*Official* Optoma HD20 Thread - Page 111 - AVS Forum | Home Theater Discussions And Reviews
 18Likes
post #3301 of 4170 Old 10-01-2011, 10:26 AM
hyperactiveme's Avatar
Quoted: 119 Post(s)
Liked: 73
I dont see what the Xbox settings are. I think that's the issue and they need to be posted.
Reset it to default http://support.xbox.com:80/en-US/xbo...oot/kb/xbox-kb
See if it works. Or try basic settings.
Console setting
- HDTV: 480
- Reference: standard
- HDMI color space: Source
I tried HDMI amplified switch from monoprice. Horrible results. I ended up buying a new pioneer AVR and all worked out.
hyperactiveme is offline
post #3302 of 4170 Old 10-01-2011, 11:40 AM
cream puff's Avatar
Console setting
- HDTV: 480
I have this one, works like a charm with my xbox and HD20
cream puff is offline
post #3303 of 4170 Old 10-01-2011, 05:25 PM
tighr's Avatar
Quoted: 43 Post(s)
Liked: 83
So speaking of video games. I just tried hooking up my Nintendo 64 directly to the composite input, and I get nothing. I get audio out of my stereo, so I know that the Nintendo is on, but its not getting a video signal. Worked fine on another TV.
I did a google search, and it appears someone else had the same question earlier in this thread, but it was never resolved. I could find no other info on this. Anyone else get their Nintendo 64 to work?
~Tighr: Not helping the situation since 1983
tighr is offline
post #3304 of 4170 Old 10-01-2011, 05:28 PM
msgross's Avatar
hard to say... If you had a receiver that did video upscaling then I bet it would work..
msgross is offline
post #3305 of 4170 Old 10-01-2011, 06:04 PM
tighr's Avatar
Quoted: 43 Post(s)
Liked: 83
Well yeah.
Don't have one.
tighr is offline
post #3306 of 4170 Old 10-02-2011, 04:16 AM
aggoodin's Avatar
Lol N64.... Just let it die! Its not as fun as you remember. I have one with Goldeneye and Perfect Dark and Mario Kart. Its has nearly unplayable graphics and its incredibly repetitive.
DIY Theatre room 10'x11'- Integra 30.7, Outlaw 5000, Pioneer BDP-51FD, PS4, DIY HTPC, PS4, Clark Synthesis TST209's, Sealed 15" HO Dayton/iNuke 3000dsp, 2 SVS SB-12NSD's, Fusion Tempest 12 L/R, 88 Special C, Volt 6 R, TDG NFC-83 ATMOS x2, BenQ HT2050, SilverTicket 106", Darbee.
aggoodin is offline
post #3307 of 4170 Old 10-02-2011, 08:22 AM
xenon2000's Avatar
Quoted: 17 Post(s)
Nope, the N64 via composite will not work with the HD20. Sorry. You either need to buy an S-video cable for your N64, an AVr or other signal converter.
xenon2000 is offline
post #3308 of 4170 Old 10-02-2011, 10:38 AM
tighr's Avatar
Quoted: 43 Post(s)
Liked: 83
Looked just fine on my 56" HDTV (and my 27" sdtv) when I played Goldeneye yesterday. Nostalgia is great!
tighr is offline
post #3309 of 4170 Old 10-03-2011, 05:51 AM
Knolan33's Avatar
It sounds like he has a 50ft cable, but is having problems with his Xbox signal. He has tried two different repeaters to boost the signal to no avail.
Not sure the repeater will have much effect, since its at either end of the 50ft run. What you may want to do is get a higher quality cable than the one you're currently using, as Xenon suggests.
Is 50 ft the shortest run you can use? How far away is the projector? Mine is 16 feet away and I'm able to use a 30ft monoprice cable, with absolutely zero issues. It even has a 6ft connection on both ends (wall plates), for a total of 42 feet with two connectors.
I have a 50ft cable (due to the fact I couldn't pass the cable in the ceiling the whole way...finished ceiling and not enough space to pass it). Otherwise I could have used a 30ft even 25ft no problems. And I had to use a repeater to boost the signal from the Xbox...the dish worked fine but the Xbox signal was full of noise. So now I have a 3ft cable from the Xbox to a hdmi switch...50ft to the repeater and a 6ft to the HD20.
The picture is good...but on fully black screen such a Gears startup...you can see small lines in the screen...now it's not visible during game play or movies...but I'm wondering just how much quality I'm losing due to this.
Like I said I'd debating on trying the Xbox with a short cable to see if this still occurs...if so. Well then I'll have try and find a solution. The cable doesn't seem to be the issue as I had no problems with the dish signal.
The Xbox is an older 60gig unit as well...could be an issue, but I'm going to try different things to see what I can get out of it.
Knolan 33
Only live once...make the most of it
http://www.avsforum.com/avs-vb/showthread.php?t=1339145
Knolan33 is offline
post #3310 of 4170 Old 10-09-2011, 10:52 AM
Godfazzer's Avatar
Hello! please help me
is this video noise normal? http://www.youtube.com/watch?v=C6r3aJmEIyo
it is highly noticeable on grey color, even without any input it has same noise on menu
Godfazzer is offline
post #3311 of 4170 Old 10-09-2011, 01:05 PM
aggoodin's Avatar
Are you talking about the sparkles?
aggoodin is offline
post #3312 of 4170 Old 10-09-2011, 01:15 PM
Godfazzer's Avatar
Yes, it is has size of one pixel, and flashing very fast
post #3313 of 4170 Old 10-09-2011, 01:35 PM
aggoodin's Avatar
Its a bad HDMI cable I have a 3ft monoprice HDMI thats a sparkle cable.
aggoodin is offline
post #3314 of 4170 Old 10-09-2011, 01:47 PM
Godfazzer's Avatar
but even when i disconnect hdmi it is the same
post #3315 of 4170 Old 10-09-2011, 01:55 PM
aggoodin's Avatar
Better close your eyes!
aggoodin is offline
post #3316 of 4170 Old 10-09-2011, 02:03 PM
Godfazzer's Avatar
what do you mean?
post #3317 of 4170 Old 10-09-2011, 05:04 PM
aggoodin's Avatar
what do you mean?
If it isn't the cable its the unit. Firmware is only available from Optoma if you ship it in.
aggoodin is offline
post #3318 of 4170 Old 10-10-2011, 07:11 AM
xenon2000's Avatar
Quoted: 17 Post(s)
As many have already said. Yes, it is normal. The little fire fly like noise is normal and common of many low cost and even higher cost DLP projectors.
Now the moving bars is not normal. But I suspect that is simply the refresh rate of the camera and projector fighting each other.
But also notice how close you have to get to see that noise. I NEVER see it on my 125" screen at normal seating distance. I too have to be about 2 feet from it in person to see it.
I would be shocked if any firmware would change it as it's heavily part of the video processor and likely the chipset not firmware.
FYI, I have seen this digital noise on many projectors for years. But remember, you shouldn't notice or even be able to pick it out from normal viewing distance. If you do, I would adjust your settings because you likely have sharpness and/or brightness too high.
post #3319 of 4170 Old 10-12-2011, 06:38 AM
mcnizzel's Avatar
I realize there is a sale section here, but I figured it would be most productive to post here.
I have an optoma HD20 for sale! it has 55 hours on it, and was purchased right around two months ago. My wife has changed her mind about our basement set up, and I'm going to have to get an 8350 for lens shift to keep my theater.
there is nothing wrong with this projector, well taken care of, no scuffs, drops, or anything bad has happened to it. comes with everything, cord, remote, box, etc. I'm entertaining offers, anything reasonable will be accepted. if you have any questions please feel free to PM me.
I know the hd20 is a great budget choice, its why I bought it, but if here is your chance to be even more economical and help out a fellow member at the same time!
*EDIT*
I didn't realize you had to pay to list an item for sale, out of courtesy to the community I have purchased an ad in the appropriate section as well. http://www.avsforum.com/avs-vb/vbcla...do=ad&id=16374
mcnizzel is offline
post #3320 of 4170 Old 10-13-2011, 05:38 AM
cacophonix's Avatar
Quoted: 30 Post(s)
I recently bought a HD20 and am looking to mount it on the wall. I've vaulted ceiling, and can't mount it on there as i also have a ceiling fan. What wall mounts have you guys used? I bought a Vantage Point CGUPM6 from frys but it didn't work. It sucks that almost no other retail stores carry projector mounts here in dallas metroplex.
So can anyone recommend any good wall projector mounts?
cacophonix is online now
post #3321 of 4170 Old 10-13-2011, 06:02 AM
Knolan33's Avatar
Well I have order an adapter for the HDMI switch to see what this will do, and I also did some calibration finally last night.
Used the one from "custard" or something like that. Seems to have help the "noise" pixels I was seeing, but now I find it is almost to "black" on the blacks. Might have to play around with a little more, could just be that the brightness was just to high from what it is now...went from 50 OTB to 38 with the calibration.
Knolan 33
Knolan33 is offline
post #3322 of 4170 Old 10-13-2011, 07:27 AM
mechbeav's Avatar
Why would that stop you?
http://www.projectorsuperstore.com/images/UPM50.jpg
Most wall mounts for inverted setups I've seen are regular ceiling mounts with some sort of DIY bracket to hang it off the wall.
mechbeav is offline
post #3323 of 4170 Old 10-13-2011, 02:26 PM
cacophonix's Avatar
Quoted: 30 Post(s)
My room is fairly small ... with a throw distance of 14'. And my screen is 92". So i want the projector to be as far back as possible. And i've a inwall speaker installed in the vaulted ceiling just above the place where i want to wall mount my projector. So if i try to mount it on the ceiling, i'll be hanging it right in front of the speaker ... so thought wall mount is my best option.
post #3324 of 4170 Old 10-13-2011, 03:51 PM
mechbeav's Avatar
Cacophonix - that sounds reasonable, but 14ft throw won't work. With a 92" 16x9 screen the max throw distance for the HD20 is 12 ft.
http://www.projectorcentral.com/Opto...ulator-pro.htm
For the inverted wall mount I would install a shelf and use a ceiling mount below it.
mechbeav is offline
post #3325 of 4170 Old 10-14-2011, 06:56 AM
xenon2000's Avatar
Quoted: 17 Post(s)
As others have said, 14' is too far for a 92" screen. User the Projector Central calculator.
http://www.projectorcentral.com/proj...ulator-pro.cfm
The HD20, like many low cost DLP projectors; does not have lens shift and the zoom range is tiny.
With a 92" screen, I would recommend putting the HD20 as close to the screen as possible and putting it on a coffee table. For 92" screen you can put it 10' away. Of course that would put your large seating at the back of the room and then split seating to both sides of the projector.
The projector will always project upwards. So either close to the ceiling or close to the floor are your only options and little variation in distance from the screen.
post #3326 of 4170 Old 10-15-2011, 10:22 AM
Bryan withaY's Avatar
Not that you'll use this mount in your situation but just wanted to point out that this mount works perfect with the HD20.
http://www.mountdirect.com/NPL_Proje...nt_p/npl_w.htm
It's solid and easy to adjust and level. If you ever move your projector where you can use a ceiling mount you can just reuse this one by simply not using the elbow.
Bryan withaY is offline
post #3327 of 4170 Old 10-18-2011, 08:49 PM
clintonk's Avatar
Yes I have the same issue. I just bought the HD200-X from Costco, replacing an older Toshiba model. I am frustrated with 2 things:
1) trying to find a ceiling mount that actually fits and works. The mounting holes are 3mm (small) and the configuration is a small triangle, which most mounts are too big to even fit the mounting holes. I found a mount that works, but the adjustments are brutal.
2) I too see horizontal lines when I have a black screen or when I plug in my wii console. I googled the issue and a lot of discussion came up about checking the ground or wire connections. But I never had this issue with my last projector. Not sure whats up. I thought maybe its my display settings but I don't think it is.
Originally Posted by Knolan33 View Post
Does anyone else see small lines when the screen is only black such as booting up a game on the Xbox?
Just like small picture lines, not noise or flickers...
clintonk is offline
post #3328 of 4170 Old 10-18-2011, 09:32 PM
cacophonix's Avatar
Quoted: 30 Post(s)
xenon2000, you are absolutely right. I am new to the whole projection thing, and didn't think through. The image totally blows my mind, but the placement options are very limited. I really don't want to split my seating, and don't want to mount it in a place that people can bump into.
Maybe i should settle for the coffee table approach whenever i'm watching a movie, and keep it aside when not in use. Inconvenient, but maybe that's all i can do.
post #3329 of 4170 Old 10-19-2011, 04:39 AM
Knolan33's Avatar
I actually calibrated the HD20 a bit, not sure how good it is, but it's seems to have limited the lines...
Like xenon said it seems to be extremely noticeable if the brightness and such is to high. I haven't had the chance to play around with the difference way of connecting it, as the repeater and such are in the ceiling. But once I start working on my A/V rack and such, I'll provide feedback if there is any changes
Knolan 33
Knolan33 is offline
post #3330 of 4170 Old 10-19-2011, 06:52 AM
xenon2000's Avatar
Quoted: 17 Post(s)
Yes, with limited distance and zero offset adjustments, it has to be either above the image or below the image. So those are your only options. I personally think you should spend the time to ceiling mount it. But if that just isn't an option, the table option is the only option left. And even if you had the zoom range to put it at your back wall, you would still need a large amount of lens shift and you have zero with the HD20.
LCD is really the only low cost solution for greater placement flexibility right now.
Optoma Hd20 Dlp 1080p Home Theater Projector
