*Unofficial* Mitsubishi HC3800 Thread - Page 215 - AVS Forum | Home Theater Discussions And Reviews
 3Likes
post #6421 of 6431 Old 02-08-2016, 04:40 AM
mp06011999's Avatar
Quoted: 21 Post(s)
Liked: 42
Mine's projecting a 144 inch image and I run mine on standard all the time. Another I installed for someone is projecting a 135 inch image and they too are running on standard. Eco mode is too dim for our tastes at those sizes. And even at that, still not bright enough given what TVs are doing these days. Just not ready yet to plop down 2 grand for an upgrade...
mp06011999 is offline
post #6422 of 6431 Old 02-09-2016, 03:29 PM
Legairre's Avatar
Quoted: 196 Post(s)
Liked: 139
What you guys have experienced is the same for me my HC3800. It just wasn't bright enough anymore. sure new lamps help but in low lamp mode even when new it was OK for BD or DVD, but things like sports it just doesn't have the pop, brightness and clarity of displays today. Sure 6 years ago it was fine, but now it just can't compare. Today's displays are so much sharper, clearer, brighter and display colors that pop so much more due to higher contrast. In high lamp it was brighter, but just too loud for me.
I finally broke down and bought the VPL-HS40ES. The contrast is something like 120,000:1 and it's calibrated true lumen is like 1700 in high and 1300 in low. I think the HC3800 is 25dB in low lamp mode and the 40ES is only 21dB in high lamp mode so it's inaudible 4 ft over my head in low. The 40ES is razor sharp, so clear it disgusting, so bright, and the colors and picture are just so far ahead of the HC3800.
I love the HC3800 and man trust me I hated dropping nearly 2K on a new projector. I had to make that choice we all make at some point. Put another lamp in something that at the time rivaled the best out there for 2k, but after 6 years just didn't impress me anymore due to technology having surpassed it's picture quality or bite the bullet.
I should mention that the HC3800 has features that I really miss like the weight. At just over 6lbs I could take it down and mount it myself, a lamp on the top so you didn't have to take it down to replace it, and no filter to clean every 700 or so hours. The 40ES is 22lbs so it's heavy. I can't mount it alone because it's so large and heavy you just don't want to risk dropping it while mounting it. Also the lamp is on the bottom so again it has to come down and the same for the filter.
I wish Mitsubishi didn't stop making projectors. I think they would have had a killer one at the right price as an HC3880/4000 replacement.
"What do you mean it's too loud? My ears aren't even bleeding yet!"
Legairre is online now
post #6423 of 6431 Old 02-10-2016, 05:14 AM
gregoryperkins's Avatar
Quoted: 216 Post(s)
Liked: 78
Yup, according to the wire cutter, you made a good choice! Luckily not many of my friends have projectors to give me envy. 2 have the 1070 and I haven't even seen them.
http://thewirecutter.com/reviews/the...-home-theater/
If your room’s measurements fit the bill and you want the best picture quality for your home, we heartily recommend the Sony VPL-HW40ES. After testing five leading models in the same price range, our projector guru Geoff Morrison writes that the Sony offers the best combination of performance and price, with lens features that make it easy to install and very low operational noise (which is great if you have a small room and the projector is mounted above your head). He also notes that “The HW40ES is one of the best projectors in its class at color accuracy.” In fact, at its current price, it’s even cheaper than our runner-up pick, the Epson 5030.
gregoryperkins is online now
post #6424 of 6431 Old 02-10-2016, 10:12 AM
Legairre's Avatar
Quoted: 196 Post(s)
Liked: 139
Yeah the 40ES is a real winner, but I do miss the HC3800. Before the HC3800 I had a Sanyo PLV-Z2 and then a Mitsubishi HC1500. I really like the Mitsubishi projectors and DLP with no filter to clean. The HC3800 was just rock solid for 6 years with no signs of quitting. I put three lamps in it and changed the first two around 4000 hours and had 1500 on the last one. So at nearly 10,000 hours it's still going strong with no noise from the color wheel and not a single problem in all those years. Just a great solid projector. When I got it I figured I'd have it 2 years, but 6 years later it's still going strong.
post #6425 of 6431 Old 02-10-2016, 04:12 PM
Jim McC's Avatar
Quoted: 85 Post(s)
Liked: 44
I have 3,300 hours on my HC3800, and was wondering if I should put my spare bulb in.
When you changed yours at 4000 hours, was there a huge brightness jump?
Jim McC is offline
post #6426 of 6431 Old 02-10-2016, 05:27 PM
Legairre's Avatar
Quoted: 196 Post(s)
Liked: 139
Yes I did notice a big jump in brightness and the colors popped again too. The new lamp did wonders for colors and brightness. The new lamp brought that wow factor back again.
post #6427 of 6431 Old 02-10-2016, 07:49 PM
Liked: 1
Sweets10v8 is offline
post #6428 of 6431 Old Yesterday, 08:06 AM
Quoted: 216 Post(s)
Liked: 78
It's strange, I didn't notice much of a difference in brightness, but I notice the blacks more. Maybe just improved contrast with additional brightness?
post #6429 of 6431 Old Yesterday, 09:45 AM
Legairre's Avatar
Quoted: 196 Post(s)
Liked: 139
Each time I replaced the lamp I replaced it with a 100% OEM that cost around $300 and noticed the brightness and colors popped right away. Really made me say "wow I had fogotten how good it can look". Was the lamp an OEM lamp? People have purchased non OEM lamps and said the brightness did increase.
post #6430 of 6431 Old Yesterday, 09:55 AM
Quoted: 216 Post(s)
Liked: 78
It was an Osram bare bulb, supposedly oem. It took me about an hour to get it into the enclosure. Only time will tell if it is the real deal.
post #6431 of 6431 Old Today, 08:57 AM
mp06011999's Avatar
Quoted: 21 Post(s)
Liked: 42
I won't go into the bulb thing again. Just know that every bulb I have ever purchased said Osram on it, but not every bulb was quality. ONLY the $300 ones were (would work and last everytime).
BUT, I can say, without a doubt, that a new bulb does breed new life into this projector. It makes me love it again. I think it makes the biggest difference when you are asking alot out of it to begin with. The larger the picture the larger / greater EVERYTHING is - good and bad. 144 inches is on the BIG side and really too much to ask of the 3800 these days. But I am done dropping money into a 6 year old projector. It would take $300 to give me that pop and awe that I love and then that would only last for about 1500 hours. Then it gets to dim for my taste. I've been through several lamps and I run it on "standard" and "bright mode" on. So does my buddy with his at 135 inches. Both our theater rooms are blacked out, mine more so with black from floor to ceiling and NO windows. It's just that as TVs get brighter, poppier and punchier so too must the projector. And sadly, the 3800 can no longer keep up.
I too am seriously considering the Sony. It's just hard to park a functioning projector and plop down another 2k. We'll see. I was so expecting to be into an LED or Laser projector by now. The projector field has stalled and narrowed :-( As a matter of fact, I tell anyone now that asks about projectors to NOT go projector if you are NOT going over 100 inches. Otherwise, just buy a TV. So much easier...
Mitsubishi Hc3800 1080p Home Theater Dlp Projector
