*Official* Optoma HD20 Thread - Page 25 - AVS Forum | Home Theater Discussions And Reviews
 18Likes
post #721 of 4170 Old 09-01-2009, 05:31 PM
guitarman's Avatar
Quoted: 14 Post(s)
Wow I just watched Rounders which is non anamorphic using a Panny BD80 which zooms the the image perfrectly. Never saw it look better at upscaled 1080p 24fps, the whole picture looked great, colors, blacks, detail everything. Nice PJ the HD20.
Tom/guitarman
VideoDementia
Are you twisted also?
http://www.videodementia.com/sales/TomWithWires.jpg
guitarman is offline
post #722 of 4170 Old 09-01-2009, 06:09 PM
ryllo's Avatar
guitarman,
what screen are you using?
ryllo is offline
post #723 of 4170 Old 09-01-2009, 06:11 PM
JimJimBinks's Avatar
Wait a sec, does HD20 to 24fps?!
Also, please let me know if that's a stupid question. Do all projectors and TVs do it these days?
JimJimBinks is offline
post #724 of 4170 Old 09-01-2009, 06:37 PM
FreyTheater's Avatar
yes, it does 24 fps. quite nicely!
FEEL an awesome 3D Blu-ray movie in the Frey Theater - Now with projection in glorious "FREYMAX" 3D!
FreyTheater is offline
post #725 of 4170 Old 09-01-2009, 06:41 PM
guitarman's Avatar
Quoted: 14 Post(s)
Originally Posted by ryllo View Post
guitarman,
I'm using a dalite high power screen and yes blacks and video look great. The PJ is ceiling mounted so gain is reduced way down. A gray screen would work well for the HD20 also.
Tom/guitarman
VideoDementia
post #726 of 4170 Old 09-01-2009, 09:55 PM
darinp2's Avatar
Quoted: 1135 Post(s)
Liked: 1766
Is anybody tempted to try adding an iris or two for less lumens, but higher on/off CR, like discussed in this thread:
http://www.avsforum.com/avs-vb/showt...9#post16971419
--Darin
Ericglo likes this.
This is the AV Science Forum. Please don't be gullible and please do remember the saying, "Fool me once, shame on you. Fool me twice, shame on me."
darinp2 is offline
post #727 of 4170 Old 09-01-2009, 10:11 PM
Dougie085's Avatar
The HD20 can do any refresh rate between 24 and 80hz. So yes it can do 24p
Dougie085 is offline
post #728 of 4170 Old 09-01-2009, 11:10 PM
adrianbrandt's Avatar
Originally Posted by Rew452 View Post
I have found along with others that it is better to run for the first 100 or so hours on High to ensure that the electrodes burn in properly and then switch to the low setting if that is were you like it.
Doing this seems to ensure for the most part a good long life of the lamp.
Hmmm, this is an interesting claim. Can you explain exactly how you arrived at this determination? If you would provide this, then others -- in the spirit of the scientific method -- would be able to follow your experimental protocol to see if they can verify this finding. I'm not an electronics or physics (or projector) expert, but I cannot immediately think of what would explain this or what would constitute "proper" electrode burn in (do you mean lamp electrodes, or what?) and how that relates to lamp life. At least if you would share your protocol for arriving at this finding, others could independently evaluate and verify your result(s).
adrianbrandt is offline
post #729 of 4170 Old 09-02-2009, 03:19 AM
Rew452's Avatar
Quoted: 113 Post(s)
Liked: 65
Ah! the Engineer/Scientist.
First off please do research the technology of the these lamps which are used in both front pj's and rear pj tv's regardless of display tech used. They are probable the weakest link and one of the most expensive part and has the shortest life span of any part used in pj's.
They are a High Pressure (up to 250bar after ignited) discharge lamps with Mercury-Halogen gas and tungsten electrodes. They use high voltage to ignite and it is the arc across the two electrodes which have a gap of only 1mm or so. The high voltage jumping across this small gap generates the high lumen light we need.
But the gap wears in time and sometimes slivers grow across the electrodes which tend cause a secondary arc which we see as a flicker; if we are lucky or can cause premature lamp failure if we are not.
After lamp ignition the metal vaporizes which takes time; the reason to leave on for a few hours.
At turn off metal will re-deposit and again takes time; the reason to reduce cycling of power on/off.
As with most electronics the most dangerous times of failure is at turn-on and turn-off.
The studies have already been done. Do the research and draw your own conclusions.
My post was for the new users which are not familiar fragility of these lamps to help them get the most life from them.
Still no guarantees I have had them fail at 50 hours but these guidelines seem to help.
Rew
Rew
Vizio P75-C1 | OPPO UDP-203 | Samsung UBD-K8500
Denon AVR-X4300H00 | Nvidia Shield Android TV | C =Axiom VP150 |FL/FR =Axiom M60 |SL/SR =Axiom QS4 |TFL/TFR =Bose 161 | TRL/TRR =Bose 161 |Sub =Reaction Audio S-15 500W SEALED SUBWOOFER
Rew452 is online now
post #730 of 4170 Old 09-02-2009, 03:46 AM
atanuray's Avatar
atanuray is online now
post #731 of 4170 Old 09-02-2009, 04:56 AM
Coolme's Avatar
I saw the projector shootout that was posted earlier in this thread from PP. I have a little question: the letterbox bars on the HD20 really looked more grey than they did black. Is this something you owners can see also? It's a bit distracting and I find it spoils what is for the rest a fine image.
Coolme is online now
post #732 of 4170 Old 09-02-2009, 06:51 AM
BrickTop's Avatar
Quoted: 47 Post(s)
Liked: 31
Originally Posted by atanuray View Post
Art's review is finally here
http://www.projectorreviews.com/optoma/hd20/index.php
Decent review, but he doesn't have any contrast measuements. So the HD20 has "bad" black levels, but without contrast numbers, we don't know if it is because of horrible contrast, of just because it is brighter than most (which it seems to be). Too bright can easily be taken care of with an ND filter. Just doesn't seem to tell the whole story.
BrickTop is offline
post #733 of 4170 Old 09-02-2009, 07:05 AM
opto2000's Avatar
Actually, I wanted to see a little comparison with its own HD65, cause HD20 seems to be a successor of HD65 even it's 1080p projector. I think I'd better wait until I see reviews for $999 Vivitek and BenQ 1080p PJs.
opto2000 is offline
post #734 of 4170 Old 09-02-2009, 07:18 AM
Rew452's Avatar
Quoted: 113 Post(s)
Liked: 65
Well it's on the FedEx truck for delivery!
Hope to have some initial impressions sometime today.
Rew
Rew
post #735 of 4170 Old 09-02-2009, 07:21 AM
I just put my 60" Sony LCoS TV on Craigslist, as soon as that sells I'll be ordering this projector.
Please don't hate me once I get this thing and the Projector n00b questions start flying
post #736 of 4170 Old 09-02-2009, 09:06 AM
ryllo's Avatar
Rew452,
IS HE THERE YET LOL!!!
looking forward to your info once you get it. Can't wait to see if your screen paint works well for this pojector, so i can go paint mine!!!!
ryllo is offline
post #737 of 4170 Old 09-02-2009, 09:06 AM
monakh's Avatar
Quoted: 57 Post(s)
Well, I guess Art gave the HD20 his 'Hot Product' award. That goes a long way in my books.
Tom, still waitin' on that review of yours, buddy.
Edit: Bookmarked the thread and thought it would be in here. Didn't check the front page. Thanks.
monakh is offline
post #738 of 4170 Old 09-02-2009, 10:12 AM
Robert Clark's Avatar
Quoted: 51 Post(s)
Liked: 47
It's here, already posted yesterday...
Robert Clark
Robert Clark is offline
post #739 of 4170 Old 09-02-2009, 10:28 AM
Yes, I take an analytic/scientific approach to separate lore from fact/knowledge-based claims.
I have, and am well aware of this. You probably don't recall my earlier posting answering what a P-VIP lamp is.
After lamp ignition the metal vaporizes which takes time; the reason to leave on for a few hours. At turn off metal will re-deposit and again takes time; the reason to reduce cycling of power on/off. As with most electronics the most dangerous times of failure is at turn-on and turn-off.
Sure, that's all pretty well-known and non-controversial, but is a non-sequitur as far as the "100-hours on high burn in extends lamp life" claim goes.
Great! So can you (or anyone else) please point the curious like me to at least one reference that addresses extending lamp life with 100-hour "burn-in" on high.
Any references (such as a paper like this on UHP lamps) would be welcome.
My question is also for new (as well as old) users. I want to help avoid that folks get burdened with with lore that has them unnecessarily worrying about things that may not even be true (e.g.: high octane gas is "more powerful"). The "100 hours burn-in on high to maximize lamp life" claim may be valid, but how can you or anyone else know what the precise basis for this very specific claim is?
post #740 of 4170 Old 09-02-2009, 11:58 AM
sharpnine's Avatar
Can I ask where you got this information?
I don't understand how it could produce a refresh rate such as 80hz with a color wheel rotating at a fixed speed (120 hz). It seems like it would create weird artifacts if it tried (changing frames in the middle of a color wheel transition).
I would think that perhaps it could accept any frame rate in that range, but would only be able to output frames at a fixed rate i.e. would drop frames, or create new frames as needed.
I have been trying to determine if 24fps is really output as a native output format, or if it is just accepting 24fps and bumping it up to 60 hz. I think a 120hz color wheel would allow the former, but I wasn't sure if the firmware was actually sending an image every 5 color wheel rotations as would be required.
When watching blu-ray discs from my PS3 on the HD20 I did not think that 24fps looked better (and perhaps worse) so I turned it off. It could be an issue with the PS3, or just my eyes.
sharpnine is offline
post #741 of 4170 Old 09-02-2009, 12:25 PM
Charles R's Avatar
Liked: 645
If the HD20 is like the HD80 you can hear the color wheel slow down (less whining) when you go from 60Hz to 24Hz. That alone makes it a winner! In theory the image should be identical with less judder during movement.
| 120" Screen | 1080p Projector | 7.2.4 Boston Acoustics & Power Sound Audio | Yamaha RX-A3060 & AudioSource AMP110 | Sony UBP-X800 | LibreELEC/ODROID-C2 Media Client | Ubuntu/ODROID-XU4 Server via Kodi/Plex Media Server : LG 65EG9600 OLED TV | TiVo | Roku Premiere+ | Blu-ray Movies for Sale | Digital HD Codes for Sale |
Charles R is offline
post #742 of 4170 Old 09-02-2009, 12:41 PM
Dougie085's Avatar
I was just going by the specs, It can accept those refresh rates according to the optoma specs. Weather or not the projector actually adjusts for it I don't know.
post #743 of 4170 Old 09-02-2009, 02:23 PM
sharpnine's Avatar
Interesting. So the color wheel is perhaps changing rotational speed to match the frame rate. I had assumed it was a fixed speed multiple of 60hz.
However wouldn't the slower color wheel increase RBE?
post #744 of 4170 Old 09-02-2009, 02:25 PM
novasol's Avatar
Not be anti HD20, but I did have one for a while(actually HD200x) and didn't see it as enough of a 1080p upgrade from my Epson 720. Both projectors were basically identical in my viewing.
I'd recommend anyone looking at this pj to consider spending a few hundred more on one of the alternatives Art mentions in his review.
To quote Art
Optoma HD20 vs. InFocus X10, Sharp XV-Z15000, Viewsonic Pro8100
Both of these projectors are a step up (or more) from the Optoma HD20. The X10 which is being phased out, is probably a great deal at the moment, but still likely to be close to $2000. The Sharp is also around that price.
Simply put, the InFocus should have a slight, but side-by-side noticeable advantage in black levels, it also has better overall color - always an InFocus strength. The two should be about comparable in terms of shadow detail, and the X10 should be a little quieter in operation.
The Sharp XV-Z15000, which we reviewed a few months back, is one of my favorite DLP projectors. It too has really good color (I'd give the InFocus the edge), comparable to the Optoma. Both produce that pleasing image. Where the Sharp has its big advantage is black levels where it is significantly better than the Optoma (or InFocus). The Sharp does really well at blacks. If you favor DLP projectors, and are spending more, I really like the Sharp.
Then, there's the Viewsonic - which started out a year plus, ago, as an under $5000 projector, with a few extra bells and whistles. Recently, though, the price has plummeted, to less than $2000 as they have dropped price and made it available online. While I wasn't a big fan of the Pro8100 at it's original price, it's another good projector right now for well under $2000. It too would provide another higher performance choice, this time for probably $400 to $700 more.
I have the Viewsonic Pro8100 and it was basically $250 more for a substantial upgrade.
Of course if you only have $1000 to spend, then the HD20 is the only choice...for now
novasol is offline
post #745 of 4170 Old 09-02-2009, 04:21 PM
Charles R's Avatar
Liked: 645
The projector actually displays the image at 48Hz (doubles the 24Hz). So I'm guessing there isn't that much of a difference.
post #746 of 4170 Old 09-02-2009, 06:08 PM
guitarman's Avatar
Quoted: 14 Post(s)
HD20 owners pls try the HDMI Blu ray colorfacts numbers I posted in my reivew thread. These lower the brightness down and also lowers the black level way down for movie watching. Give them a try and let me know it they work for you?
Tom/guitarman
VideoDementia
post #747 of 4170 Old 09-02-2009, 06:09 PM
bskousen's Avatar
A major retail store with a web site has the Optoma HD20 with a GrayWolf II 106" manual wall screen for $999 with free shipping. Is this a good deal? I don't know anything about the GrayWolf brand other than it is manufactured by Optoma I believe. I was going to wait until a few other $1,000 1080p dlp projectors came out in the next two months, but the retailer has a 90 day return policy so I thought it might be too good to pass up. This retailer has a habit of running out of stock rather quickly so I jumped on it.
bskousen is offline
post #748 of 4170 Old 09-02-2009, 06:14 PM
Dougie085's Avatar
Basically getting a free screen so I'd say it's a pretty good deal. And free shipping.
post #749 of 4170 Old 09-02-2009, 07:12 PM
Quoted: 51 Post(s)
Liked: 47
Originally Posted by guitarman View Post
Why would anyone summon up a post like this in a specific Offical Optoma HD20 owners thread. Bad taste really. Start a new seperate thread on how great you like your viewsonic. I doubt they'll be a run a viewsonics anytime soon.
+1.
There have been too many posts like this in this thread. The mods have already cleaned it up once. Makes you wonder why some posters are so desperately trying to convince people NOT to buy the hd20...
Robert Clark
post #750 of 4170 Old 09-02-2009, 07:13 PM
mjskywalker's Avatar
I have the HD20 with a Greywolf II Screen and it looks fantastic. I think it helps with the blacks everyone is complaining about. I bought by screen for about $250 on Amazon and I think at the time it was originally about $400. So yeah I think that is a good deal.
Just a thought maybe they are bundling the projector cause it works best with a grey screen.
Jason
mjskywalker is offline
Optoma Hd20 Dlp 1080p Home Theater Projector
