Official Mitsubishi HC1600 Owners Thread - Page 6 - AVS Forum | Home Theater Discussions And Reviews
post #151 of 165 Old 08-07-2012, 05:30 PM
antidelldude's Avatar
It is a power issue. Either the power supply or the ballast. In instances like these it is usually a blown cap or two somewhere. It has not happened to mine yet so I can't comment on where to start looking.
antidelldude is offline
post #152 of 165 Old 08-07-2012, 05:34 PM
Chilli1600's Avatar
Quck reply, thanks! Guess I'll start looking for someone to take it to for repair... big fingers aren't so good for working on this stuff...
Chilli1600 is offline
post #153 of 165 Old 08-12-2012, 09:16 AM
joeyalbergo's Avatar
I just procured a damaged HC1600 and it has these bad pixels / black & yellow then two vertical lines one pixel id say in width.
What happened to this projector? Can I repair this?
I've phoned Mitsu and am waiting for a call-back.
Any advice would be appreciated -
TIA!
joeyalbergo is offline
post #154 of 165 Old 08-12-2012, 09:47 AM
This is a problem that will need to be addressed by an authorized repair facility. It is a failed Digital Micromirror Device (DMD) and the entire DLP board around it will need to be replaced. A board that is only sold to authorized repair centers and a part that you can not find anywhere on the internet.
My best advice to you, if you'd want to attempt the fix yourself, is find another hc1600 with a different problem and swap the DLP boards.
post #155 of 165 Old 02-27-2013, 05:09 PM
pogi720's Avatar
I'm new here and wondering if any of you experience the problem I'm having with my HC1600. Everytime I hook it up to my Windows 7 computer it does not get detected until I restart my computer. Any thoughts on this? Is this expected behavior? This did not happen when I used to have Windows XP on the same PC. With XP, I only needed to check "Extend my Windows desktop onto this monitor" and it works. No need to restart.
Any Windows 7 expert here?
pogi720 is offline
post #156 of 165 Old 03-18-2013, 09:00 AM
tedzap's Avatar
how many hours are people getting out of the lamps? I have had 2500 trouble free hours and am wondering if I should source a replacement or just plan on replacing the projector altogether.
thanks in advance!
tedzap is offline
post #157 of 165 Old 04-17-2013, 09:01 PM
pogi720's Avatar
What I do now is just go to Device Manager and disable and enable the Display Adapter. This way I don't need to restart the computer just to get detected.
pogi720 is offline
post #158 of 165 Old 04-17-2013, 09:05 PM
pogi720's Avatar
In the manual it says "COLOR may be unavailable depending on the type of input signal.'
Question is, what type of signal will enable the COLOR adjustment? At least for TINT, the manual was specific about it being enabled only when you have NTSC signal. But what about the COLOR?
Does anyone know? Thanks.
pogi720 is offline
post #159 of 165 Old 04-18-2013, 05:32 AM
airscapes's Avatar
Quoted: 391 Post(s)
Liked: 307
Tint and Color are from the analog days, If you use a component (non HD signal), composite or Svideo you will have access to those controls but . HDMI or VGA you will not as they really have no place in the digital world. TV makers are adding them in newer sets because people think they need them when in fact the do not.
Doug
Planar PD8150 with DC4 DMD paired with a Dalite HP 2.8 110"
http://www.airscapesart.com
airscapes is online now
post #160 of 165 Old 04-29-2013, 06:44 AM
pogi720's Avatar
Thank you.
pogi720 is offline
post #161 of 165 Old 08-22-2013, 04:30 PM
Rasin2's Avatar
Gotta Mitsusbishi HC1600 never had a problem with it..Had a bonehead in my basement adding outlets..a room over from my theater. .kicked a breaker twice...now I gotta an expensive blue flash light..powers up,runs like normal..can access menus..but wont revoginze any type of input..hdmi, component..nothing. .keep getting no signal. .any help out there?
Rasin2 is offline
post #162 of 165 Old 12-03-2014, 08:52 PM
blobula's Avatar
Quoted: 12 Post(s)
Could someone suggest an affordable bulb replacement for this projector? I believe I'm in the need for one. In dark scenes I see blurring is very noticeable and sometimes the image pulses. The bulb i have is still the original from 3/4 years ago.
blobula is offline
post #163 of 165 Old 03-13-2015, 01:27 PM
99th_Obsidian's Avatar
Blew (literally a loud pop and then electrical burning smell) my 2nd lamp in 6 years during last weekends movie. Thought about buying another lamp but decided... its time for an upgrade. So I shopped for 3D 1080p projectors near what I paid for my Mitsu and selected the Optoma HD141X. Amazon sez its was just delivered so I'll let you know once I get it all setup. Any thoughts on what I should do with my old HC1600?
4seating dot com survivor
99th_Obsidian is offline
post #164 of 165 Old 03-31-2015, 08:11 PM
Liked: 0
Can anyone tell me the part number for the Mitsubishi hc 1600 color wheel.
Please and thank you
chrisshafferfan is offline
post #165 of 165 Old 04-07-2015, 07:15 AM
Liked: 0
hey, just bought a hc1600, hooked a LG home theater blue ray player into the HDMI port and it is saying "no signal". I changed the output on the video player to 720p but still no luck.. I've never owned a projector so I'm new at this.. any help would be appreciated.
hc1600 is offline
Mitsubishi Hc1600 Dlp Home Theater Projector
