My first projector (Panasonic AX200U) - AVS Forum | Home Theater Discussions And Reviews
post #1 of 12 Old 12-05-2008, 09:31 AM - Thread Starter
mash007's Avatar
Hello everyone, first time posting. I've been researching aggressively in the past few days for a new projector and I keep finding myself back at this forum. Thanks to the people here I now have a brand new AX200U sitting on my shelf! 1 word... HOOOOOOOOOOOT (in a good way).
I've only hit 2 road bumps. First, I have a spot on the projector that's a tad brighter than the rest of the screen. I only have 1 hr on the projector so this might go away.
Second, my room is a light matte beige/brown color. The color of the image doesn't seem to affected too much, but it does cause a lot of ambient light which I'd like to get rid of. This is my personal room, so I don't want to do anything dramatic. Any ideas?
Again, thanks for everyone help.
PS: I got this projector for $800 from an authorized dealer on a well known auction site using the Live.com cashback.
mash007 is offline
post #2 of 12 Old 12-05-2008, 09:42 AM
reikoshea's Avatar
what screen are you using...sounds like you are describing a hotspot.
reikoshea is offline
post #3 of 12 Old 12-05-2008, 09:47 AM
reconlabtech's Avatar
1. As said above, your screen has a hotspot. If you are using the wall, you need a FLAT paint, not satin, semi-gloss, or gloss.
2. The darker your paint job, the better. if you don't want to paint the whole room darker, just hit the area up front where the screen is. It doesn't have to be black but IT MUST BE FLAT!
// Front Projection Enthusiast //
BenQ W1070 - 103" EasyFlex Painted Screen
Onkyo TX-NR646 - JBL Northridge 5.1 - SVS PB-1000
Roku Ultra - Amazon FireTv - Sony BDPS5500 - Kangaroo PC
reconlabtech is offline
post #4 of 12 Old 12-05-2008, 09:50 AM
j-bo's Avatar
How big is the room? What are you using for a screen? Where is the ambient light coming from?
The Truth IS out there!
j-bo is offline
post #5 of 12 Old 12-05-2008, 11:53 AM - Thread Starter
mash007's Avatar
The paint is flat. But I was thinking of painting that wall a darker shade of the brown/beige. I have light coming from a window on the right side, but that's not much of a problem since I mostly use the projector at night. The main problem is the projector image itself CAUSES allot of ambient light (basically my room lights up a bit), this distracts a bit from the viewing experience.
mash007 is offline
post #6 of 12 Old 12-05-2008, 12:10 PM
What is your current screen?
post #7 of 12 Old 12-05-2008, 12:59 PM
reikoshea's Avatar
his wall...still likely to be the reason for hotspotting...even with flat paint.
post #8 of 12 Old 12-05-2008, 01:25 PM - Thread Starter
mash007's Avatar
Its not my walls fault for the bright spot because I put a white piece of paper in front of it and its still there.
mash007 is offline
post #9 of 12 Old 12-05-2008, 01:43 PM
reikoshea's Avatar
its actually the angle at which the light is being reflected back.
ever shine a flash light at a mirror and bounce the light back to your eyes? notice how bright the bulb of the flash light becomes? same concept.
post #10 of 12 Old 12-05-2008, 01:59 PM
Could be the PJ is set too bright.
Calibrate your brightness and contrast by using the THX Optimizer Tool found on most Pixar Movie dvds.
post #11 of 12 Old 12-05-2008, 02:31 PM - Thread Starter
mash007's Avatar
Will do. But I don't think thats the problem either, its pretty misshaped and noticeable. Might have to call Panasonic, but its no biggy.
mash007 is offline
post #12 of 12 Old 12-06-2008, 11:29 AM
CANNON-FODDER's Avatar
Quoted: 213 Post(s)
Liked: 102
CANNON-FODDER is offline
