Projector lens cleaner - AVS Forum | Home Theater Discussions And Reviews
post #1 of 19 Old 11-10-2008, 10:08 PM - Thread Starter
holyhd's Avatar
What sort of cleaning solution can be used for projector lens?
I am using Optoma HD70 if this makes any difference. I heard people using monster cleaner solution ($19 from BB), eye glass cleaner from walmart (Zeiss brand) etc.
Which one is better. Mainly I do not want to damage the lens by using a solution that affects the lens coating (if any).
holyhd is offline
post #2 of 19 Old 11-10-2008, 10:20 PM
jwv651's Avatar
Good question...I would like to know also.
Joe V.
jwv651 is offline
post #3 of 19 Old 11-11-2008, 06:43 AM
Samfield's Avatar
Liked: 25
I also have an HD 70 and have used the Zeiss wet pads from Wal-Mart in conjunction with a soft generic eyeglass cloth (chamois-like) designed for plastic lens cleaning. This method appears to be safe and I have not noticed any visible scratching, or image distortion of any kind.
Samfield is offline
post #4 of 19 Old 11-11-2008, 07:41 AM
reconlabtech's Avatar
Why does the lens need cleaning? I have had my HD70 up for over 2 years now and the lens cap has never even been used. I don't see any reason to clean mine. Are there smokers or smoke contamination?
// Front Projection Enthusiast //
BenQ W1070 - 103" EasyFlex Painted Screen
Onkyo TX-NR646 - JBL Northridge 5.1 - SVS PB-1000
Roku Ultra - Amazon FireTv - Sony BDPS5500 - Kangaroo PC
reconlabtech is offline
post #5 of 19 Old 11-11-2008, 10:44 AM
Samfield's Avatar
Liked: 25
Any interior glass surface eventually accumulates some degree of film or pollutants out of the air, even in homes of non-smokers. Ever visit the home of someone who doesn't change furnace filters on a periodic basis? If the condition persists long enough a dirt film accumlates on the windows and walls. The interior side of windows even in a very clean home (over time) accumulates a film whether a smoker lives there or not. Typical residential heating and cooling systems continually churn dirt and particulates through the air. Over time these will settle on surfaces in the home. Granted, a lens cap limits exposure to airborne contaminants, but over time they will accumulate on a lens surface. It takes less than a minute to clean the lens. After investing in an HD projector, Blu-ray player and discs it seems like a small price to pay to ensure the presentation is optimal.
Samfield is offline
post #6 of 19 Old 11-11-2008, 11:33 AM
d james's Avatar
Hmm I've got cob webs right on the lens itself, maybe its time for me to clean it up. The picture still looks great!
For cleaning I'd use a microfiber cloth designed for camera lens. You don't need any special chemicals unless there is some serius crude on there, if you blow on it the moisture from your mouth will add a little fog on the glass and you can wipe it clean.
d james is offline
post #7 of 19 Old 11-11-2008, 01:06 PM
Good point, thanks. I have a high 90 gas furnace so I better give my lens a close look later this winter to see if it is getting any film on it.
post #8 of 19 Old 11-11-2008, 05:25 PM
DaGamePimp's Avatar
Quoted: 408 Post(s)
Liked: 442
This advice was handed down to me by a professional photographer with about 30 years in the business and owning over $250K worth of photo gear .
Never use anything wet on most lenses unless told to do so by the manufacturer , you can remove coatings/films that are supposed to be there . Best to use a light duster to remove dust particles first and if further cleaning is required then use a lens approved dry cloth and wipe lightly in a circular motion .
Hope that helps .
- Jason
Media Room = Samsung 65KS8000 / Denon x3300 / Klipsch speakers / Velodyne subs / Samsung K8500 / PS4 Pro / Xbox One S / WiiU / PS3 / 360 / Wii / 1080TI game PC / Multi-Arcade / My HT SLIDESHOW
DaGamePimp is online now
post #9 of 19 Old 11-11-2008, 06:11 PM
Pure-Evil's Avatar
Liked: 152
i agree. i would be very very careful with ANY chemical cleaner of any kind. projector lenses usually have a coating on them which could easily be removed with chemicals. i would use a dry soft microfibre cloth ONLY
Pure-Evil is offline
post #10 of 19 Old 11-12-2008, 02:43 AM
MirkoK's Avatar
So you'll have two spiders in Spiderman? Cool. I use Hama lens cleaning fluid which came in a set with "optical paper" for lens cleaning. Found it in the photo and video section of a local shop. Before that, I tried 100% isopropanol from a pharmacy with a microfiber cloth but that left streaks - probably from the cloth which has been used before. The use-once paper (which, by the way, looks like parchment paper) works better.
From what I understand, these metallic coatings are not "easily" removable at all. Peope who want to remove the coating have found out that you have to grind long and hard.
MirkoK is offline
post #11 of 19 Old 11-12-2008, 09:02 AM
j-bo's Avatar
Im a part-time photographer also and don't use any liquids/chemicals to clean lens.. big no no no.
Use a bulb blower to remove dust particles, a turkey baster will work just fine.
There is nothing that will get on the lens that will require a liquid/chemical cleaning agent unless you smoke heavily. Even then, it would take a good a bit of time to accumulate enough to degrade image quality.
If your image isn't degraded, there isn't really a point to it anyway, IMO.
The more you clean, the greater the chance you have of damaging the lens.
The Truth IS out there!
j-bo is offline
post #12 of 19 Old 11-12-2008, 06:33 PM
Huey's Avatar
Blasting the lens to agressively with a bulb or canned air may cause dust blob on your panels--much more painful problem and will be visible as dust blobs on your image.
Camera lens cleaner is designed to clean the lens without killing the coating. Just don't use it weekly--may be quarterly.
Huey ;-]
Huey is offline
post #13 of 19 Old 11-13-2008, 01:34 AM
CT_Wiebe's Avatar
The only cleaner accessories I would trust would be these: http://www.2filter.com/prices/products/formulamc.html.
Basically, I agree with the other posts, that a lens brush from a camera store, is all that really should need to be used.
- Claus {non-Santa model}
CT_Wiebe is offline
post #14 of 19 Old 11-13-2008, 03:45 AM
MirkoK's Avatar
Are you serious?! There is no way you can blow dust blobs through a couple of glas lenses and through a glass prism to the panels. The advice against using air is for open projectors. And don't blow air into the air exhaust vent As to canned air, it's expensive and not necessarily pure. For removing fingerprints, lense cleaning fluids work fine. They are not made for rubbing the lense once per week, of course. But some projectors (e.g. in students' apartments) are subjected to conditions that may require the use of more than a bulb blower occasionally. Spilled beverages, fingerprints, residue from preparing meals in the same room etc.
MirkoK is offline
post #15 of 19 Old 11-13-2008, 07:19 AM
j-bo's Avatar
Who mentioned compressed/canned air? No one.
A bulb blower puts out just enough air to move dust particles only and is safe. Safe enough to use on digital camera sensors.
We are talking the outside of the PJ lens right?
j-bo is offline
post #16 of 19 Old 01-06-2009, 10:09 AM
Ryked's Avatar
What do you do if you notice dust on the inside of the lens??
The wife did me a favor a while back and vacuumed the filter while it was still on the side of the PJ . Never really though much of it until it was mentioned above not to blow air into the exhaust vent. With her vacuuming the filter it probably sucked dust in through the exhaust vent
It is a Panny AX200U.
Haven't really looked into it as it is less than a year old.
Any thoughts or ideas?
First HTPC: Silverstone SST-GD05B-USB3.0 case, PC Power & Cooling Silencer MK III 500W, Gigabyte GA-Z77M-D3H-MVP MB, i3-3225 3.3GHz CPU, G.Skill Ripjaws Series 8GB DDR3-1600 Memory, A-Data XPG SX900 128GB 2.5" SSD and Asus BW-12B1ST/BLK/G/AS Blu-Ray.
Going to try out the HD4000 graphics for a bit.
Ryked is offline
post #17 of 19 Old 01-06-2009, 10:42 AM
rickster904's Avatar
I used to use a lense pen and a bulb blower - never any liquid. I haven't cleaned my pj lenses in 2 years. IMO if you don't smoke and don't leave finger prints on the lense the need for cleaning is really insignificant. I have never noticed any IQ issue with a tiny bit of dust on the lense. You can't get rid of all the dust anyway. Don't sweat the small things.
On the other hand I open up my LCD pj to rid the inside of dust every 6 months.
rickster904 is offline
post #18 of 19 Old 01-18-2009, 05:55 PM
lsiberian's Avatar
I'm trying to get dust blobs off of my image. Have cleaned the color wheel and both lenses. Didn't realize compressed gas could cause dust blob formation. Where is a place to some pure gas? Really trying to get this thing cleaned up the dust blobs are very annoying when there is no ambient light.
lsiberian is offline
post #19 of 19 Old 02-02-2010, 10:56 PM
isamu's Avatar
Quoted: 34 Post(s)
JUst ordered some Micro Fiber clothes. Hoped they work on my 8720 lens
isamu is offline
