Official Sanyo PLV-Z60 Thread - Page 8 - AVS Forum | Home Theater Discussions And Reviews
Old 10-31-2010, 03:58 PM
JetJockey1's Avatar
Try to google PLV-Z5 (very similar model)thermal reset fix, unplug unit, its 6 screws, remove cover, push the reset button, replace cover....good luck!
JetJockey1 is offline
Old 11-01-2010, 09:32 AM - Thread Starter
angryht's Avatar
Let us know what happens. With only 200 hours, they better treat you right!
-Greg
angryht is offline
Old 11-01-2010, 09:52 AM
johnnymg's Avatar
Thanks, that's good to know.
I talked with someone at the Sanyo Chatsworth repair facility this morning.
Since the the unit has <200 hours I'm going to give it to them for a look see. The unit was pretty noisy anyway.................. ~45+db when running in eco mode so it needed some attention anyway. This will be a good test of Sanyo's service. I was planning on upgrading to the new 1080P projector.............. before this issue with my current project.
thanks again for the reset switch suggestion
JohnG
johnnymg is offline
Old 11-04-2010, 06:46 PM
rajdori's Avatar
Quoted: 13 Post(s)
i bought PLV Z60 in Dec 08. about 2 yrs now. approx 875 hrs on the lamp. i don't know if lamp has dimmed in last 2 yrs, but i am extremely satisfied with the pj so far. i am feeling the upgrade itch on pj. so my questions are..
1- if i upgrade, i plan to go for Epson 8100 or 8350 pjs. will i see a huge improvement over Z60 on watching bluray? worth spending 500 more?
1- going by my expected usage, i will hardly be at 1500 hrs in next one yr, i.e. after 3 yrs of usage. will anything else will be a problem in say another year? or will the picture quality degrade significantly?
2- i use the pj as per instructions, have it in a temp-controlled relatively dust-free room. is there anything more i can do to avoid picture degradation?
3- officedepot and staples etc sell dust-busters in a bottle. is it ok to use it from say 10" on my projector interior? or should not do that?
rajdori is offline
Old 11-05-2010, 10:23 PM
johnnymg's Avatar
JohnG
Update: Sanyo has fixed the projector. Will pick it up next week. Curious to see if they'll tell me what the problem was.
Update: Picked up the projector and it now works. It's still quite noisy with a measured sound amplitude of ~45 dB. The fans are loud on this unit. :-(
cheers
JohnG
johnnymg is offline
Old 11-30-2010, 01:22 PM
amerrescue's Avatar
Plv z60 Projector the lamp replace led was flashing, on top of the unit. I replaced the lamp with a new one. It appears to be perfect; however, the lamp replace led is still flashing.I disconnected the power, replaced the lamp, opened the door with the remote and the light still doesn't come on..followed by the door shutting..on its own and then the lamp replace light starts flashing again. Is the board damaged or another reset I am not aware of?
amerrescue is offline
Old 12-01-2010, 12:55 PM - Thread Starter
angryht's Avatar
Did you do a lamp counter reset?
From the manual (see also the first post)
Turn the projector on and press the MENU button to display
the On-Screen Menu. Select the Setting Menu with the
Point ed buttons. Press the Point 8 button to access the
submenu items.
Select Lamp counter reset and then press the the OK or
Point 8 buttons. Lamp replacement counter reset?
appears. Select [Yes] and then press the OK button.
Another confirmation dialog box appears, and select [Yes] to
reset the Lamp replacement counter.
-Greg
angryht is offline
Old 01-04-2012, 06:08 PM
Interceptor2k's Avatar
Hi all. I have had my z60 for 2 years now and it has been great. However, I decided to try hooking up my old pc to use as a video streamer / surfer. The image quality is poor (blurry) for text. I have graphics card set to default 1280 x 720, 60 hz, but image just does not look very good. Is there an optimum setting for viewing text? I have even increased default font size to 120 dpi which helped. I suspect that fine detail like text and icons just may be too small when projected onto a large screen.
Pc is XP, graphics card is nVidea 5700. It's old stuff, but works good.
Thanks in advance.
Interceptor2k is offline
Old 01-05-2012, 07:04 AM - Thread Starter
angryht's Avatar
I've noticed that the text on mine is a little dodgy too. I have older equipment as well but I haven't explored a solution.
-Greg
angryht is offline
Old 08-07-2013, 02:37 PM
Has anybody sold their Z60? If so what did you sell it for?
I'm looking to sell mine with quite a few accessories (96" DIY Silver Fire v1 screen, ceiling mount with 4 different lengths, 30ft HDMI cable with ferrite cores) and had originally asked $600 on Craigslist without much success. It has roughly 1200 hours in eco mode but I believe the lamps have lasted to 3-4k like that haven't they?
Just want to know what this is worth and how much I can get out of it.
jordo_99 is offline
Sanyo
