Taking a leap into FJ? - AVS Forum | Home Theater Discussions And Reviews
Old 08-27-2009, 06:52 AM - Thread Starter
02saleen346's Avatar
I know cedia is around the corner but wanted some input. Im trying to narrow it down to a couple of projectors. My room is 16X14, Dallas Mavs blue, its going to have some amb light and its main use is going to be for HDTV, Movies and Sports. The models im looking at getting are: Infocus IN80, Epson 6100 or 6500. I havent decided on my screen but have considered a paint on one. What would be a nice screen under or around $800? The projector will be paired with my Pioneer Sc07 and Pioneer 23fd blueray player. Im trying to stay under $2500 for my first build but also want a good picture. From what I have read over the last month its not hard to do with the lower end models with 1080p. I probably need to demo some in person but dont know where to start here in Dallas Tx.
02saleen346 is offline
Old 08-27-2009, 07:22 AM
buddahead's Avatar
You should be able to get a Carada screen for that.You won't find a better screen unless you get into the 2k area.Many here use Carada as I do.Check with them.Their servive is 2nd to none.Also call AVS they sell good screen to.
buddahead is offline
Old 08-27-2009, 08:04 AM - Thread Starter
Thanks. Will it matter what projector or how much light is in the room for what screen I go with? Forgot to add the panny ae3000 I was consider going with as well.
Old 08-27-2009, 08:19 AM - Thread Starter
I guess it would also help if I put I was looking at getting a 100" screen.
