (which does not mean that they will , just that they can) .
- Jason
Media Room = Vizio 4K 70" lcd/Denon x4100/Audiosource Amp 100/Klipsch speakers/Velodyne subs/Sony BDP s780/PS4 Pro/X1S/WiiU/PS3/360/Wii/Game PC/Multi-Arcade / #standwithscotty / My HT SLIDESHOW
DaGamePimp is offline
post #28 of 1584 Old 10-02-2008, 02:24 PM
Yeah, even though I only ordered the adaptor I wont be suprised if I end up ordering a full length DVI.
post #29 of 1584 Old 10-02-2008, 02:26 PM
Michael F.'s Avatar
"female HDMI to male DVI straight connecter" That is correct (#2029) and what I ordered but with a left turn 90 degree HDMI Male to HDMI Female (#4859)
It's soooo Confusing!
post #30 of 1584 Old 10-02-2008, 02:29 PM
try 2DOUBLE clicking on the WOOT picture
Mouw is offline
