*Official* Optoma HD20 Thread - Page 106 - AVS Forum | Home Theater Discussions And Reviews
 18Likes
Old 07-12-2011, 01:07 PM
Thirsty1258's Avatar
Quoted: 70 Post(s)
Thanks. That is correct only speciality shows are full hd.
Thirsty1258 is offline
Old 07-13-2011, 07:36 PM
Cinderella17's Avatar
Hello everybody can someone help me with some good calibration for this projector? cause I have too much darknest in the image... Thanx
Cinderella17 is offline
Old 07-13-2011, 07:40 PM
msgross's Avatar
Just picked up one of these from woot.com for $655... should meet my needs vs spending 2-3 times as much...
msgross is offline
Old 07-13-2011, 07:58 PM
bensons's Avatar
Looking hard at the Woot deal myself. Somewhat concerned with the 90-Day warranty. Was going to pull the trigger on an Epson 8350. The HD20 from Woot would be a huge savings.
We tried a couple Samsung RP units in 2005 and returned them due to RBE. Went with a Sony SXRD instead. Has DLP technology changed much since 2005? Think going with a DLP again is too risky?
Steven Benson
Minnesota Home Theater User Group (MNHTUG)
Yahoogroups | Facebook
bensons is offline
Old 07-13-2011, 08:11 PM
JukeBox360's Avatar
Quoted: 12 Post(s)
Liked: 53
I'm sure you could always buy a warranty no?
JukeBox360 is offline
Old 07-13-2011, 11:22 PM
tighr's Avatar
Quoted: 42 Post(s)
Liked: 80
I bought mine back in November from Woot, never looked back. The price is right, and its worked fantastic ever since.
~Tighr: Not helping the situation since 1983
tighr is offline
Old 07-14-2011, 08:13 AM
xenon2000's Avatar
Quoted: 17 Post(s)
You may want to view a current DLP projector in a store that has dark viewing room demos to see for yourself.
DLP RP TVs use the same DLP chips and tech as the front projectors. So often an RP will be the same Darkchip2 with 4x color wheel as most current DLP projectors. But, that doesn't mean the RBE will be the same as the screen material also affects contrast which can have a big affect on RBE.
I personally have found RBE on RPTVs to be annoying, yet I have not found the RBE to be annoying on my Front DLP projectors that use the same 4x speed color wheel, using screens 100-125". Not saying they don't have RBE, if I put on the right content and look for it, it's there. But even when looking for it, I really have to dart my eyes fast to see it and it's not an issue during normal viewing for me on DLP projectors.
But you will have to see for yourself. I like several things about DLP over LCD projectors right now, which is why I went DLP again this time around.
xenon2000 is offline
Old 07-14-2011, 01:41 PM
bigscreenHD's Avatar
Purchased HD20 June 17/11
Exactly 15 days later the bulb turned off while watching a bd. Place of purchase told me "good luck with that" and slammed the door shut in my face. Thanks Canada Computers.
Symptoms
HD20 powers up fine
Logo appears on screen
fan turns on
light turns off at 5min 50 sec
TROUBLE CODE : ON LED - flashes amber,
Lamp LED - solid red
Codes suggest lamp failure...however i can get this sequence of events to repeat after cycling power via removal of power cord...always lamp turns off at 5min 50 sec....mmm?
Called OPTOMA support and issued RMA, sent in bulb for replacement. Have been asking Optoma for extended warranty for some 14 days since failure...nobody there can help me purchase one....and still waiting for new bulb to arrive.
Summary
Pros
Nice picture when working
Cons
Shady Distributors
Brand new pj lasted a mere 15 days
Bulb had 40hrs logged on it.
Customer support helpful but slow to respond
No one at Optoma can help me purchase an extended warranty
Overall not a pleasant experience!! Will be my first and last Optoma purchase.
bigscreenHD is offline
Old 07-14-2011, 11:25 PM
mechbeav's Avatar
If you are powering up the PJ without waiting for the unit to cool down ( > 30 minutes) you will kill the lamp in any PJ. Not sure if you are doing that, just mentioning it.
I'm not sure you can get an extended warranty on the HD20 thru Optoma, might have to go through a 3rd party like Mack.
mechbeav is offline
Old 07-15-2011, 08:15 AM
boyopo's Avatar
Cool Projector
boyopo is offline
Old 07-15-2011, 09:58 AM
@mechbeav, cool down period was at least 30min between pj restart.
I am thinking that it may not have anything to do with the bulb. Checked continuity and all is good. The bulb restarts fine, runs for duration described above and then turns off..maybe a thermal sensor
Old 07-15-2011, 10:04 AM
Rew452's Avatar
Quoted: 106 Post(s)
Liked: 64
System also monitors current drawn by the lamp. This is more likley the problem. It probably means lamp has failed and needs to be replaced.
Sorry but it happens
Rew
Rew
Vizio P75-C1 | OPPO UDP-203 | Samsung UBD-K8500
Denon AVR-x5200w | Nvidia Shield Android TV | C =Axiom VP150 |FL/FR =Axiom M60 |SL/SR =Axiom QS4 |TFL/TFR =Bose 161 | TRL/TRR =Bose 161 |Sub =Reaction Audio S-15 500W SEALED SUBWOOFER
Rew452 is offline
Old 07-15-2011, 10:17 AM
Good call Rew, didn't think of that possibility. I will provide update once the new bulb arrives.
cheers
Old 07-18-2011, 07:32 AM
krackato's Avatar
What kind of mounts are you guys using with the HD20?
I originally was using a mount from Monoprice: http://www.monoprice.com/products/pr...seq=1&format=2
It worked okay, but it's fairly cheap. A small piece of it broke and it also seems to have a hard time tilting up and down, something that the box says it should be able to do, but if there's a way to do it, I haven't figured it out.
I was thinking of getting the "VideoSecu Universal LCD/DLP Projector Vaulted Ceiling Mount Bracket Black with 25.6" extension pole PJ2B 1C9" - http://www.amazon.com/VideoSecu-Univ...srch_res_rtr_8
But that's mostly because it seems affordable at $35, and has 56 reviews on Amazon and is currently at 4 stars. Only problem is it looks a little ugly IMO (like some kind of evil droid out of Empire Strikes Back...)
What do you guys think about the VideoSecu mount?
krackato is offline
Old 07-18-2011, 09:31 AM
tighr's Avatar
Quoted: 42 Post(s)
Liked: 80
Originally Posted by krackato View Post
I originally was using a mount from Monoprice. It worked okay, but it's fairly cheap. A small piece of it broke and it also seems to have a hard time tilting up and down, something that the box says it should be able to do, but if there's a way to do it, I haven't figured it out.
I'm using that exact monoprice mount. Even though the box says tilt adjust, I think that was a feature of a previous revision, because mine doesn't tilt at all (it's actually a solid piece). The mounting plate itself is also warped (I placed it on a flat surface), so my image is a little off-center and there's not much I can do about it. I haven't worried about it much because I got it just about perfect as long as nobody touches it, so it hasn't had a hand on it since the Super Bowl.
I bought it because the price was right, but I'd be interested in an upgrade, myself.
tighr is offline
Old 07-18-2011, 01:33 PM
99TJ's Avatar
Just wondering about the ceiling paint. If I were to paint the ceiling a ceiling white color, will the picture be ok? My HD20 is going to be ceiling mounted.
99TJ is offline
Old 07-18-2011, 05:15 PM
hyperactiveme's Avatar
Quoted: 119 Post(s)
Liked: 72
I went from white to black and never noticed a difference. Both paints where matte finish. White ceiling gave it a more multi purpose room feel whereas black gave it a real HT feel.
The picture will be the same but may be perceived as having weaker blacks. What color is your ceiling now?
hyperactiveme is offline
Old 07-18-2011, 05:48 PM
99TJ's Avatar
Just finished taping and sanding, priemer is going on soon then paint.
99TJ is offline
Old 07-18-2011, 05:51 PM
JukeBox360's Avatar
Quoted: 12 Post(s)
Liked: 53
Problmes with this set? Considering buying for a decent price.
Old 07-18-2011, 06:02 PM
Bryan withaY's Avatar
This is what I have.
http://www.mountdirect.com/Projector...ries_p/npl.htm
The pictures do not do it justice. Solid mount, powder coated, easy to install and adjust. Extensions are also available or you can use your own (1 1/2" NPT pipe).
Bryan withaY is offline
Old 07-18-2011, 06:57 PM
Quoted: 119 Post(s)
Liked: 72
Very nice mount. I have the cheapo from monoprice. If I had to do it again I wouldn't buy it.
If you want to go black in the future please don't texture your ceiling. What a PITA to paint
Old 07-18-2011, 07:04 PM
luna digital's Avatar
I have the same cheapo from mono price and I would probably pass on it as well. it constantly slips and I have to re-adjust it.
luna digital is offline
Old 07-19-2011, 06:44 AM
Peter_'s Avatar
I would like to ask a favor, play both video tests and look how much of Dynamic Resolution it has.
Link: Test 1.mp4
Link: Test 2.mp4
Please tell me what resolution the projector begins to mess the lines.
Thank you,
Peter.
Peter_ is offline
Old 07-19-2011, 08:05 AM
xenon2000's Avatar
Quoted: 17 Post(s)
Curious, how close is your screen to your ceiling? And I am guessing your walls are dark since you painted the ceiling dark. My ceiling is very close to the top of my screen and while I still have a light ceiling, I am certain that I get a lot of light back on the top of my screen from my light ceiling.
Old 07-19-2011, 03:14 PM
Quoted: 119 Post(s)
Liked: 72
I'm about a foot from the ceiling and yes my walls are a dark grey.
Old 07-20-2011, 10:44 AM
Update to lamp failing at 40hrs....
Received and installed new bulb from Optoma yesterday afternoon. Noticeable lamp flicker after power-up but disappeared after running on high for a couple of hours. Ran Avatar and all looks to be fine.
Old 07-20-2011, 01:20 PM
menkelis's Avatar
I just bought a HD20 to replace my cealing mounted EP719 projector.
I have the HD20 mounted, and replaced the old 4:3 screen with a new 16:9 screen.
Everything is almost perfect with the display except that there is a slight
horizontal tilt that I can not correct. If I get the bottom of the screen level
then the top is tilted.
I tried the keystone correction but that does not completly get the edge straght.
I am at a loss now, Could someone could please suggest some possable actions
that I might try. I suspect that I might need to ether change the progector height
or move the screen a bit.
BTW, I got the projector on E-Bay as it was listed as "broken / for parts" for $340.
The problem being listed was "projector turns off" after displaying "bulb at end of life".
After a complete cleaning and replacing the bulb ($110) I ran a "service mode burn-in"
for 11 hours without a problem.
menkelis is offline
Old 07-20-2011, 01:35 PM
dbshelton's Avatar
Is the projector square with the screen?
dbshelton is offline
Old 07-20-2011, 11:29 PM
menkelis's Avatar
I will re-check this.
I have put in a link to photo of the screen.
Look in the lower right corner.
http://photo2.walgreens.com/walgreen...AME=walgreens/
menkelis is offline
Old 07-20-2011, 11:40 PM
JukeBox360's Avatar
Quoted: 12 Post(s)
Liked: 53
Your link doesn't work
Optoma Hd20 Dlp 1080p Home Theater Projector
