Official Panasonic PT-AE3000U OWNERS Thread. - Page 28 - AVS Forum | Home Theater Discussions And Reviews
 24Likes
post #811 of 4860 Old 11-19-2008, 06:49 AM
Ingeborgdot's Avatar
Quoted: 145 Post(s)
Liked: 27
Ingeborgdot is offline
post #812 of 4860 Old 11-19-2008, 06:57 AM
mn_hokie's Avatar
Liked: 27
A recent article on Cnet indicates that the failure rate of the AE3000's firt run production is as high as 60% !!!! EEK!!!!!
mn_hokie is offline
post #813 of 4860 Old 11-19-2008, 06:59 AM
dmclone's Avatar
Where do people come up with these numbers? A poll on this site of ACTUAL OWNERS had this number less than 20%.
dmclone is offline
post #814 of 4860 Old 11-19-2008, 07:03 AM
mdmaclean's Avatar
How is the scaling? Typically for me, the newest piece of equipment TENDS to have the best scaler. Are you using a DVD player which upscales, or leaving that to the AE3000?
I have a Panasonic S77 (with DCDi), and a PS3, so I have a couple of choices. My AE3000 is on order, so can't test myself yet
Mark MacLean
Kludge Artist
http://www.maclean.tv
mdmaclean is offline
post #815 of 4860 Old 11-19-2008, 07:05 AM
TommyboyCAN's Avatar
I've gone through an array of tests and my unit is great. I have no problems and have been enjoying it for 2 weeks now.
126" Carada BW 16:9 screen @ 15.5ft throw.
All I'm reiterating which has said before on this forum is that for 1 problem there are probably 10 ecstatic users.
TommyboyCAN is offline
post #816 of 4860 Old 11-19-2008, 07:12 AM
mn_hokie's Avatar
Liked: 27
I can't remember the details of the article, but I want to say that they had tried to link it to the distribution site. One of the distribution warehouses was in a colder climate and the amount of time the units were in storage prior to shipping apparantly had some kind of impact on one of the resistors in the unit. Once the unit was fired up by the end user, the rapid change in temperature caused something to fail. I talked to someone about it and they explained it to me by comparing it to a rubber band that was placed in a freezer and then stretched. Of course, the rubber band broke.
My AE3000 has been working fine, but I fear that it's just a matter of time before I'm going to be forced to send it back. I do have my fingers crossed though.
mn_hokie is offline
post #817 of 4860 Old 11-19-2008, 07:15 AM
Quoted: 145 Post(s)
Liked: 27
And that is still not a failure rate. That is the above average user complaint and not actually a failure.
post #818 of 4860 Old 11-19-2008, 08:23 AM
jamis's Avatar
I heard the high failure numbers are due to a massive influenza outbreak at the factory causing line workers to frequently sneeze into the units they were assembling. This caused a massive increase in 'dust' blobs and fluid deposits on the optics leading to focus issues.
jamis is offline
post #819 of 4860 Old 11-19-2008, 08:48 AM
Quoted: 145 Post(s)
Liked: 27
I just touched mine and have gotten sick. They are taking me away as I type. I may never return to read some of these stupid posts again.
Remember, those of you that believe this stuff I still have some land to sell on Mars.
post #820 of 4860 Old 11-19-2008, 08:53 AM
mn_hokie's Avatar
Liked: 27
You're doing better than a lot of people then. Most puke when UPS rings the doorbell.
mn_hokie is offline
post #821 of 4860 Old 11-19-2008, 09:57 AM
Russell1's Avatar
Hi guys,
Just received an AE3000u yesterday. Unfortunately, it has a stuck blue pixel that shows up right in the middle of the screen. I've ordered a lot of projectors through the years and always had good luck in not having issues like these (with the exception of the bad lamp problem found on many of the first run Sony HS10s) so getting a unit with a pixel issue was bound to happen to me one day.
Although my unit has exactly 2 hours on it, my vendor doesn't except returns on units with more than one hour of use and advised me to go through Panasonic. I'm usually not that picky about these things and wouldn't have minded having the stuck pixel if if wasn't so darn noticeable (see pic):
Any one else had to contact Panasonic about this? If so, how good are they about it and do they pay for shipping or do I have to eat those costs or live with the bad pixel altogether?
Russell1 is offline
post #822 of 4860 Old 11-19-2008, 10:00 AM
Eskimo1's Avatar
Now that's funny.
I can see it already - "The OFFICIAL Panasonic 3000 booger blob thread - Please post if you have boogers in your 3000"
Poll options:
1- HUGE ones, I can see texture
2- Big - I can tell what color they were
3- Not sure if it's a dust blob or a booger - how do I tell?
4- No boogers here - guess they used DayQuil® that day!
No replacement for displacement...
Eskimo1 is offline
post #823 of 4860 Old 11-19-2008, 10:05 AM
Brajesh's Avatar
Quoted: 301 Post(s)
Liked: 128
Russell1, I had similar, annoying stuck pixel issues on my 1st and 2nd units. My 3rd unit thankfully is fine. I'm less than thrilled w/Panny's QA...a 25% problem rate, from my informal poll at least, is unacceptable. I haven't had to deal w/Panny directly, but I know in my case, the vendor contracted Panny both times before issuing me a RMA to return/exchange the units. Good luck.
Hi-deft Media Keen Videosaurus
Brajesh is offline
post #824 of 4860 Old 11-19-2008, 10:07 AM
kendo70433's Avatar
Originally Posted by timn99 View Post
Just curious, but what would be the best way to check and see if your projector is square with the wall?
This is my procedure. More experienced projectorists please chime in.
To square the projector to the wall, you must adjust three degrees of freedom: The projector can't be tilted up/down, pointed right/left, or rotated in the axis that goes through the lens.
Make sure all keystoning is off. Project a big solid color. The blue screen works well.
Adjust the leveling legs and rotate the projector to left or right until all four of the projected rectangle's edges are parallel to the screen's edges. Lens shift the image to the center of your screen. Repeat these adjustments as necessary, since they will interact with each other, until the image edges are all parallel to the screen edges and as centered on the screen as you want them to be.
kendo70433 is offline
post #825 of 4860 Old 11-19-2008, 10:14 AM
Brajesh's Avatar
Quoted: 301 Post(s)
Liked: 128
I walk up to the projected image and use a tape measure to check if the length of the left/right sides are almost exactly equal. The same with top/bottom sides. You may need to rotate PJ slightly to left/right until it's just about equal. Also, tilt up/down if ceiling mounted.
Brajesh is offline
post #826 of 4860 Old 11-19-2008, 10:22 AM
wnielsenbb's Avatar
Quoted: 16 Post(s)
Liked: 27
Start with zero lens shift. Put up a pattern with a center target. Don't worry if it isn't centered on the screen yet. Assuming you have square walls (not a good assumption, but a good place to start,) you can measure from the wall to the center of the lens, then from the wall to the center of the projected image. They should be the same, if not point the projector left or right to correct. Then measure from the ceiling to the center of the lens, and center of the projected image. If they are different, adjust the feet up or down to correct. Then bring the image to the top or bottom of the screen and make sure the tilt is right.
That is how I did it on my 2000 anyway. I have a good even focus, and am projecting from as far away as I can. 16 ft throw on a 120" screen.
Warren.
wnielsenbb is offline
post #827 of 4860 Old 11-19-2008, 10:24 AM
wnielsenbb's Avatar
Quoted: 16 Post(s)
Liked: 27
I did it the hard way.
post #828 of 4860 Old 11-19-2008, 10:44 AM
hemster's Avatar
Originally Posted by viper14 View Post
what do most people have for a throw distance and screen size i was eyeing up my room that i'm buildin gin teh basement for this projetor and now i'm leaning to placing it at the 17.5 mark from the lense to the screen (120) this way i'm using just a little bit of zoom, i'm going ot place it in the room on the other side and cut out a squar for the lense to beam through.
+1. I too am mounting mine at 17.5 feet (from the lens to screen) for a 110" wide scope screen. Currently am in the process of designing a mount such that the anamorphic lens can be mounted. Have 10' ceiling so flush mounting to the ceiling is not on. Will need to lower it by about 12" from the ceiling I expect.
Well, at least at 17.5' I'm not using too much zoom and expect the CA distortion to be minimal to none.
~hemster
Relentless pursuit of perfection... within budget!
hemster is offline
post #829 of 4860 Old 11-19-2008, 10:54 AM
Russell1's Avatar
Brajesh,
Thanks for the reply. Did your vendor or Panasonic cover the shipping costs? Unfortunately, my vendor is not as accommodating as yours so I'm left with dealing with Panny directly.
Just saw your poll and I must say that percentage is alarming. I can only hope that most of the users without issues didn't bother to post cause they've been too busy watching movies
I already left a voice message with my nearest service center which is located in Illinois. Until I hear from them, I'm trying to get an idea as to what this is gonna end up costing me other than lost time..
Russell
Russell1 is offline
post #830 of 4860 Old 11-19-2008, 11:12 AM
Bytehoven's Avatar
Quoted: 35 Post(s)
Liked: 66
Please provide a link. I can find no such article on CNet.
XBL GT: J05HB4G05H
PSN ID: Bytehoven
Battle Log: Bytehoven
Bytehoven is offline
post #831 of 4860 Old 11-19-2008, 11:55 AM
Brajesh's Avatar
Quoted: 301 Post(s)
Liked: 128
Unfortunately no. Had to pay for return shipping both times, but vendor paid for shipping out replacements.
Brajesh is offline
post #832 of 4860 Old 11-19-2008, 11:57 AM
bakpakva's Avatar
I would prefer that the new projectors had a better filtration system, or at least an easy way to clean the dust blobs like the Sanyo's. It isn't just the Panny, there are blobs in the Epson 1080UB user thread as well (along with other similar issues). Can a small piece of foam cost that much that they can't include it over all intake ports? I have had my AE-700 for 4 yrs, and never had a blob issue, so I will be quite peeved if I get one in a newer model. They should be getting better, not worse at air handling.
That said, I don't put much value in the user issue polls. Those that have issues are much more likely to participate. The Epson poll has only 21/30 respondants that had no issues out of the box. I know there are more than 30 owners, so this is not much of a pool of owners. As for the focus issues, I would tend to believe this is partially due to the lens, and partially due to improper screen to projector alignment.
That said, when I do pull the trigger on either the Panny or Epson in the coming months, I will make sure I get it from a source that will not give me any grief on returning it if I am dissatisfied.
bakpakva is offline
post #833 of 4860 Old 11-19-2008, 12:58 PM
Russell1's Avatar
"Unfortunately no. Had to pay for return shipping both times, but vendor paid for shipping out replacements."
Thanks. I figured as much. How fast was their turnaround time?
Well at least it sounds like you had a helpful vendor. The vendor you purchase a PJ from can really make all the difference as I'm now learning the hard way. Even though the place I ordered from has been in business since 1977, a policy of having 1 hour or less logged on the unit and/or be within 15 hours after receipt to qualify for immediate replacement is a little too tight for me.
The Panasonic rep I spoke with today sent an email to their technical dept, who was backed up at the time, but will be contacting me with instructions. In the meantime, he assigned me a case #.
I'm pretty patient and willing to wait awhile to get a unit without any of these annoying issues but not so sure if I'd be willing to pay multiple shipping costs on 2 or 3 units to get there.
Russell1 is offline
post #834 of 4860 Old 11-19-2008, 01:03 PM
Brajesh's Avatar
Quoted: 301 Post(s)
Liked: 128
Replacement shipped out next day after they received the original PJ.
Brajesh is offline
post #835 of 4860 Old 11-19-2008, 01:11 PM
Bytehoven's Avatar
Quoted: 35 Post(s)
Liked: 66
If you're willing to put the replacement projector on your CC and then have the $$$ deducted when the problem projector is returned, you can get a faster replacement.
XBL GT: J05HB4G05H
PSN ID: Bytehoven
post #836 of 4860 Old 11-19-2008, 01:19 PM
sharpbg's Avatar
After spending several hours making sure the projector was square to the screen, I can confirm that, at least in my case, it didn't make an appreciable difference in focus. The right side of the screen is still quite blurry when viewing a native 1080p computer source.
sharpbg is offline
post #837 of 4860 Old 11-19-2008, 01:48 PM
DrA
DrA's Avatar
Quoted: 35 Post(s)
Their advice:
"If you see a focus problem, try another model!"
I feel lucky that I can move the PJ forward to min throw, no zoom position and don't have to take a hit by selling the AE3000. How about others that can't? Royally screwed.
read
http://www.projectorcentral.com/cc990212.htm
Improvise, adapt to the environment, Darwin, **** happens, I Ching.
DrA is offline
post #838 of 4860 Old 11-19-2008, 01:51 PM
viper14's Avatar
Quoted: 41 Post(s)
Has anyone tryed using there pc over the HDMI connection on the panasonic PT-AE3000, i curentally have a pioneer vsx 94 AMP i have my pc connected to the AMP via VI to HDMI (ati adapter) to recieve the 7.1 sound but i noticed when i project to the scren its about 6 inches short on all sides i then have to zoom the projector in get my full 120" screen its not projecting any light its actually like its zoomed the display out anyone elese test this
pc via HDMI
viper14 is offline
post #839 of 4860 Old 11-19-2008, 02:02 PM
DrA
DrA's Avatar
Quoted: 35 Post(s)
can you mount closest? read this http://www.projectorcentral.com/cc990212.htm
DrA is offline
post #840 of 4860 Old 11-19-2008, 02:13 PM
wnielsenbb's Avatar
Quoted: 16 Post(s)
Liked: 27
Viper14, download the latest video drivers. Make sure you are in 1920x1080 video mode, and put up the 1:1 pixel mapping test image (google for it) You may need to set your amp to passthrough mode in case it is trying to scale the image. I run pc to my 2000 through my amp. It worked fine, but netflix "watch now" didn't like it so I ended up running a seperate line direct to the projector.
Warren.
