InFocus X9 Review - Page 4 - AVS Forum | Home Theater Discussions And Reviews
post #91 of 104 Old 07-14-2009, 01:41 PM
jake the ssnake's Avatar
Does anyone else have a problem with the settings going back to default EVERYTIME it shuts off ? The default is way too dark for some of my games, so I have to change it every time i turn it on, very frustrating. It didn't come with an owners manual so I'm not sure if there is a way to save the settings.
jake the ssnake is offline
post #92 of 104 Old 07-14-2009, 03:24 PM
Duane T's Avatar
I think that you can only make changes to the User setting, with the others defaulting to their original numbers after the power has been off.
XBL GT: Big Bucket
Duane T is offline
post #93 of 104 Old 07-14-2009, 04:14 PM
Thanks, I'll give that a try. I guess I really don't need multiple settings anyways, good is good regardless of movies or games.
post #94 of 104 Old 07-16-2009, 10:21 PM
Yesdear's Avatar
Why are some of the menu controls greyed out? Sharpness, tint and color can not be adjusted. I find the color a little dull and washed out even in a dark room and would like to tweek it a bit.
Yesdear is offline
post #95 of 104 Old 07-31-2009, 10:43 AM
Poagman's Avatar
Originally Posted by Cataphract View Post
I am also interested in finding out what is the color wheel speed on this PJ? I read the whole thread but have not seen the answer yet. It is not listed on the spec sheet either.
I think a 2X speed would definitely be a deal breaker for me. Same reason why I did not jump on the HC1600 deals.
Any ideas guys?
The X9 has a 4X colorwheel.
Poagman is offline
post #96 of 104 Old 07-31-2009, 10:48 AM
Poagman's Avatar
Originally Posted by EdBag4 View Post
Thanks KGBL, I have seen this one however it doesn't list a vertical offset, does that mean there isn't one?
Thanks again,
Ed
The InFocus Projection Calculator does calculate the image offset for you and can be found at http://www.infocus.com/ProjectionCal...tainment&pro=1
Also, the image offset for the X9 measures 119% (19% of image height will be the gap from top of screen to lens when level). You can however aim the projector up/down and use keystone correction to adjust if necessary. Keystoning should be avoided at all cost if possible though in order to maintain as sharp of an image as possible.
Poagman is offline
post #97 of 104 Old 07-07-2010, 01:09 PM
wickednebula's Avatar
the infocus x9 is back on sale at comp USA for 489.00 . that's a steal i love mine.
wickednebula is offline
post #98 of 104 Old 07-07-2010, 01:55 PM
spanner's Avatar
thanks for the post. I also love mine, with a 1500 hrs on the bulb and no problems what so ever. I am considering buying a second one
spanner is offline
post #99 of 104 Old 07-08-2010, 07:50 AM
Tiga's Avatar
I thought about jumping on this as well. Is it confirmed that it's a 4x color wheel? 2x wheels make my head explode. Thanks!
Tiga is offline
post #100 of 104 Old 07-18-2010, 09:38 AM
Tiga's Avatar
I still can't seem to confirm that this is a 4x color wheel. Can anyone clarify? I'm considering this as an upgrade to my Infocus IN72 - anyone seen both models that can comment if this is a worthwhile upgrade? Thanks!
Tiga is offline
post #101 of 104 Old 09-30-2010, 07:05 PM
Mark0's Avatar
Anyone know if the x9 is capable of 3d?
Mark0 is offline
post #102 of 104 Old 10-23-2013, 08:32 AM
THEPLOWKING's Avatar
My InFocus X9 looks like it has bit the bucket and died.
It powers on, display comes up, everything normal, then after about 10-15 seconds it suddenly shuts off. Tried reseting the bulb hours, but that didn't help. Will a new bulb fix this problem?
Note: I might be the long life bulb winner here. Original bulb and it has 6050 hours on it.
I NEVER ran it in econo mode, and it was run about 75% in movie mode / 25% PC mode(daytime viewing).
THEPLOWKING is offline
post #103 of 104 Old 10-23-2013, 08:38 AM
Also, This was a very reliable projector, I never once had an issue or problem with the X9.
post #104 of 104 Old 10-25-2013, 08:39 AM
spanner's Avatar
My X9 has become my backup/portable projector. This was also a reliable projector for me and at a great price at the time. My only problem was the contrast, especially in dark movies, but for game day it worked great. I am now using a optoma hd33 and love it. not sure if a new lamp will help you, Maybe you can find a working one with hours on it for a reasonable price to check.
spanner is offline
Pt Ae3000u Lcd 1080p Proj 60k 1 1600 Lumens Hdmi Component Svid
