Infocus X10/ IN80 Owners thread - Reviews, Settings, Screenshots and issues - Page 34 - AVS Forum | Home Theater Discussions And Reviews
post #991 of 1000 Old 08-01-2014, 09:46 PM
atanuray's Avatar
Firmware is not user upgradable, AFAIK.
atanuray is offline
post #992 of 1000 Old 08-02-2014, 12:13 AM
billkaza's Avatar
Liked: 0
You mean that it is locked?
I have installed Dark chip 3 in my projector and i would also like to upgrade to in82 firmware but in case this doesnt work i dont have in80 firmware.
Is there any way i could extract it?
billkaza is offline
post #993 of 1000 Old 12-03-2014, 06:46 PM
hybris1's Avatar
What are the best deals on bulbs these days? I see $50 ones on Amazon and $160 OEM bulbs. I am moving in a month and may leave the projector so it doesn't have to be the best. I was thinking the cheap one and if it sucks, I'll keep it for an emergency spare.
hybris1 is offline
post #994 of 1000 Old 12-26-2014, 12:53 PM
Liked: 0
Issue with Infocus X10
I'm hoping someone here can provide an insight into an issue i'm having with my 1.5 year old x10 projector. I'm quite a novice when it comes to this so please let me know if there is anything i can try as i'm currently assuming the projector is broken and that is that!
Basically whenever i switch on my projector on it just projects a grey screen (no red infocus as i would typically expect when the projector is warming up). There is then nothing, as far as i've found, where i can alter this; the remote fails to have any effect, i can't bring up the setting menu or any sources that i connect to the project do not come up at all.
I'm assuming my projector has had it so i'm expecting the worst, please let me know if this is something any of you have come across before.
matt6gb is offline
post #995 of 1000 Old 01-17-2015, 06:30 AM
dengland's Avatar
Quoted: 33 Post(s)
dengland is offline
post #996 of 1000 Old 01-17-2015, 10:41 AM
dengland's Avatar
Quoted: 33 Post(s)
Infocus X10 Service Menu Code
Anyone know the Service Menu code? My projector had a hard crash and lost its mind (even lost it SN until I power cycled). Everything defaulted to default values.
Picture looks like crap. if I lower the red gain, I can make it better, but that is not the answer.
I think the color wheel index is wrong. I cannot get into the service menu without the correct set of remote key presses.
dengland is offline
post #997 of 1000 Old 01-25-2015, 05:39 AM
dengland's Avatar
Quoted: 33 Post(s)
CWI index was indeed the problem. I found it to be 56. I adjusted it to 90 to get a good picture back.
dengland is offline
post #998 of 1000 Old 03-22-2015, 11:17 AM
talon95's Avatar
Quoted: 136 Post(s)
Liked: 65
Ah I see you did get this fixed now that I dug up this thread. Thanks again for your help. This also fixed the posterization (red blotchy) problem on mine. All I had to do was change it from 91 to 86 in my case.
BTW, a more general question to anyone. Is there a decent replacement lamp that's significantly less than $400 for the X10. I just don't see spending that much when I can probably buy a decent 1080p DLP now for not that much more. I dug these up,
http://www.myprojectorlamps.ca/proje...focus/X10.html
http://www.jaspertronics.com/products/pli01678
https://www.bulbamerica.com/products...-original-bulb
Of course there's the crap $50 ones, but I do want something that will work for quite a few hours and not blow up in the projector.
talon95 is online now
post #999 of 1000 Old 09-26-2015, 09:10 PM
Liked: 0
Hi my infocus x10 is having the blotchy red issue since some time. I see that adjusting the cwi may help. Could you please tell how to get the service menu. I am unable to PM since I am new to the site, please pm me if possible. Thanks.
avsjvs is offline
post #1000 of 1000 Old 12-02-2015, 02:17 PM
bigtartn's Avatar
This is unreal. My posts earlier in this thread bemoaned the blotchy problem. Infocus service in the UK wanted to charge 100s of pounds to fix the problem - what a bunch of crooks
Turns out all you needed to enter the servuce menu and play with the color wheel index value and the blotchyness goes away.
[Can someone explain what is going on here?]
Found elsewhere:
On every color wheel system (FP and RPTV), there is mark of some sort on or in the wheel. This is the color wheel index (CWI) mark. Elsewhere, there is a sensor that "sees" this mark once per revolution and passes a signal to the light engine. There is software in the light engine that keeps the wheel spinning at some multiplication factor of the displayed video by tweeking the color wheel motor controller. The idea is to keep the CWI mark signal at a specific time relationship to the vertical sync signal. Many of these CWI marks are applied to the color wheel by hand during color wheel manufacturing. As such, two specific CWI marks on two specific wheels may not be in the same location with respect to the color segments of the wheels.
The CWI adjustment allows the people in the factory to do fine adjustments to set the timing of the color segments of the wheel with the timing of the display video. That is, it allows them to adjust for someone putting the CWI mark in a slightly different location.
For others - the service code sequence is
1. "resize"
2. "custom"
3. "source"
4. "presets"
5. Down arrowButton
6. Up Arrow button
Explaning
bigtartn is offline
Infocus
