*Official* Optoma HD20 Thread - Page 115 - AVS Forum | Home Theater Discussions And Reviews
 18Likes
post #3421 of 4170 Old 12-21-2011, 07:05 AM
nmcmahan52's Avatar
picked one of these up a couple weeks ago off of newegg for our basement, loving it so far, i think my biggest issue is getting it lined up with the screen
probably need to move the ceiling mount over about a half a foot
nmcmahan52 is offline
post #3422 of 4170 Old 12-21-2011, 11:40 AM
wilsonb's Avatar
Originally Posted by xenon2000 View Post
What is the most current firmware.... well, since it's not posted for download, only Optoma would know that answer 100%. I heard that Optoma has to do it because there is some type of color wheel calibration after the firmware update. At least that is what they said when I sent mine in for a firmware update when I first bought the projector. But that could be bogus. Though if the end user could easily apply updates, I don't understand why they would block HD20 updates from being posted when they allow a few of their projectors to be updated by end users. So maybe there is more to it than just a USB cable and firmware updater.
I wouldn't mind so much sending it in for updates if I didn't have to pay for the shipping. I didn't have to pay last time because it was with Costco and within 90 days of buying it. But they said normally I would have to pay to ship it to them. Which is lame for just a firmware update.
Thanks for the feedback...
I imagine there is a way to maneuver in the menu to get firmware revision. Shipping it to Optima would not be a good option for me.
wilsonb is offline
post #3423 of 4170 Old 12-21-2011, 11:47 AM
wilsonb's Avatar
wilsonb is offline
post #3424 of 4170 Old 12-21-2011, 01:13 PM
corey99699's Avatar
If you can, you will have to move the mount and possibly the screen too as the HD65 has less zoom and a different image offset than the HD20.
From the HD20 manual, it uses Three M3 size screws. Max length 10mm, min 7.5mm
Page 46 of the manual has the placement of the hole listed with a pic and measurements. Download the PDF from Optoma and check out page 46. I am sure the HD65 manual has a similar page to reference.
But basically it's a triangle formation with 110mm between the back 2 screws. And 82.3mm between the back 2 screws and the front single screw.
How much image offset difference is there between the two?I'm hoping not a whole lot.
corey99699 is offline
post #3425 of 4170 Old 12-22-2011, 06:05 AM
xenon2000's Avatar
Quoted: 17 Post(s)
Sure, I can navigate and tell you what version of firmware my HD20 has. But I know it's not the latest. And I certainly would not be able to extract the firmware without special software and drivers to talk to it. I have done custom roms with Android, and other firmware work and I don't know of any tools available to even attempt anything with the HD20. Plus I would not be willing to be the first to try with my HD20.
So unless you find someone that has figured out how to extract and re-apply a firmware and also has the latest firmware themselves; your only option is to send it in. And if Optoma wasn't lying, then you would also need to calibrate the color wheel.
Maybe I missed it; but what is wrong with your HD20 that makes you believe you need a newer firmware?
xenon2000 is offline
post #3426 of 4170 Old 12-22-2011, 06:11 AM
xenon2000's Avatar
Quoted: 17 Post(s)
You are better off going to the Projector Central calculator yourself, as that is all I am doing. If I remember right, at 10 ft away there was a 1.5" difference. Also, the HD65 mounting holes may not be in the same location which could change the lens centering as well.
post #3427 of 4170 Old 12-22-2011, 10:08 AM
corey99699's Avatar
Ok I checked it out and looks like I'm good,only 1.6 inch difference at the distance I'm using.It turns out I can use the mount for my 65 too so that's good news.I'm looking forward to getting it tomorrow I've missed my 65,been about 7 months since I've had a projector and I've never even seen one in 1080p.
post #3428 of 4170 Old 12-23-2011, 06:56 PM
corey99699's Avatar
Well I got my hd20 today and I'm watching it now,quite an upgrade from the hd65 if you ask me,loving it so far.I still need to run my calibration disc but I'm impressed so far,I used the same mount I was using for my hd65 and the best part is that I didn't even have to move it,just plugged in the hdmi and the power cord and raise the extension a bit and I'm in business.
post #3429 of 4170 Old 12-26-2011, 05:40 PM
adrift's Avatar
Hey folks. Need some advice.
Tonight I replaced the dimming bulb in my HD20 with a new one I got on ebay (just the bulb, not the housing). The picture is much brighter now, but at the top of my screen there's a multi-colored spot about the size of my fist that I can only really see on white backgrounds. I was pretty careful taking it apart and putting it together again, but I didn't use gloves to replace the lamp like some folks recommend. Could the spot be caused by touching the housing lens by accident? Or is it a color wheel issue maybe? I remember seeing something similar looking to this spot right before I sent my projector to Optoma to get cleaned the first time it started malfunctioning, and I never got into the projector then...
Anyways, any help that can be offered is appreciated.
adrift is offline
post #3430 of 4170 Old 12-26-2011, 06:48 PM
m335i's Avatar
Okay i am having problems with my Optima HD20 Projector. I bought it refurbished. It worked great for about a year has about 2500 hours on bulb now. When i turn it on it works great color is great and picture is great, but after about 15-20 mins the color starts to look like it has high contrast or something and it starts looking greenish purple. If i leave it on it will start to flicker and color will be all over the place like rainbow... Anyone know what this might be? What could i do to fix it?
Thank you!
Will post images soon.
When I first turn on its perfect.
After 15-20 mins i get this.
m335i is offline
post #3431 of 4170 Old 12-26-2011, 07:39 PM
adrift's Avatar
Originally Posted by Brenda856 View Post
So BB is going to charge 1099? Disappointing... guess I'll take a try online.
Amazon has it for $899, and apparently you can get one refurbished for $699 with free shipping.
adrift is offline
post #3432 of 4170 Old 12-26-2011, 07:40 PM
adrift's Avatar
Thank you!
What happens if you turn on High Altitude? Could be that its getting hot because of accumulated dust.
adrift is offline
post #3433 of 4170 Old 12-27-2011, 01:03 AM
m335i's Avatar
when i put the bulb on high it gets worse and color gets bad fast.
m335i is offline
post #3434 of 4170 Old 12-27-2011, 06:03 AM
xenon2000's Avatar
Quoted: 17 Post(s)
No way it's the color wheel. It is most certainly the bulb and housing swap. The real question is whether you can really do anything about it. It's very unlikely that any finger oil would cause a concentrated coloration. But the oil would cause the bulb to fail early if not cleaned off really well during assembly. So unfortunately you need to mess with the bulb/housing to affect it. Seeing that the housing and bulb was the last thing changed, it's mostly likely just that.
post #3435 of 4170 Old 12-28-2011, 05:47 AM
xenon2000's Avatar
Quoted: 17 Post(s)
High Altitude mode is completely different than Bulb on high. There is actually a setting for High Altitude and it runs the fan at high speed due to less air at high altitude. Though I think much earlier in this huge thread people had to send in their units for repair when this happens.
post #3436 of 4170 Old 12-28-2011, 10:59 AM
adrift's Avatar
Well its good to know that it probably has nothing to do with the color wheel (didn't know if dust could slide back in there and cause the issue I'm describing). I opened it back up recently and blew it out with a can of compressed air, but it didn't have any effect. I guess I'll try swapping the old bulb back in and see if that makes any difference.
Thanks for the help.
adrift is offline
post #3437 of 4170 Old 01-03-2012, 04:56 PM
Thirsty1258's Avatar
Quoted: 70 Post(s)
Does anyone know where I can buy a longer power cable I need to run it like 6 ft extra. And don't want to use a extension cord. Anyone know what the specs are for this cable or if mono price has em. Thx
Thirsty1258 is offline
post #3438 of 4170 Old 01-03-2012, 05:45 PM
tonsofpcs's Avatar
Thank you!
Mine (just over 3000 lamp hours, 6 of those 'bright') has started doing similar. Colors are clipping. At first I thought it was an issue with certain broadcasts because it only happened and was apparent on deep reds (like those commonly seen on a certain network's Sunday evening cartoons). It slowly got worse and became more apparent. Lowering the brightness and/or R/G/B gain/bias settings made it less so, leading me to believe that there is clipping occurring in the circuitry that does the balancing/biasing (analog?). I tried recalibrating it and this didn't help (in fact, it seemed the reds were way off and the other colors were off a bit as well). Shutting it, letting it cool, blowing out the dust, then bringing it back up didn't appear to help much either. Resetting factory defaults made it seemingly better but it still has issues. Grey steps show a different color tint at each level, so something has clearly gone non-linear and biases are likely off.
Has anyone had this issue before and found a solution? Bad caps? Burnt transistors?
Is there anywhere that is familiar with these that performs repairs for a reasonable fee?
Eric
tonsofpcs is offline
post #3439 of 4170 Old 01-04-2012, 05:52 AM
xenon2000's Avatar
Quoted: 17 Post(s)
Eric
I would do a search. I am pretty sure this is the same issue many others have had to send it in to Optoma for repair. I believe some people have been able to prolong repairs by putting it into high altitude mode. But that hasn't worked for everyone. It would be great to know what Optoma is doing for that repair.
post #3440 of 4170 Old 01-04-2012, 01:41 PM
jamnperry's Avatar
I had that problem. I took it apart and blew out the color wheel with a can of air and no problem since. I really didn't think it would help because it looked clean except for just slight dust particles on the wheel.
I'm on my second bulb with around 1600 hrs. It was a very repeatable problem usually within 10 minutes of turn on going to green/purplish hues. Probably did it around 2 months ago and no problem since.
Followed the great instructions in this thread.
jamnperry is offline
post #3441 of 4170 Old 01-04-2012, 03:02 PM
adrift's Avatar
I just wanted to give an update on this issue in case anyone cares. I never changed the bulb back out, so I don't know if that was the issue or not, and after doing a massive amount of Googling, I only found one other individual having a similar issue, but they had a multi-colored streak running down their screen which would have been far more noticeable. They fixed their issue simply by blowing the projector out. Blowing the projector out didn't work for me, but I've been running the projector with High Altitude on, and over the last two weeks the spot has been shrinking considerably, and is almost gone completely. I probably would have been more proactive in taking the thing apart again and swapping out the lamp, but the colored spot on my screen is towards the top of the screen, and if/when watching movies, the widescreen letterbox bars cover the spot completely.
Anyways. I'm happy.
adrift is offline
post #3442 of 4170 Old 01-09-2012, 04:51 PM
dctoast's Avatar
Does anyone know the measurement of the center of lens to base on these?
dctoast is offline
post #3443 of 4170 Old 01-19-2012, 07:38 AM
tighr's Avatar
Quoted: 42 Post(s)
Liked: 83
I thought I'd mention, since it was a question here previously: I just hooked up my Nintendo 64 this past weekend to my Onkyo TX-NR609 receiver. Worked like a charm! When I had previously tried using the composite input on the Optoma, I wouldn't get picture. The projector did not want to recognize the 240p that the N64 outputs.
So, for anyone else hoping to play old school video games, that's one suggestion. I had previously bought a Video Scaler off eBay (the Zinwell Briteview progressive upconverter) but its still in the box (brand new, surprisingly enough). If anybody wants that instead, I'll sell it to you!
~Tighr: Not helping the situation since 1983
tighr is offline
post #3444 of 4170 Old 01-21-2012, 04:25 AM
N ikkos's Avatar
I just switched to an electric screen from a manual. It is a budget screen by elite (electric 100h). It has a 12V trigger and we put up the screen and connected it to the HD20 only to find that there is no option in the HD20 menu to turn the trigger function on. It clearly shows it under the system menu in the manual but I do not have it on my projector. My firmware shows as C09. I would greatly appreciate any help in the right direction or an indication of where I am doing something retarded. I plan on calling Optoma, however as luck would have it the 1 year warranty expired in december 2011. Arrhg so disappointed after spending 3.5 hours getting the screen up in my odd octagonal shaped theater room(not my choice just the way it came with the house) I have been goggling but have not found anything useful yet. So anyone willing to take a stab at this I would greatly appreciate it.
N ikkos is offline
post #3445 of 4170 Old 01-22-2012, 04:22 PM
Arative's Avatar
Quoted: 44 Post(s)
Liked: 41
Thank you!
I had this problem. Had to send it in to get the main board replaced. Cost around $500. That was about 9 months or so ago.
I'm starting to see a lot of blown out colors again, especially on reds. I'm hoping it is just the bulb, since this is the original bulb, going on close to 4000 hours now. I use compressed air every two weeks to blow the dust out of the projector out now.
Arative is offline
post #3446 of 4170 Old 01-23-2012, 03:55 PM
boxer0987's Avatar
Do the HD20 and HD66 have same mounting holes?
boxer0987 is offline
post #3447 of 4170 Old 01-24-2012, 06:21 AM
xenon2000's Avatar
Quoted: 17 Post(s)
Sorry, I don't have both projectors to answer that. But if you download the PDF manual of both from Optoma, I know the HD20 manually clearly gives the location dimensions and screw type and length. So you could then compare the two.
post #3448 of 4170 Old 01-26-2012, 06:26 AM
Ghostman84's Avatar
I have no idea what's causing this. I recently put in a new lamp but I took out and re-inspected the bulb and housing and everything seemed fine.
I also recently installed a new color wheel, but this was the reason I replaced it in the first place (obviously that isn't the problem)!
Can someone help me figure out how to fix this?
Ghostman84 is offline
post #3449 of 4170 Old 01-26-2012, 12:44 PM
cobolisdead's Avatar
Quoted: 46 Post(s)
Well, I finally got some nice black out curtains to go in my living room and foyer. Now the image looks brilliant even in the middle of the day!
Quis custodiet ipsos custodes?
cobolisdead is offline
post #3450 of 4170 Old 01-27-2012, 06:26 AM
xenon2000's Avatar
Quoted: 17 Post(s)
That issue is most definitely not the color wheel or circuitry. Since you are testing with a white background, you can clearly see the white uniformity. The only thing that affects this is the light source (bulb and housing/reflector), the light path (mirrors, etc), and the lens optics. Based on the type of distortion seen here, my first guess would be the light source. This minor of a distortion would not be something you would be able to see wrong with the naked eye when inspecting the housing and bulb.
My biggest guess on what is wrong with the bulb is a slight variation (very very slight) in the reflector coating and/or bulb location or bulb glass.
Unfortunately I highly doubt there is anything you can do. When you put in a "new lamp", I am guessing this is not an Original housing with bulb assembly. So did you replace just the bulb and reuse the housing? If so, it's definitely caused by that. Was the bulb at least an Original Manufacturer's bulb and not a cheaper knock off OEM bulb? There are huge differences in OEM bulbs.
Personally, I would call it defective and seek a replacement to try. I bet that even if it has issues too, the distortion will look different proving that it is indeed the replacements they are using.
That is my best guess of course. I could be wrong completely. But the distortion doesn't make sense to be anything else.
Optoma Hd20 Dlp 1080p Home Theater Projector
