*Official* Optoma HD20 Thread - Page 112 - AVS Forum | Home Theater Discussions And Reviews
 18Likes
post #3331 of 4170 Old 10-19-2011, 06:58 AM
xenon2000's Avatar
Quoted: 17 Post(s)
FYI, I currently only use HDMI, VGA, and Component through an Onkyo AVR, using an HTPC, 360, PS3, and Wii. And I do not have any lines at any distance and I don't see the DLP "Sparkle" unless I am unwatchably close to the screen.
xenon2000 is offline
post #3332 of 4170 Old 10-29-2011, 12:03 PM
apilon's Avatar
Quoted: 35 Post(s)
Good day
My room is 10 X 13 and althought i can control ambient light the room is not totally black because of the light bleeding from the vent of the HD20.
Is there any tricks that can be done to contain the bleeding of the lamp light without jeopardizing the projector ?
Alain Pilon
Montreal, Quebec
apilon is offline
post #3333 of 4170 Old 10-30-2011, 08:17 AM
xenon2000's Avatar
Quoted: 17 Post(s)
Originally Posted by apilon View Post
Good day
Alain <
I have said this before. The light bleed from the vents is not affecting the image contrast. Way more bounce is created from the light off the screen and the surrounding areas. Unless you literally have dark walls, floor, ceiling, furniture, and no reflective items in the room. And even then, the light bleed from the HD20 is so minimal it does not affect the image.
Here is an easy test, you temporarily block the light bleed using some cardboard or other material while you have a movie playing. I have done this test and can not see any difference on the screen.
I have ultra dark walls and furniture. But my ceiling is flat tan. Though my ceiling is also pretty far from my screen and if my ceiling was affecting my image, I would see some form of wash out that is greater at the top. And I don't.
Also, the smaller the room, the more important it is that you have dark colored walls, ceiling, and furniture.
Do the test and be satisfied; then look at the rest of the environment.
post #3334 of 4170 Old 10-30-2011, 09:54 AM
petetherock's Avatar
Quoted: 1194 Post(s)
Liked: 617
Hi
I am considering coming back to projectors (last one I used was an old Infocus 4805).
I will be seated about 3m from the screen, which is a hand me down manual 82" Da-lite. This will be suspended from a 3m ceiling, and the bottom of the screen will be about 90cm from the floor.
I intend to use the HD 20 on a coffee table, placed in front of my sofa.
So
How high should the table or more accurately, the HD 20 be?
If I use if on a shelf behind my sofa, is that ok and how high should it be?
Any issues with using such a temporary kind of placement?
petetherock is online now
post #3335 of 4170 Old 10-31-2011, 07:27 AM
xenon2000's Avatar
Quoted: 17 Post(s)
Originally Posted by petetherock View Post
Hi
So
Man, I loved my HD70 a ton over my Infocus 4805. So you should be very happy jumping to the HD20.
If you haven't used the Projector Centrol calculator before, I would use that.
http://www.projectorcentral.com/proj...ulator-pro.cfm
Then once you pull up the HD20 and set it to an 82" screen, it will show you the range of distance you can place the HD20 and also show you the offset from the center of the lens to the edge of the projected image. From there, should be easy to check the height of your coffee table and where it would need to be placed and where your screen bottom would end up, etc.
post #3336 of 4170 Old 10-31-2011, 08:58 AM
Liked: 617
Thanks, I tried it, and it calculated that the Optoma should be 6.4" below the screen?
Since my screen ends up about 90 cm from the floor, the projector could be sited on an Ikea "Freden" shelving, directly behind my seat then?
post #3337 of 4170 Old 11-01-2011, 07:12 AM
xenon2000's Avatar
Quoted: 17 Post(s)
I am not saying where you have to put it. But the calculator says for an 82" screen that the offset is 6.4" from lens center. And that it has to be within 8'11" to 10'9" away. You can have it below the screen or above the screen. But within those numbers.
If that means behind your seating distance, then I recommend ceiling mount. If you can not do that, then obviously you have to have no seating in the middle where the projector is casting the image.
post #3338 of 4170 Old 11-03-2011, 10:40 AM
99TJ's Avatar
I purchased the optoma hd20, my 84" manual pulldown screen just arrived the other day.
Question is though:
How do I mount the screen so it lines up properly with the sides of the projector image?
I already have the projector ceiling mounted but I am alittle worried that if I just try to install it that I wont line the sides of the screen up properly to the image.
99TJ is offline
post #3339 of 4170 Old 11-03-2011, 10:54 AM
cobolisdead's Avatar
Quoted: 49 Post(s)
Get a level.
Quis custodiet ipsos custodes?
cobolisdead is offline
post #3340 of 4170 Old 11-03-2011, 11:15 AM
dulewis's Avatar
Can any of you HD20 owners confirm that it will or will not work with a Pioneer VSX33 AVR? My HD65 and the Pio will not work together and I'm looking for a cheap yet effective upgrade option.
dulewis is offline
post #3341 of 4170 Old 11-03-2011, 11:23 AM
dulewis's Avatar
Question is though:
We'll assume you already have your screen to projector distance calculated and correct so just use one of your side walls as a reference. The center of the lens to side wall measurement should equal the center of your screen to the same side wall measurement. Hope that helps.
dulewis is offline
post #3342 of 4170 Old 11-03-2011, 02:38 PM
adrift's Avatar
Got a question, and wondering if anyone else has noticed this before too. I'm pretty sure others have mentioned it, but can't remember...
Is anyone else finding that, depending on what unit they turn on first, the projector projects, for lack of better word, dimly? For instance, if I turn on my receiver first, and then turn on my projector (I think that's the order), the picture is fairly bright (for as many hours are on the current bulb), but if I turn the HD20 on first, and then the receiver, the image is far less bright.
I suppose the solution is to always make sure I turn on one device before the other, but does anyone know what's going on here? Why is it doing that?
Okay, that's all. Thanks.
adrift is offline
post #3343 of 4170 Old 11-03-2011, 11:26 PM
hyperactiveme's Avatar
Quoted: 119 Post(s)
Liked: 73
Worked flawless with my vsx-520 and vsx-820
hyperactiveme is offline
post #3344 of 4170 Old 11-04-2011, 07:17 AM
xenon2000's Avatar
Quoted: 17 Post(s)
I have been in this thread pretty much from the beginning and I don't recall ever hearing that issue. My HD20 does not act like that.
My HD20 and previous HD70 and the Mitsubishi DLPs at work all project dimly for about 30 secs (would need to time) and then go bright and then it searches for the source and projects the source image. And all of these do so regardless of my AVRs in place or not. Turned on first or not. Source available or not, and regardless of the type of source.
Maybe I am misinterpreting your issue. Maybe you are saying that you do have the dim->bright startup with the logo->source process like the rest of us. But that when it's in the fully started up mode with the source projected that it continues to be dimmer unless you have your AVR and source on first?
When you think it's dimmer, have you checked to see if there is a variation in the bulb brightness mode? And that AI is off?
post #3345 of 4170 Old 11-04-2011, 07:21 AM
xenon2000's Avatar
Quoted: 17 Post(s)
Question is though:
I am probably stating the obvious, but make sure you projector is on while you use 2 people or more, to hold up the extended screen and mark your locations for mounting. Also make sure you are not at full zoom in or out. You will want to be able to have at least some zoom to bleed into the black border a little if you need to.
If you are directly mounting the pull down screen to the wall or ceiling, that will certainly make it easier then if the "box" is hanging from the ceiling.
post #3346 of 4170 Old 11-13-2011, 08:04 AM
Wy2sl0's Avatar
Quoted: 30 Post(s)
Hi everyone. I bought my first projector this week and finally got it installed. It was a refurb unit from Consignia with a two year extended warranty.
I noticed a few things though. 1) it is almost impossible to get perfect focus on the entire image when I am using the projector as a text reading screen on the web.
2) The bottom left corner is darker than rest of the image (I have it mounted upside down at the top of the room)
Any ideas or is this just normal? I can live with it, it isn't terrible. Although the focus problem is annoying. I am using it in my bedroom with a 73" screen and 8ft throw distance.
Wy2sl0 is offline
post #3347 of 4170 Old 11-13-2011, 11:48 AM
adrift's Avatar
Are you using a PC to read text off the web, or are you getting on the web some other way? For a PC loaded with Windows you might want to tweak your ClearType Text settings. It won't affect the focus on the screen, but it should help make text easier to read even if the focus is a little off. If that doesn't work, you might need to readjust the placement of the projector a bit to get better focus across the image.
adrift is offline
post #3348 of 4170 Old 11-13-2011, 01:35 PM
Wy2sl0's Avatar
Quoted: 30 Post(s)
I have moved the projector around, but I can't get perfect focus. The way the focus is working, is either the Top left is in perfect focus, or the bottom right is in perfect focus. I know my screen isn't 110% flat, but even against my wall the same problem is there, just not quite as bad.
Could it be a lens issue? Or is this just normal?
Wy2sl0 is offline
post #3349 of 4170 Old 11-13-2011, 01:59 PM
local5o's Avatar
Does anyone have any screen shots of Hockey on thier HD20?
local5o is offline
post #3350 of 4170 Old 11-13-2011, 02:03 PM
aggoodin's Avatar
What browser are you using? Chrome looks like its made for reading on massive screens. IE is OK and Firefox blows on the big screen for readability.
DIY Theatre room 10'x11'- Integra 30.7, Outlaw 5000, Pioneer BDP-51FD, PS4, DIY HTPC, PS4, Clark Synthesis TST209's, Sealed 15" HO Dayton/iNuke 3000dsp, 2 SVS SB-12NSD's, Fusion Tempest 12 L/R, 88 Special C, Volt 6 R, TDG NFC-83 ATMOS x2, BenQ HT2050, SilverTicket 106", Darbee.
aggoodin is offline
post #3351 of 4170 Old 11-13-2011, 07:13 PM
Wy2sl0's Avatar
Quoted: 30 Post(s)
It isnt to the point of where I can't read, it is just soft. I can tell in Windows or anywhere there is text. If you just watched movies, I would venture that 90% of people wouldn't notice this. However if you are watching 1080p content and like your image sharp like I do, its definetly noticeable.
Wy2sl0 is offline
post #3352 of 4170 Old 11-13-2011, 08:57 PM
tighr's Avatar
Quoted: 43 Post(s)
Liked: 83
Check the resolution your computer is pumping out. If its not 1920x1080, it needs to be.
Also, 73" is the maximum size at full zoom for an 8' throw distance. At that zoom, you have absolutely no margin for focus. I would try and do a smaller screen or see if you can move the projector back. For 8', you should be aiming for 67".
http://www.projectorcentral.com/Opto...calculator.htm
~Tighr: Not helping the situation since 1983
tighr is offline
post #3353 of 4170 Old 11-14-2011, 05:23 AM
Wy2sl0's Avatar
Quoted: 30 Post(s)
Yes I understand that. There is however a problem with the lens that is only focuses the top right or bottom left though. Even with zero zoom, the problem is still present.
Wy2sl0 is offline
post #3354 of 4170 Old 11-14-2011, 05:50 AM
Quoted: 119 Post(s)
Liked: 73
No but I can get some next broadcast. What are you looking for?
post #3355 of 4170 Old 11-14-2011, 10:51 AM
local5o's Avatar
HYPER---Just getting ready to pull the trigger on an HD20 and would love to see some hockey pics. It will be used mainly for me and the guys watching Red Wings and my son and his friends with PS3. Occasional movie as well. Any pics would be great. Also screen recommendations would be great. Thanks!!!
local5o is offline
post #3356 of 4170 Old 11-15-2011, 05:07 AM
Quoted: 119 Post(s)
Liked: 73
Hockey looks fantastic, however the Hd20 won't make your red wings look any better :-)
A lot has to do with your room dynamics too. You need to give more info or tell us if you've looked into what you need to have a projector friendly environment.
I just used a painted DIY screen.
post #3357 of 4170 Old 11-15-2011, 12:03 PM
local5o's Avatar
Hyper---prob gonna do the painted screen as well, but not sure yet. The room is around 19x19 with decent light control and 8' ceiling.
local5o is offline
post #3358 of 4170 Old 11-15-2011, 02:36 PM
Quoted: 119 Post(s)
Liked: 73
Your good to go then. As far as DIY painted screen, ill pm you.
post #3359 of 4170 Old 11-16-2011, 05:35 PM
luna digital's Avatar
I would also like a PM on the DIY painted screen. I have an old 106 pulldown that has a nasty scratch and I have been watching my HD20 on my light brown wall. I am seriously considering sanding and painting it but have NO idea where to start.
luna digital is offline
post #3360 of 4170 Old 11-16-2011, 05:39 PM
Good day
Alain <
Try getting a block of black felt and mounting it to the ceiling above the projector. It is great for absorbing light. I have my ceiling painted black so the felt blends in nicely and you don't even notice it. I did it primarily because it bugged me seeing the light bouncing off the ceiling. I don't think it really caused any contract issues, it was just me being OCD I guess.
Optoma Hd20 Dlp 1080p Home Theater Projector
