*Official* Optoma HD20 Thread - Page 114 - AVS Forum | Home Theater Discussions And Reviews
 18Likes
post #3391 of 4170 Old 11-22-2011, 12:08 PM
cobolisdead's Avatar
Quoted: 49 Post(s)
Some of you guys just need to crank the sound up. I sit with the Projector about 1-2' away from my head, and I have never noticed any noise from it.
Quis custodiet ipsos custodes?
cobolisdead is offline
post #3392 of 4170 Old 11-22-2011, 03:11 PM
adrift's Avatar
Originally Posted by JamesVG81 View Post
It's ceiling mounted. I have the bulb on low with AI turned off. It's still pretty loud to me. It's at the top of a 8 foot ceiling. Like I said once the movie is going it doesn't bother me really. Can't wait to get my screen to go with this. Even though the screen will be as much as I paid for the projector lol
Check to make sure "High Altitude" is set to off.
adrift is offline
post #3393 of 4170 Old 11-22-2011, 03:23 PM
JamesVG81's Avatar
Quoted: 66 Post(s)
Liked: 39
Yea it's off.
JamesVG81 is offline
post #3394 of 4170 Old 11-22-2011, 03:40 PM
adrift's Avatar
Yea it's off.
Ah. Well it was a thought. Someone on Amazon.com complained about how loud the HD20 was that he owned for about a year. He knocked a couple stars off of it for loudness. I mentioned the Brightness, and High Altitude setting to him, and it turns out that somehow the High Altitude got turned on by accident (or by default). Poor guy.
Anyways, it shouldn't be that loud without those on, but who knows... we all gauge these things differently I guess.
adrift is offline
post #3395 of 4170 Old 11-22-2011, 03:50 PM
JamesVG81's Avatar
Quoted: 66 Post(s)
Liked: 39
Yea if I knock up the brightness I can really hear it. I don't Turn my system up very loud. I'm not a I need the house to shake when I'm watching a movie kind of person.
post #3396 of 4170 Old 11-23-2011, 06:13 AM
xenon2000's Avatar
Quoted: 17 Post(s)
Yea it's off.
Well, if it's really running at low fan speed and it's not defective; then at least it's good you got the HD20 and not many other projectors. Many projectors are much louder. If it really is louder than your PS3 or 360, you may want to consider that it's possibly defective. As I have mentioned before, even if my HD20 is literally the only device on in the dead of night, I can hear it, but barely. Certainly not what I would call noisy. And if I turn on any sound at a quiet level, I don't notice the HD20.
I just thought of something else. The environment. Do you have carpet floors or a hard material? I have carpet. Curious if maybe some acoustic treatments might help reduce the noise.
xenon2000 is offline
post #3397 of 4170 Old 11-23-2011, 06:41 AM
JamesVG81's Avatar
Quoted: 66 Post(s)
Liked: 39
Yea the room isn't finished all the way yet. Does have carpet but the sound in the room is pretty sharp at the moment. Nothing on the walls and no ceiling at the moment lol.
post #3398 of 4170 Old 11-26-2011, 01:11 PM
bazual's Avatar
Hi Folks,
First post here, I have an Optoma HD200x which is starting to run into a few problems. The image is starting to appear blotchy even with the High Altitude setting turned on.
I have the projector since April 2010 and had to send it to Optoma in January 2011 due to the blue flickering issue. They responded that it was a build up of dust etc and this was causing the issue. Of course the lamp hours was reset in January and I believe it was about 1000 at the time and I have clocked up 1500 since then. It is not on the bright setting or high altitude so I do no think its a replacement bulb issue hopefully.
I am wondering could this be another dust issue, I do notice a slight flickering of the white box in the corner when source are changing so this leads me to believe that it could be dust causing the blotchyness. I was going to follow the instructions posted in this thread #post19956757 in relation to cleaning dust etc.
Does anyone have any opinions of what might be causing the issue or is the general consensus that its a dust thing?
Thanks for your help.
bazual is offline
post #3399 of 4170 Old 12-12-2011, 08:56 AM
Daaku's Avatar
Hi,
I have a Optoma HD20 and bought a Sony Google TV Blu Ray player. When i play my Blurays on the Sony Goo TV player some of the Blurays play at 1080P 60hz and some on 1080P 24hz. The youtube and other application do play on 1080P 24hz. I do see a flickering on the movies that pay on 1080P 24 hz. Is this a limitation on the Bluray or the Sony player. Is there a way to convert the pictures to 60hz from 24hz. When there is a scene change i can also see that the screen getting brighter or duller after a couple of secs.
The Sony Google player is connected to the Bose Lifestyle V35 which is connected to the Optoma HD 20 projector. I just bought this projector only reason that we choose this player is that it comes with a full blown browser and also a blu ray player. HDMI cable is a 50 ft cable (Blurigger CFL rated)and according to the description on Amazon it supports upto 340Mhz or 10.2gbps. Suggest me how to improve the quality of the picture.
Daaku is offline
post #3400 of 4170 Old 12-13-2011, 05:50 AM
xenon2000's Avatar
Quoted: 17 Post(s)
Originally Posted by Daaku View Post
Hi,
Unless the player has frame interpolation options and some displays do, but the HD 20 does not; then the player will output what the BD disc is authored as. Most BD content is 1080 24p native. So your player would output that and the HD20 would display that output.
I personally have never seen any flicker or motion issues with 1080 24p from my PS3 to my HD20. Or any display or player I have used with BD discs.
As for the scene brightness changing, make sure that AI on the HD20 is turned off. Being on will cause the bulb to switch between low and high. I personally run my hd20 on a 125" White 1.0 gain screen with bulb on Low to help with black levels. I have tried an ND2 filter to cut brightness further, but after 5 mins my eyes adjust and it looks the same as without the filter. So...
post #3401 of 4170 Old 12-13-2011, 06:06 AM
xenon2000's Avatar
Quoted: 17 Post(s)
... I do see a flickering on the movies that pay on 1080P 24 hz. ...
I was just thinking. If you are used to watching content on a TV that has 120 or 240 hz with motion smoothing options. Then I could how see 24p might appear different. Also, I have noticed that in general, motion seems smoother on smaller displays vs huge projections. So maybe there are some perception differences as well. Not sure.
But overall I have been very happy with BD movies at the native 1080 24p on my HD20 @ 125".
post #3402 of 4170 Old 12-13-2011, 09:44 AM
tighr's Avatar
Quoted: 43 Post(s)
Liked: 83
My parents have a 120 hz television. Maybe I'm becoming something of a video snob, but I don't think I will ever appreciate interpolated scenes over standard film 24 fps.
~Tighr: Not helping the situation since 1983
tighr is offline
post #3403 of 4170 Old 12-13-2011, 01:23 PM
Daaku's Avatar
This is my first projector so no idea what i should be expecting and also bought the projector on a close out sale from Sixth Ave so had my reservations. As pointed out i could be seeing a difference because i got used to seeing the BD on my Samsung LED with 240hz.
I will check the AI option. How do i check my firmware ver and also where can i find an update. Thanks
Daaku is offline
post #3404 of 4170 Old 12-14-2011, 01:19 AM
_parodius_'s Avatar
Good morning,
I've just received my brand new HD20 and found one issue on modifying User profile settings.
When i modify the predefined settings, watch a film and finally turn off the PJ, the next time i turn on the PJ all the changes i made are lost.
I reviewd all the post about the Optoma HD20 and some people say that all the changes made on the User profile should be saved for the next use but other people say that all the modifications are gone and you have to re-enter it again and again each time you turn on the projector.
The procedure i follow is turn off the projector and then unplug it from the wall after a few minutes. (I have to tested if the User profile settings are kept if i not unplug the ac cable from the wall)
Some expert could clarify it? (as i reminder, all the changes are made on the USER profile, not on the Cinema, Bright or whatever)
Thanks a lot for your help.
Cheers!!
_parodius_ is offline
post #3405 of 4170 Old 12-14-2011, 06:01 AM
xenon2000's Avatar
Quoted: 17 Post(s)
I agree. Everytime I see these "motion altering" technologies, they always feel unnatural and even a little sickening.
post #3406 of 4170 Old 12-14-2011, 06:26 AM
xenon2000's Avatar
Quoted: 17 Post(s)
It's probably going from 240hz with motion altering technologies, to a native display and having it huge with projection and a dark room likely amplify the difference for you.
You have to ship the unit to Optoma for firmware updates. Lame I know. But sadly that is how they do it.
Sorry I am not in front of my HD20 to walk you to the firmware version. The manual will help if you can't find it during browsing.
post #3407 of 4170 Old 12-14-2011, 06:29 AM
xenon2000's Avatar
Quoted: 17 Post(s)
Originally Posted by _parodius_ View Post
Good morning,
Cheers!!
You mentioned you also tested when not unplugging it from the wall, but didn't say what those results were. If the user settings are lost when you don't unplug from the wall, you likely need a firmware update. Which requires it to be shipped to Optoma. Mine is plugged in all the time, and my User settings are always there when I soft power on/off. I haven't tested with unplugging the power after I turn it off and wait for it to cool down.
post #3408 of 4170 Old 12-14-2011, 06:35 AM
_parodius_'s Avatar
Thanks a lot for your reply!
Sorry, it was a typo.. i mean that i hadn't tested if the settings are kept with the PJ plugged...
Will try to perform that test and come back with the result, in the meantime if somebody else could give us more light about the issue will be welcome.
Cheers!
post #3409 of 4170 Old 12-14-2011, 07:03 AM
Quoted: 49 Post(s)
Why in the darkest pits of Tartarus are you unplugging it?
post #3410 of 4170 Old 12-14-2011, 07:12 AM
_parodius_'s Avatar
Why not? My electric provider is getting enough money from me....
post #3411 of 4170 Old 12-14-2011, 08:01 AM
xenon2000's Avatar
Quoted: 17 Post(s)
FYI, standby power usage is under 1 Watt. Do you also unplug your TVs? They likely use the same or more.
Not saying there is anything wrong with doing that. maybe there is maybe not. But there may also be little return to your power bill for doing so.
post #3412 of 4170 Old 12-14-2011, 08:17 AM
_parodius_'s Avatar
You're right, just joking because i was little bit surprised for that question
I spend a lot of time far from home travelling and of course i unplug all the electrical devices before leaving (don't want that a sudden storm or a power outage turns all my tech stuff in a piece of crap).
Cheers!
post #3413 of 4170 Old 12-14-2011, 12:01 PM
Daaku's Avatar
Cheers!
It seems to remember my user settings. I switch off the projector and also turn off the power supply to the power outlet as well.
Daaku is offline
post #3414 of 4170 Old 12-14-2011, 10:55 PM
_parodius_'s Avatar
Thanks for your reply!.
Good news guys, the problem has gone...magically...
After coming back home from work, i tried to see if the settings were kept unplugging the PJ from the wall and they were kept. I tried again without unpluggin and they were kept also...
The issue has turned into a mistery. Do you guys know if the PJ has any kind of little battery that is charged after few hours of operation to keep the settings on the memory like computers (i mean as the little cell that keeps time and date in BIOS)?
I don't like when problems disappear without explanation, it means that they can come back the same way....
Thanks a lot for your help!
Cheers!
post #3415 of 4170 Old 12-15-2011, 06:08 AM
xenon2000's Avatar
Quoted: 17 Post(s)
Cheers!
I don't know, but I am pretty sure there is no battery in the unit. There may be a large capacitor, which you could test by leaving unplugged overnight.
But I still think the best is to leave it plugged in. As for storms and unplugging it while traveling, I highly recommend a quality surge protector. I use a hospital grade one-time blow surge outlet. It will sound an audible alarm when it's tripped and the outlet will stay dead until you bypass it. Since it is one-time only, once it's tripped if you choose to do the bypass there is no more protection and the indicator light will not be lit. It's pretty cool. It was $30 for just the outlet. But it's clean on my ceiling and I haven't had a surge yet.
In my last setup, I had the power routed to a closet and used a battery backup with surge protection and power filtering to power the projector. Was nice so that when there was a power outage, I could shut down the projector properly.
But of course the best protection is unplugging. Just not practical for myself.
post #3416 of 4170 Old 12-15-2011, 06:32 AM
_parodius_'s Avatar
I agree Xenon, I also thought about having an UPS together with the PJ as i also have with my computer.
One more "box" kicking around xD
Cheers!
post #3417 of 4170 Old 12-19-2011, 06:54 AM
wilsonb's Avatar
Great group here...
I bought my HD20 from Best Buy on no % credit deal for $1200 or something after everything.. Have been very happy with it..
I liked it so much, when I moved over here temp in GTMO, I bought another one on Ebay for $550 ;-) Took a chance... and happy I did.
Having problems with this one when using Composite In for Cable TV..After 15-20min, the projector just powers completely off. No fan/no lights. Unplugging resolves this... but this can't go on. When this happens, It's not cooling the bulb down like it needs to.
Has oneone heard of this? How do I check the firmware?
(I don't have OVERPRICE proprietary remote. Would have to do it through buttons on unit. I have it set to turn off at signal timeout. I also have AI on.)
Has ANYONE heard of a leaked firmware? I'm sure a HD20x would work. I can't believe that hasn't happened by now. Seems Optima dropped the ball on supporting HD20. I remember hearing talk about firmware 3D capabilities. Maybe it was Optima to push their inventory before newer models release. Surprised no one has successfully connected a USB and investigated what is pulled.
What is the most current Firmware?
Thanks..
wilsonb is offline
post #3418 of 4170 Old 12-20-2011, 05:57 PM
corey99699's Avatar
Does anyone know if I can use my HD65 mount with the HD20?It would be nice if I could keep from buying a new mount but not sure if it will work.
corey99699 is offline
post #3419 of 4170 Old 12-21-2011, 06:00 AM
xenon2000's Avatar
Quoted: 17 Post(s)
If you can, you will have to move the mount and possibly the screen too as the HD65 has less zoom and a different image offset than the HD20.
From the HD20 manual, it uses Three M3 size screws. Max length 10mm, min 7.5mm
Page 46 of the manual has the placement of the hole listed with a pic and measurements. Download the PDF from Optoma and check out page 46. I am sure the HD65 manual has a similar page to reference.
But basically it's a triangle formation with 110mm between the back 2 screws. And 82.3mm between the back 2 screws and the front single screw.
post #3420 of 4170 Old 12-21-2011, 06:05 AM
xenon2000's Avatar
Quoted: 17 Post(s)
Originally Posted by wilsonb View Post
Great group here...
Thanks..
What is the most current firmware.... well, since it's not posted for download, only Optoma would know that answer 100%. I heard that Optoma has to do it because there is some type of color wheel calibration after the firmware update. At least that is what they said when I sent mine in for a firmware update when I first bought the projector. But that could be bogus. Though if the end user could easily apply updates, I don't understand why they would block HD20 updates from being posted when they allow a few of their projectors to be updated by end users. So maybe there is more to it than just a USB cable and firmware updater.
I wouldn't mind so much sending it in for updates if I didn't have to pay for the shipping. I didn't have to pay last time because it was with Costco and within 90 days of buying it. But they said normally I would have to pay to ship it to them. Which is lame for just a firmware update.
Optoma Hd20 Dlp 1080p Home Theater Projector
