*Unofficial* Mitsubishi HC3800 Thread - Page 213 - AVS Forum
post #6361 of 6389 Old 03-10-2014, 07:10 AM
ovsims's Avatar
I'm using windows 8 but I connected my camcorder with a different hdmi cable and the problem was still there. I bought this projector new but it was in the box for over a year until last year when I finished my room so this is my first bulb that came with it. So it's out of warranty. I don't think I noticed the problem when I first started using it but it is definitely there now
ovsims is offline
post #6362 of 6389 Old 03-10-2014, 11:01 AM
gregoryperkins's Avatar
Quoted: 17 Post(s)
Have you tried applying some of the settings earlier in this thread? I am using a grey screen which will have slightly different settings from a white screen. Your bulb changes a lot in the first hundred hours, so it's not to surprising that you are seeing a difference.
How did you find this projector new a year ago, it came out in 2009? I've had mine for over 4 years.
gregoryperkins is offline
post #6363 of 6389 Old 03-10-2014, 11:57 AM
ovsims's Avatar
I've had this well over a year I bought it late 2010 I used it for like a month in my bonus room and decided that it was too small for the projector and I then decided to turn my garage into my HT room. I put it back in the box and it stayed there until late 2012. So I don't remember it being a problem when I first used it but it's there now. I don't even watch the projector now cause the glare or cloudiness makes my eyes hurt. Yes I've tried all kinds of different settings from this thread and other sites. My screen is white.
ovsims is offline
post #6364 of 6389 Old 03-10-2014, 01:39 PM
Quoted: 17 Post(s)
I assume that you've cleaned the lens. I can't think what would be causing it.
post #6365 of 6389 Old 03-12-2014, 08:49 PM
ovsims's Avatar
I feel like such an idiot. It was the lens after all. It wasn't dust though it was some kind of film on it maybe from using the fireplace else I don't know what or how it got there.  I had to take it off the ceiling mount to see it. I used a microfiber cloth to clean it and the glow was gone. Thanks to all for your help.
ovsims is offline
post #6366 of 6389 Old 03-12-2014, 08:51 PM
Jim McC's Avatar
Quoted: 21 Post(s)
Liked: 33
That's good news. Mine is still going strong with about 2500 hours on the bulb.
Jim McC is online now
post #6367 of 6389 Old 07-24-2014, 06:31 PM
Liked: 0
Mitsubishi Hc3800 vs BenQ W770ST
Hi, I'm looking to buy my first projector and joined this forum to ask some questions.
Right now, I'm looking to get either a gently used Mitsubishi Hc3800 with 700 hours of viewing time at around $350
or
a new BenQ W770ST at $500.
I know that the Hc3800 was a much higher end product at the time of its release, but considering all the advances in technologies in the past 5 years, which would be a better deal? Also, lack of 3D is not an issue for me at all. I'll be viewing art house movies on Blu Ray.
Thanks in advance for the replies!
doyawn is offline
post #6368 of 6389 Old 07-25-2014, 09:52 AM
Selden Ball's Avatar
Quoted: 792 Post(s)
Liked: 521
I have over 2000 hours on my 3800. Your price is only slightly more than the cost of a new lamp bulb for it, so it's a reasonably good deal.
At one point there was a promo which provided a new bulb for free. You might ask if the previous owner took advantage of it, which might explain the low hours.
Make sure the firmware in the 3800 is up to date. The initial release had a tendency to shut down the projector when it received a signal it didn't like.
I have no experience with the BenQ, so can't comment there.
Selden
Marantz SR7009/7.1.4/FH+TM/DefTech PM1000/LCR+TM amped
Selden Ball is offline
post #6369 of 6389 Old 10-24-2014, 10:48 AM
bjw122's Avatar
Please recommend reputable lamp / bulb vendor
I've had my HC3800 for a number of years now. It came with a free replacement bulb, which is currently in use. I'd like to buy either a replacement lamp with housing, or a replacement lamp (and then replace the bulb in the existing housing by myself) so that I have it on hand for when the existing one reaches end of life. I've looked at the replacements available on Amazon.com and I noticed that there's a good number of bad reviews -- people that aren't happy because they got a replacement with restricted ventilation in a "compatible" housing, etc.
Where can I buy a factory replacement bulb, or bulb with housing, that is a reputable source and offers a fair price?
Thank you,
bjw122
bjw122 is offline
post #6370 of 6389 Old 10-24-2014, 06:22 PM
Legairre's Avatar
Quoted: 33 Post(s)
Liked: 70
Thank you,
bjw122
this the best place I know that has a 100% original OEM HC3800 lamp with housing for this price. It says pre-order because they don't keep it in stock and order it from the manufacturer when you place the order. I called after ordering mine and they said it takes 10 days to get it from the manufacturer and then a few more to get to you. Mine came in the Mitsubishi box with the manufacturer's warranty. It's an exact match to the one that came with my HC3800.
http://www.projectorlampexperts.com/...ProductID=8050
They also have good info on how to spot fake lamps http://www.projectorlampexperts.com/...tYourself.aspx
"What do you mean it's too loud? My ears aren't even bleeding yet!"
Legairre is offline
post #6371 of 6389 Old 10-24-2014, 06:27 PM
Quoted: 17 Post(s)
Yow $250 for a bulb for a projector this old! But I agree, oem is best!
post #6372 of 6389 Old 10-24-2014, 08:54 PM
Legairre's Avatar
Quoted: 33 Post(s)
Liked: 70
Yeah they use to go for just over $300 so $250 is better, but still high. An OEM "equivalent" as some sellers call them are about $170 so I'd rather pay $250 for a true OEM and not have to deal with a possible lamp failure. Especially when my 3800 still throws a great picture.
Legairre is offline
post #6373 of 6389 Old 10-25-2014, 10:04 AM
bjw122's Avatar
Legairre -
Thank you for the info, that's very helpful! I appreciate you taking the time to address my questions. I have a follow up question. What's the difference between the bulb that you recommended for $250 and the ones sold on Amazon for around $80? There are multiple postings like this one on Amazon, and I'm wondering if these are just sub-standard, non-OEM bulbs, regardless of what the advertisements say on Amazon?
I tried to post a URL to the bulbs I was finding on Amazon, but I'm not allowed to use URL's in this forum because I'm still a newbie. However, if you go to Amazon.com and search for "HC3800 lamp" you will find them quickly.
Thank you,
bjw122
bjw122 is offline
post #6374 of 6389 Old 10-25-2014, 02:31 PM
Legairre's Avatar
Quoted: 33 Post(s)
Liked: 70
Legairre -
Thank you,
bjw122
Hey glad to help. What you'll usually find with the knock off lamps is either they have an original osram buld with a generic housing that is poorly designed and doesn't allow heat to escape or you'll just get a generic bulb in a generic housing. Looking at the ones on amazon it appears that's what they are selling. Unfortunately buying a so called OEM equivalent instead of a true OEM is a roll of the dice and most people don't have good luck with them.
Legairre is offline
post #6375 of 6389 Old 10-25-2014, 10:31 PM
mp06011999's Avatar
Quoted: 16 Post(s)
Liked: 40
Legairre -
Thank you,
bjw122
Brother, I cannot say this loudly enough...... BUY OEM AND NOTHING ELSE!!!!
I have tried several OEM "equivalents" over the years and the VERY BEST outcome I had was 1/2 the life for 1/2 the price life. Yep, I have tried these "deals" and NEVER would I do it again. Buy the OEM or nothing at all.
FYI, OEM retailers list was on the Mitsubishi web site as of about 4 months ago when I needed a new Lamp. BTW: A "BULB" is the the light part inside. A "LAMP" is the light part PLUS the housing.
mp06011999 is offline
post #6376 of 6389 Old 10-26-2014, 06:47 AM
bjw122's Avatar
Roger that, appreciate the advice based on your experience! I'll look at the Mitsubishi website to try to find that OEM retailers list you mentioned too.
Ok, so in the least I'm going to buy an OEM bulb, got it. Can I save considerable money by replacing the bulb in my existing housing, versus buying a whole new lamp? I found these instructions on how to replace the bulb in the housing, so I could just buy an OEM bulb (from a reputable dealer), and replace it. Any advice on that approach?
bjw122 is offline
post #6377 of 6389 Old 10-26-2014, 11:53 AM
mp06011999's Avatar
Quoted: 16 Post(s)
Liked: 40
Yes actually. I have tried buying just the bulb a couple of times and my old housings were so heat stressed that I really should not have reused them. They only lasted one year. Not bad since they only cost like $75 on Amazon. And I even once tried an OEM bulb placed in an aftermarket housing (purchased as one unit) and that one did not work at all. After those three attempts I decided never again. I have used about 4 OEM Lamps (complete assembly) and NEVER an issue. I debated trying the OEM bulb and switching it out myself as I did before, but decided to not because of how many hours were on the housing now. It would just be too heat stressed to reuse. The plastic and wires are really brittle.
I know $300 is a hard pill, but it is the only sure way to not get crap. I think bulbs are like cell phones nowadays where there is so much counterfeiting and outright lying. You take a gamble. Btw, I purchased my OEM bulb (Osram 230/0.8 E20.8 / BULB15 Factory Original Replacement Bulb Only) from Electrified on Amazon Feb 2013. I bought my OEM Lamp (complete assembly) in June from Projector People.
And in case you're wondering why I have had so many lamp replacements... These include friends' displays in addition to mine. From now on I tell them to just spend the money and buy the OEM Lamp. Then I don't get calls from them with issues afterwords.
post #6378 of 6389 Old 11-12-2014, 11:33 PM
Liked: 0
The latest software Mitsubishi hc3800
I have a mitsubishi hc3800. Yesterday mitsu shut down a few times. What is the latest software and how hc3800 updated? Do you have the link to the software? I have a mitsubishi connected to the computer? Sometimes you can watch 5 movies without any interference, but sometimes the projector will turn off a couple of times during one movie. Lamp has been viewed 270 hours. Mitsubishi firmware is now 3.0. I change my cable lenght to 15-25m, but that wont help (maybe little).
Sry my english.
Thx.
Ukiwf1 is offline
post #6379 of 6389 Old 11-13-2014, 10:01 AM
Legairre's Avatar
Quoted: 33 Post(s)
Liked: 70
Sry my english.
Thx.
The latest firmware I'm aware of from a couple of years ago was 6.0. The firmware can only be updated by Mitsubishi so you'd have to contact them and send it to them. I searched my emails and I called them at 1-888-307-0309 several years ago to get an RMA to send it in for a firmware update.
Legairre is offline
post #6380 of 6389 Old 12-04-2014, 10:59 PM
bjquinn's Avatar
So, another idiot here who blew into the cavity where the bulb housing goes when replacing a bulb. The projector now shows white spots everywhere. Hundreds of them, like a disco ball. Dust everywhere. I've read all about it online for the past couple hours. Is there anything I can do?
bjquinn is offline
post #6381 of 6389 Old 12-06-2014, 09:09 AM
mp06011999's Avatar
Quoted: 16 Post(s)
Liked: 40
I tried blowing air from a compressor at about 40psi to no avail. I had about two dust spots. They went away on there own after a couple hours of running the bulb on "high" to force the fan to run on high.
I have finger prints all over my image, but visible only when the picture goes all black. No idea where / how I did that when I changed the lamp - I wore nitrile gloves. Gotta get up there and see....
post #6382 of 6389 Old 12-06-2014, 12:58 PM
bjquinn's Avatar
Yeah, I've run the projector for about 36 hours straight now on high and it has seemed to dislodge some of the smaller particles, but all of the big ones are still there, as well as a bunch of others. Before it was lit up like a Christmas tree, but now there's just a couple dozen spots. It's bad. But perhaps getting better simply by running it on high for a while.
I've also read some people suggest using a vacuum cleaner (sucking air, not blowing it). Haven't tried that yet, but I may try that after leaving the projector on high one more day today.
bjquinn is offline
post #6383 of 6389 Old 12-07-2014, 09:02 PM
Jim McC's Avatar
Quoted: 21 Post(s)
Liked: 33
Vacuuming vents
When you guys vacuum the vents, do you do both vents? Thanks.
post #6384 of 6389 Old 12-08-2014, 08:00 PM
bjquinn's Avatar
Well, I'm probably not the one to elicit opinions from, since I destroyed mine, but I just tried vacuuming both vents AND the inside of the projector where the bulb housing sits fairly thoroughly, including what looks like a dime sized hole behind which possibly the color wheel sits. Certainly didn't seem to make it worse (although, fair warning, it's so bad, it's possible I wouldn't have noticed if it had gotten worse). But it didn't make it better either.
Are you having a problem with dust blobs showing up on the screen or are you trying to figure out how to do preventative maintenance? If you've got dust blobs, then I've tried running the projector on high nonstop for several days and when that didn't work, I tried vacuuming every crack, crevice, crease, and orifice that I could find without totally disassembling the projector. So far, no dice. I see a service manual online that I may be able to purchase for $10, and I'm considering trying that. I'm also considering finding a trustworthy repair shop if the disassembly seems too daunting, or perhaps even buying a used/refurb from Amazon or eBay (but of course, how do I know I won't get a unit that is already in worse shape -- perhaps dust, perhaps that nasty shutdown problem I was lucky enough to not run into). If you're in the same boat as me, please let me know what you've tried and I'll report back my results as well.
bjquinn is offline
post #6385 of 6389 Old 12-08-2014, 08:22 PM
bjquinn's Avatar
Update: I downloaded the service manual from http://www.smpcshop.com/Mitsubishi-H...ce-Manual.html. Cost me $10, but the place seems legit enough. Took the suggestion of another forumer and used PayPal but changed password temporarily immediately before and after purchase.
Anyway, I have no knowledge of the legality of sharing this type of thing -- not sure that this place that charged me $10 actually has any distribution rights, so perhaps they had no right to sell it to me and I shouldn't have a copy of it in the first place. Or perhaps they're just hoping a few idiots will pay them $10 for something that ought to be freely available. Anyway, if it's *legal* for me to do so, I would be willing to share the service manual with anyone who needs it. I'll have to defer to wiser posters on whether it is in fact legal or not.
bjquinn is offline
post #6386 of 6389 Old 12-17-2014, 08:58 PM
Jim McC's Avatar
Quoted: 21 Post(s)
Liked: 33
Anyone?
post #6387 of 6389 Old Yesterday, 08:18 PM
Legairre's Avatar
Quoted: 33 Post(s)
Liked: 70
I do both the intake and exhaust.
Legairre is offline
post #6388 of 6389 Old Today, 12:49 AM
Jim McC's Avatar
Quoted: 21 Post(s)
Liked: 33
Thanks. Do you use a normal vacuum or some sort of mini vacuum?
post #6389 of 6389 Old Today, 01:41 AM
Liked: 0
The second is the wave of cheap DLP 1080 projectors.
hmaredemei is online now
Mitsubishi Hc3800 1080p Home Theater Dlp Projector
Gear in this thread - Hc3800 by PriceGrabber.com
