Sony VPL-VW10HT - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 10-12-2008, 06:17 AM - Thread Starter
Bob Held's Avatar
I have a Sony VPL-VW10HT that when you try and power it on, the fan comes on, the bulb flashes momentarily then goes out and the lamp cover and temp/fan yellow lights stay lit. I have had the bulb checked and it is 75%. I have the service manual and have been trying to debug. I have a feeling that it is the power board feeding the bulb. Any input would be helpful - I am an engineer so if you know the component that may have gone bad I can replace it.
Many thanks
Bob
Bob Held is offline
post #2 of 4 Old 12-22-2008, 03:09 PM
Roisland's Avatar
I have the same problem. Tried to change the light bulb to a new one. Same thing.
Sometimes a clicking sound is heard just before it shuts down.
It's like it dont have the juice to power up. The lamp starts out weak as normal.
Then the projetor shuts down,,, Whats wrong?
Roisland is offline
post #3 of 4 Old 12-22-2008, 10:39 PM
Metric's Avatar
Quoted: 182 Post(s)
Liked: 57
Old projector now... when i had mine for about 6mths it did this and all i could do was send it to sony.
I want to die in my sleep like grandpa... not kicking and screaming like the people in his car.
FS: Sony 40ES with UH-380
FS: New Xbox One S
Metric is offline
post #4 of 4 Old 12-22-2008, 11:36 PM
Roisland's Avatar
Originally Posted by Metric View Post
Old projector now....
Thats true. But mine has only 1800h on it....
Roisland is offline
