optoma HD70 color wheel shattered - AVS Forum | Home Theater Discussions And Reviews
post #1 of 153 Old 02-07-2009, 03:53 PM - Thread Starter
ido0's Avatar
less then 700 hours old (about 2 years though) while watching a movie, popping sound, and unit shutdown.
I checked the lamp which is ok. only the color wheel was shattered.
the unit works fine otherwise (i think).
questions:
I don't live in the US anymore, and I think I'm out of warranty (its been around two years give or take since i got it)
A. anywhere i can check if its still covered under warranty ?
B. where can I buy a new color wheel ?
C. can I install the color wheel myself? I already took the broken one out of its place: When installing a new one, does it require to sync it somehow ? or just insert the wheel and thats it ?
ido0 is offline
post #2 of 153 Old 02-11-2009, 12:47 PM - Thread Starter
ido0's Avatar
A. turns out its not under warranty
B. found a place which sells colorwheels for my model
but can some one please answer me about C ?
- can I install the color wheel myself or should i pay them to repair it
- When installing a new one, does it require to sync it somehow ?
ido0 is offline
post #3 of 153 Old 02-11-2009, 01:27 PM
quantumstate's Avatar
Yep, that's Optoma for you!
The color wheel is inside the 'light engine', which is usually replaced as an FRU. I don't know whether you can replace just the color wheel, but its sync is built in so you don't have to worry about that. Just install the new in the same registration as the old.
quantumstate is offline
post #4 of 153 Old 02-11-2009, 01:29 PM
TF Ghost's Avatar
Ah! I didn't know about the sync issue but I do know you can replace just the color wheel, so it sounds like you should be set.
TF Ghost is offline
post #5 of 153 Old 02-11-2009, 01:58 PM
augiedoggy's Avatar
what do you mean "thats optoma"?....most of the colorwheel failures I read about and one I experienced was infocus related....not bashing but come on its not common to optomas
augiedoggy is offline
post #6 of 153 Old 02-11-2009, 02:03 PM
jarrod1937's Avatar
Quoted: 110 Post(s)
Liked: 46
He's the anti-optoma guy around here.
jarrod1937 is offline
post #7 of 153 Old 02-11-2009, 02:10 PM
augiedoggy's Avatar
he probably owns a mitsubishi unit manufactured by optomas parent company coretronics....lol
post #8 of 153 Old 02-11-2009, 03:24 PM
augiedoggy's Avatar
You gotta be sh1tting me. Do a little looking around, and a shattered color wheel is more common to Optoma than any other brand. If anyone would know, I would.
But you two can goard head with your reach-around, as you like...
And nope, never owned (nor would I) a Mitsubishi.
hey relax...and grow a sense of humor...I've only owned three projectors myself one being an infocus other two optomas...and have a friend who has owned two, an infocus and then he upgraded to the same optoma I had.....almost two and a half years later and both the optomas are going strong with no issues.....however both of the infocuses died....his color wheel failed and mine sounded like a buzzsaw until the bulb ballast or balb cooling fan died and prevented it from working at all.....he sent his in for repair and it worked for almost 6 months before it failed again. Now I'm sure one of the main reasons I see sooo many failed colorwheel and collapsed light tunnel threads on infocus products is there are soooo many older infocus products out there being used compared to optomas... where this is honestly the first time I've personally come across anybody mentioning having a colorwheel fail on an optoma.....and since my last two projectors are optomas thats usually the threads I try stick to reading not that I'm here that often reading so...
So as you can see not everyone has the same personal experiences to be so biased against one brand....especially one that manufactures so many other brands?
post #9 of 153 Old 02-11-2009, 04:13 PM - Thread Starter
ido0's Avatar
The color wheel isn't in the light engine (i think) at least not in this model.
It took only one screw to get the shattered colorwheel out, and I'd like to know if i put a new one in does it need any calibration or what ?
ido0 is offline
post #10 of 153 Old 02-11-2009, 06:17 PM
jarrod1937's Avatar
Quoted: 110 Post(s)
Liked: 46
If its the correct color wheel, the light sensor (part of the old color wheel assembly you have) will read a black strip on the side of the motor, this is how the projector tracks the color wheel position, so no need to calibrate it for that.
And yeah, i wouldn't really say its part of the light assembly either, more so a part that sort of slides into the path.
post #11 of 153 Old 02-11-2009, 06:52 PM
reconlabtech's Avatar
Nice mouth...
Prove your claim or hit the road. And take your filthy inuendo with you.
// Front Projection Enthusiast //
BenQ W1070 - 103" EasyFlex Painted Screen
Onkyo TX-NR646 - JBL Northridge 5.1 - SVS PB-1000
Roku Ultra - Amazon FireTv - Sony BDPS5500 - Kangaroo PC
reconlabtech is offline
post #12 of 153 Old 04-03-2009, 03:57 PM
Ekus's Avatar
Hello all, this is my first post here. Great forum!
I, too, am looking for the replacement color wheel for Optoma HD70.
My color wheel failed after about 2000 hrs (2.5 years), just as I was starting to shop for a replacement lamp. Looks like the lamp will have to wait, as I have to make sure it is fixable first... Two of the color wheel's glass segments broke into tiny pieces. I managed to open the projector and remove the color wheel fairly easily. I have some photos for future reference if anybody is interested.
Any suggestions? Is it worth it? I need to fix the wheel AND then buy a new lamp, and I hope I can have them for around 100 and 250 USD respectively...
Ekus is offline
post #13 of 153 Old 04-03-2009, 04:43 PM
Sheridan1952's Avatar
Last time I checked, an HD70 color wheel is about $170.
Sheridan1952 is offline
post #14 of 153 Old 04-04-2009, 01:28 AM - Thread Starter
ido0's Avatar
I just replaced mine a while ago, the colors are a bit off (the store replaced it with an HD72 colorwheel).
is there a way to recalibrate or did something else go bad ?
the symptoms that color show up a bit dithered...
ido0 is offline
post #15 of 153 Old 04-04-2009, 06:23 AM
Is TrueVivid on or off? I'd turn it off if it is on.
post #16 of 153 Old 04-04-2009, 07:54 AM
jarrod1937's Avatar
Quoted: 110 Post(s)
Liked: 46
Who the hell did that? If its been replaced with the color wheel below (from cine4home with an article of the hd72i), then the color wheel segments are different sizes:
In particular the white segment is a different size. From my experience, this leads to the mainboard driving the color wheel wrong, and where it feels the white segment should be, it displays the next color filter occupying the same space. This leads to a bit of banding, as it is showing a color, instead of white, where there should be highlights.
Only way to fix this issue would be to replace the color wheel with one that has correct segment sizes, or do a firmware hack that updates the projector with firmware designed to drive a color wheel (and dmd) with those segment sizes.
This is assuming the color wheel for the hd72 is the same as the hd72i shown above... i don't know what difference the "i" makes between them. This is also assuming my memory serves me correct on the size of the white segment in the hd70, though sadly i cannot finds any pictures online to verify it.
post #17 of 153 Old 04-06-2009, 06:21 AM
TF Ghost's Avatar
Right? That's one heck of a service center. I take it they didn't turn it on and test it before returning it to you?
TF Ghost is offline
post #18 of 153 Old 05-15-2009, 04:12 AM
fafouneou's Avatar
Hello,
I had the same problem as this movie last night but in continu
youtube.com/watch?v=Uz3z129CDzk
The HD70 is out of warranty since 3 months and is already going to Optoma 2 times during the guarantee once in November 2008 for a problem of random green flash.
Do you think is the color wheel problem?
Where I can find a color whell for the HD70 on the web ?
Does it require to sync it ?
Sorry for my poor english but i'm French...
Thanks a lot for your help
fafouneou is offline
post #19 of 153 Old 05-17-2009, 09:40 AM
guitarman's Avatar
Quoted: 14 Post(s)
The colorwheel probelm would be where the glass breaks up, you'll probably just see a black and white image. On your video It looked like posturization or could even be just a bad connection. You could try a full factory reset in the service menu. I don't have it handy maybe someone could chime in and give you the service menu.
good luck
Tom/guitarman
VideoDementia
Are you twisted also?
http://www.videodementia.com/sales/TomWithWires.jpg
guitarman is offline
post #20 of 153 Old 05-17-2009, 10:00 AM
jarrod1937's Avatar
Quoted: 110 Post(s)
Liked: 46
Actually that's only if the color wheel is completely gone. If the color wheel is still functional, but the timing of the color wheel is being lost periodically you may see whats in that video. Two of the most likely reasons for the timing being lost are:
1.) Bearings going bad, so every once in a while a "hiccup" occurs in its spinning, which can cause it lose timing periodically.
2.) The black strip that a color wheel uses for judging the color wheels position cannot be read reliably. This may happen if there is dust on the sensor or perhaps even partially on the black strip itself.
post #21 of 153 Old 05-28-2009, 08:57 PM
areaglew's Avatar
Reviving this thread for a similar issue...
I think my color wheel is going out on my HD70. The symptoms:
1) The projector turns on fine and the image is sharp and vivid.
2) After about 20 minutes, the projector image flashes with different colors. The image is still visible, but the colors are wrong.
3) A few seconds later, the projector gives a brief whine... then it shuts down and the warning indicator shines a solid orange.
4) The projector is unresponsive to the remote. I have to unplug and replug, then it will start up again, although it takes about 5 minutes of start-up attempts before it will display an image. Then back to step 1.
Any idea if this is a color wheel problem or a lamp issue? Or maybe something else? The lamp has about 1200 hours on it. I bought the projector used about a year ago, and a new lamp or color wheel would cost more than the projector did... so I'm not sure if I would try to fix it unless I was sure of what the problem is.
Any takers?
Also, is there an online guide to taking the HD70 apart?
Any info would be appreciated...
bill buck
areaglew is offline
post #22 of 153 Old 05-28-2009, 11:35 PM
coug7669's Avatar
Quoted: 16 Post(s)
Areaglew contact Sheridan from this thread. He services pj's and is very reasonable in his prices. He already listed the price for DIY pm him for installation. I retrofitted my davis colorwheel with grommets. I had a nec 240 that shattered and saw how flimsy that wheel was compared to the davis and decided then that I did not want to risk damaging the new wheel. Sheridan installed wheel for a reasonable price and I am very pleased with the work.
coug7669 is offline
post #23 of 153 Old 06-18-2009, 04:29 PM
draktheas's Avatar
Anyone know where I can get one of the HD70 color wheels?
P.S. - I know about PM'ing Sheridan, but my post count is too low.
draktheas is offline
post #24 of 153 Old 06-18-2009, 07:08 PM
Post a few more times until you can PM him...
post #25 of 153 Old 06-19-2009, 07:05 AM
TF Ghost's Avatar
I PM'd him for you...
TF Ghost is offline
post #26 of 153 Old 06-24-2009, 10:04 PM
ejsr's Avatar
We just moved and found our color wheel has broken for our Optoma HD70 as well. I need to buy a new color wheel and have it installed, unless we can do it ourselves? Maybe I need Sheridan's help too, are you there? Or do any of you know where I can buy one? Thanks so much! Elisa
ejsr is offline
post #27 of 153 Old 06-25-2009, 01:50 AM - Thread Starter
ido0's Avatar
You can do it yourself I guess, its rather easy. just get the correct color wheel. I got mine at a local projector store for less then $180
ido0 is offline
post #28 of 153 Old 06-25-2009, 07:16 AM
rnengnr's Avatar
Originally Posted by reconlabtech View Post
Nice mouth...
with all the "ME TOO" Optima color wheel falures that have popped up on this thread alone.....
Looks Like the Optima case of the faulty colorwheel has been built...
anything else you need for proof of design flaw Mr Recon
RF Freq
rnengnr is offline
post #29 of 153 Old 06-25-2009, 07:47 AM
TF Ghost's Avatar
Wow! 5 whole people in this thread alone! And how many HD70's were sold?
In any case stating color wheel failures are more common to Optoma than any other brand, and backing it up with "if anyone would know, I would know", is nonsense. Is it possible that Optoma's color wheels have a higher failure rate than other manufacturers? Sure. However it's equally likely that Optoma happens to be a more popular brand for the sub $3k home theater enthusiasts that post on AVS Forum.
TF Ghost is offline
post #30 of 153 Old 06-25-2009, 08:05 AM
rnengnr's Avatar
do you know anything about statistics dude...............
this is a mere sample of the few users of avsforum of the few that wanted to search the threads....
maybe a 20% of all optima users on AVS,,,,,,
and you got five hits...... seems like a graphable trend to me.....
toyota would have had a recall by now
nice try
RF Freq
rnengnr is offline
Optoma Hd70 720p Dlp Home Theater Projector
