Benq PB6210 Problem - Won't Power Up Fully? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 11-16-2008, 10:53 AM - Thread Starter
organica's Avatar
My Benq PB6210 has recently stopped working, and I can't figure out what's up with it.
When I switch on, it starts to power up OK, the power light flashes green and then goes solid green, and the fan kicks in.
But only a couple of seconds later, all three lights flash orange briefly, the fan stops, and it shuts down into standby mode.
I'm wondering if anyone else has had a similar problem with their Benq? It looks like some kind of thermal cut-out to me, but the exact diagnostic doesn't seem to be covered in the manual. The lamp has been replaced fairly recently, so I don't think it's that.
It's out of warranty, and I'm just pondering whether it might be fixable by replacing a fuse or something, or whether I'll need to fork out for a repair job...
organica is offline
post #2 of 3 Old 11-16-2008, 06:07 PM
jherring69's Avatar
If you don't mind opening up the projector, I would try checking the fan wires/connections. I had this problem with my Benq PB6100. However, mine was showing a fan error code. Still worth a try. It had three fans and it ended up being one loose connection. Good luck.
I have a PDF file that shows the inside of the PB6100 as well as some of the fan wires. I think the 2 projectors are very similar. Let me know if you would like me to e-mail it to you.
Jason
jherring69 is offline
post #3 of 3 Old 11-17-2008, 10:52 AM - Thread Starter
organica's Avatar
Yes that's certainly worth a try - the PDF would be much appreciated.
Could you mail it to fanwires@factork.co.uk
Thanks for your help!
organica is offline
