Epson HC720,, mounting screw size ???? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 11-12-2008, 07:31 AM - Thread Starter
davyo's Avatar
My Epson HC720 is getting delivered this Thursday, I have a universal ceiling mount being delivered as well.
What is the screw size and thread type needed to mount the Epson to the ceiling mount ????
Thanks much in advance
Cheers
Davyo
davyo is offline
post #2 of 3 Old 11-12-2008, 09:41 AM
MirkoK's Avatar
M4 x 8mm, 4 pc. See the pdf manual, it's available online. You should have looked up the manual before ordering a mount to see if it fits (ie. has four arms and suffficient diameter).
MirkoK is offline
post #3 of 3 Old 11-13-2008, 06:11 AM - Thread Starter
davyo's Avatar
Cool,, thanks much.
Yes I should have looked at the PDF online but I did not think the screw size would be listed as that has been my experience with my Panasonic projectors in the past (no screw size listed on Panasonics manuals).
As far as the mount its the mount Visal Apex recomended for the HC720(ordered mount and projector from them), so its all good,,, just didnt know if the screws would be included.
Anyhow, thanks again.
Cheers
Davyo
davyo is offline
