*Official* Optoma HD20 Thread - Page 136 - AVS Forum | Home Theater Discussions And Reviews
Old 04-30-2015, 04:19 PM
kevinwoodward's Avatar
Quoted: 14 Post(s)
Originally Posted by cessna1466u View Post
Thank you both for your responses. I read up a little more and think I am starting to understand this a little better. I picked up the projector yesterday night and tested it on a white wall. All seems good, time on the lense is 87hrs. The guy I picked it up from bought it and played it on a wall for a while then bought a huge 4K tv and said he liked the picture better on the tv than the projector. From his home and furnishings, he had plenty of money and I feel like the hours might be correct.
So I did some measurements and it looks like I will be able to mount the projector about 12.5feet from the screen. So according to the calculator the optimal screen will be a 106". I need to work on the distance that I will have to lower the projector from the ceiling but I figured I would wait until I have the screen mounted to see how low it hangs. Speaking of screens, I just came across one being sold close by for $240 it is a Loch 106" gray, manual screen. I looked them up and they are about $140 new so I emailed him and he is willing to go for $100 if I pick it up today. No problems there, I am looking at the mounting options and thing this will work very good for me where I plan to mount it and don't have to worry about custom mounting the motorized one. I can mount when using it and remove and store when not in use. Anything bad about the Loch screens? I know white is desired but from what I read grey might be ok for my setup since I dont have a dedicated theater room and there might be some ambient light. Any thoughts?
get the projector, project it on the wall then decide on screen.
for the quality of this projector I wouldn't go over 200
kevinwoodward is offline
Old 04-30-2015, 04:22 PM
cessna1466u's Avatar
Quoted: 78 Post(s)
Liked: 190
200"? I was planning on max 120 but looks more like I can go with 106" with the projector mounted about 12.5' away on the ceiling.
cessna1466u is offline
Old 04-30-2015, 04:28 PM
Quoted: 14 Post(s)
I have an epson on a 106 elite framed screen in a 14 by 13 room and it's huge
but not too big
you could save some dough and get a 100inch
just see how big you like the image on the wall
Old 04-30-2015, 10:17 PM
Quoted: 78 Post(s)
Liked: 190
Thanks again all for the replies this is helping a lot. I jumped on the manual screen that I mentioned earlier. $100 and its in like new condition. I plan on mounting everything tomorrow very temporarily with straps and brackets just to test it all but I have a couple of questions and just want to make sure I understand the number that are coming up on the projector calculator.
Looks like me mounting the projector 12.5 feet away from the screen is ideal for this 106" screen. So far so good. The problem I am having is the mounting of the screen. The top of the area that the picture will be projected on will be about 17" from the ceiling where the projector will be mounted. The center of the projector front glass piece will be about 6 inches if I go with a standard mount. If I read this right I need to be about less than 8" from the center of the glass to the top of the viewing area of the screen? Is this all correct? I see most projectors mounted level with the ceiling, I am assuming this is how it should be mounted and I should not angle the project down to help get closer to the -8"? Or is angling the projector down ok to do? Should I just go with a mount that extends down further to allow the projector to be level with the ceiling? Here is a pic of the calculator. Thanks
Old 04-30-2015, 11:03 PM
xenon2000's Avatar
Distance: 12'6" = Screen 96" to 115" with 9 inch offset. (Odd, it shows me 9 inches when I pick the HD20, but your screenshot shows 8, hmm)
Definitely make sure the PJ is level with the floor/ceiling and completely perpendicular to the screen. Otherwise will will need to use keystone adjustment to square up the image and that will introduce artifacts in straight lines. Which looks ok with video, but not perfect with gaming and computer sources.
If you don't plan on using blackout blinds or blackout curtains, the grey may work well for you. Also at 106" the grey will help reduce some of the extra brightness that comes with smaller screen sizes. I would still use the HD20 with the bulb in eco mode. I don't know anything about the Loch screens. Hopefully it is a matte grey 0.9 gain screen and not a high-gain reflective style silver screen. Which will give hot spots.
You can quickly get a rough estimate of how low the HD20 needs to be mounted from the ceiling. Figure the top of your screen will be somewhere near the top of your entertainment center if you are mounting it on that or in front of it. And then measure how far that is top level is from your ceiling. Minus 9 (or 8) inches and you have the distance to the center line of the HD20 lens. If your ceiling is not flat, you will have to take into account the extra distance for the slope.
A little odd that someone is trying to sell a $140 screen for $240. Is this a 106" 16:9 screen that you mount? Or is this a tripod based presentation screen?
cessna1466u likes this.
xenon2000 is offline
Old 05-02-2015, 11:09 AM
Quoted: 78 Post(s)
Liked: 190
Thank you all for the help. I picked up the screen and temporarily hung it to measure and do some testing. It is the matte gray color and I was able to get it for $100. He says he bought it for $500 a couple of years ago. The guy seemed a little sketchy but who knows. It will be a couple of weeks before I mount it permanently I was planning on doing it so I could mount it when I needed it and then putting it away when not in use but the wife gave me the ok to permanently mount it so I need to work on that and mounting the projector. It looks like I can go with a standard mount for the project and be ok with the height. I will mount the screen first and then measure for the projector. The mount I am making for the projector screen will allow about 2-3" if travel if I need to move it up or down before I secure it down snug. I will post back some pics when done. Here is a pic of the screen with some clamps to hold it down to measure and test.
Oh BTW, it seems my nice guy that sold me the projector was either lying or didn't know himself but looks like the bulb might have been changed already once. The label over the screw for the bulb housing has been punctured and the bulb says Osram on it, I don't know if that is an aftermarket or OEM for Optoma. Need to do some research on that.
I also got the dreaded vertical lines yesterday while testing the picture on the screen. I freaked out but found a few articles on pushing down right behind the lense and it fixed it. Before I mount it I plan on taking a look inside and cleaning out the contacts as it states on a few articles. It might have shifted while transporting it or the guy got the same thing happening and that is why he sold it, maybe he didn't know the fix.
Old 05-02-2015, 10:39 PM
xenon2000's Avatar
I am sure he knew about the issues it was having and the bulb replacement. Seems unlikely he put only 87 hours on it in a few years. I hate to assume the worse. But if I buy a used projector, I act like the bulb is dead and anything I get out of it is just bonus time until I have to replace the bulb myself. Can't trust the hours or people's word unfortunately. If lucky, they told the truth on the bulb and you may get 1000+ hours out of it. But I wouldn't count on it. Hopefully your fix for the vertical lines will last as well. Good luck.
Old 05-05-2015, 01:28 PM
Liked: 0
Love this projector model. Sad to see mine go, but will be posting it FS. If anyone hasn't researched this projector, this is a great value for starting out! My personal setup worked great with the wall paint. Can't wait to get an upgrade later down the line and redo my theater room.
xfactor01 is offline
Old 05-07-2015, 12:30 PM
Star56's Avatar
Location: In my armed redoubt deep in the mountains of northern Ohio
Quoted: 17 Post(s)
The HD20 gets better and better with bulb age. Mine is still low hrs and is getting more and more use during the NBA finals.
42" in the dining room.
50" in the bedroom
80" in the living room
65" in the family room
106" in the family room
"There is another system"
Video Modes: SDTV-EDTV-XGA-HDTV-3D
All HD Modes: Blu Ray, HD DVD, DVHS
Star56 is offline
Old 05-07-2015, 12:39 PM
John Pessoa's Avatar
They're still having focus issues?
thanks
John Pessoa is offline
Old 05-08-2015, 06:57 AM
xenon2000's Avatar
thanks
Sounds like a statement, but you have a ? at the end. Are you asking if the HD20 has focus issues? I do not think the HD20 has changed since it first came out. The focusing is fine. But the lens is really loose and so it's easy for it to come out of focus between uses if it is not permanently mounted in a stable location. If you mount it where there is a floor above it, the ceiling shake may cause it to slowly come out of focus over time. In my previous one-story house with the HD20 ceiling mounted, rarely needed to be refocused over the 4 years I was there. And even then it was more because I wanted to make sure it was in focus. Not because it looked out of focus. I would not say the HD20 has any focus issues.
Old 05-30-2015, 10:16 PM
Liked: 0
Non-returnable OEM Optoma HD20 Lamp
Our 5-year old projector began shutting down, no warning display. Solid red bulb light and blinking amber standby/on/off light. Reset the hour meter and cleaned dust, no dice. We ordered a new lamp from Optoma for $240+tax and cleaned thoroughly, even the color wheel, and installed new lamp. It stayed on longer this time, about 10-15 minutes, then shut down again - no warning. We cannot return the lamp, only defective lamps will be replaced. If we send back the lamp and they find it isn't defective, they will bill us for their time and send the lamp back to us at our cost. So now we've got a new lamp we paid $280 for and a projector that doesn't work. It would cost as much to get the main board replaced (if that is the problem) than a new projector. We can buy a new HD26 for $640 + tax, does anyone have any advise about what to do with this HD20 lamp?
patgarcia is offline
Old 06-01-2015, 08:42 AM
xenon2000's Avatar
Not really many options. Since you can't return the lamp, you are left with selling it yourself on ebay, Craigslist, etc. This is a common scenario with budget projectors. Often it's better to just replace the whole projector instead of repairs. Often a different story for $3000+ projectors.
Old 06-09-2015, 10:34 PM
Liked: 0
Wondering if someone here can help me since this is really the only active forum for this projector.
My projector has recently started denying any input from other devices. It will not take anything if I have it coming through my receiver. It will show 1080p 60z when connected to my laptop, but only a black screen. I connect it to my media player (Minix X7) and the display will flicker on and off connecting and disconnecting. The weirdest thing is that it will connect to my father's laptop fine, but at the resolution of 1600x1200. I have a decently new color wheel, and I still have many hours left on the bulb. I opened it up and cleaned it out as best as I could, but still no results.
Any advice for this would be greatly appreciated.
dylan43270 is offline
Old 06-09-2015, 11:17 PM
Quoted: 78 Post(s)
Liked: 190
I am assuming all these difference connections are done with different HDMI cables so there is no chance its your HDMI cable? Have you tried input 2? Don't what kind of receiver you might have but does it offer the option of converting lower signals to 1080p? If so have you tried turning that option on to see if that helps. On mine right now I am having the issue that if I have the processing option off on my receiver I get snow in the picture.
dylan43270 likes this.
Old 06-10-2015, 01:47 PM
Liked: 0
I am starting to think it may be an issue with my media player.
I have been messing around with stuff during the day and I have gotten my laptop to work with it by switching displayport adapters and by using Windows instead of Linux. I have also gotten it to work with an Xbox One with the short HDMI, long HDMI, and now also through the receiver. I am going to test later with the laptops to see if they can now work through the receiver, and if so it does look like an issue with the Minix (may need to update the firmware). I guess if you tinker with stuff enough something is bound to break, and if you tinker with something broken enough you can possibly fix it.
Old 06-14-2015, 10:14 AM
Quoted: 78 Post(s)
Liked: 190
New issue with the HD20 now, don't think it has anything to do with the connections since everything seems to be ok on the 65" DLP. Last night while watching a movie we noticed that every few minutes maybe even longer and sometimes not for 20 or so minutes we would see a quick green light flash on the screen. It lasted less then half a second and seemed green in color, horizontal and all over the screen. Sometimes along the bottom, then on the top, then middle. So there was not one particular spot that it was happening on or a particular part of the movie, we went back to the same scene it happened on and it wouldn't replicate. Any ideas? Is my color wheel going out or the bulb? From what the counter says it only has about 180hrs on it.
Old 06-15-2015, 08:44 AM
xenon2000's Avatar
Working on another display doesn't guarantee the issue isn't cable or source related. The green flicker sounds like it could be a source or cable issue. Have you tried another cable and another source? I would test the HD20 using a short cable, 12 feet or less if you can. And directly to a source. Test with 2 sources to make sure it's not the source either. The HD20 has been known to not see weak HDMI signals very well. Which can cause issues with some receivers, cable, and sources.
Old 06-16-2015, 09:57 AM
Thirsty1258's Avatar
Hi all I am having a new issue with my HD20. When I go to power it on the fans starts the green light blinks and sometimes the bulb glows sometimes not. Nothing happens and the fans turn off and the green light continue to blink. Nothing ever turns on and eventually the green light turns off. If I try to power on again no lights until I unplug it and try again.
Thirsty1258 is online now
Old 06-16-2015, 12:18 PM
OK got it back up and running. Took it all apart again for the second time and canned air the insides. hit the fan alot and good to go.
Old 06-21-2015, 10:09 PM
wecaz's Avatar
I have similar problem. I had to run projector in high-altitude mode ON and bright mode ON to avoid it happening again. Still there are exceptions when it still occurs.
As of not I am not so confident about opening the projector and cleaning it myslf.
wecaz is offline
Old 06-21-2015, 10:15 PM
Taking it apart. Is easy 3 small screws on bottom carefully twist lens knob off. Pull apart. I haven't had any issues since cleaning
wecaz likes this.
Old 06-23-2015, 10:00 PM
Zonacats's Avatar
Replaced a lamp ballast in an HD20 and now when I power it on, it goes from amber to constant blinking green. Any ideas?
Zonacats is offline
Old Today, 10:18 AM
Liked: 0
Hi guys,
a friend gave me a functionnal HD200x but it was rumbling. The color wheel was broken, so I replaced it but after that the lamp doesn't worked any more. Do you have any idea of what I can do ? I don't really know how I should test the lamp or anything else. I'm student in electronics so I have the materials to test some things, just tell me what I should start with.
Maxime Borges is online now
Optoma Hd20 Dlp 1080p Home Theater Projector
