*Unofficial* Mitsubishi HC3800 Thread - Page 220 - AVS Forum | Home Theater Discussions And Reviews
 8Likes
post #6571 of 6577 Old 07-22-2017, 12:44 PM
Jim McC's Avatar
Quoted: 177 Post(s)
Liked: 64
Is anyone using a 4k ready A/V receiver with your HC3800? Because I cannot get my new Denon AVR-S530BT to play nice with my HC3800, using HDMI. I also tried doing it with a composite cable, and that wouldn't work either. I just get a blue screen, so I cannot do the Setup Assistant with the receiver. I already checked the HDMI cable from receiver to projector and it is good.
I just tried the receiver upstairs with my TV and it does work using composite, but will not work with HDMI.
Jim McC is offline
post #6572 of 6577 Old 07-22-2017, 04:37 PM
Legairre's Avatar
Quoted: 642 Post(s)
Liked: 337
Looking at the manual it's seems pretty straight forward. Connect HDMI cable to monitor out on the receiver and then to the projector. Then just hit Setup on the remote to get into the menu system. Since the cables are fine and the receiver's HDMI doesn't work on either the TV or the projector it's seems like a problem with the receiver.
Can you take it back and exchange it for the same model? Maybe you just got a bad one.
"What do you mean it's too loud? My ears aren't even bleeding yet!"
Legairre is offline
post #6573 of 6577 Old 07-22-2017, 09:14 PM
Jim McC's Avatar
Quoted: 177 Post(s)
Liked: 64
Thanks Legairre. I appreciate all the help you've given me. I'm just fed up. I may just return it and forget about a 4k receiver until I get a 4k projector.
The manual says I can also use a composite cable for the setup, but that doesn't work with the projector either. I currently have my old receiver hooked up again, using the digital optical cables (since the HDMI audio no longer works.
Jim McC is offline
post #6574 of 6577 Old 07-23-2017, 08:34 AM
Legairre's Avatar
Quoted: 642 Post(s)
Liked: 337
Hey Jim no problem at all. Glad to help. Since the Denon is HDCP 2.2 and the HC3800 isn't it's possible that the Denon requires an HDCP 2.2 display. Since the receiver worked on your TV is the TV a 4K TV which would mean it's HDCP 2.2.
Legairre is offline
post #6575 of 6577 Old 07-23-2017, 11:08 AM
Jim McC's Avatar
Quoted: 177 Post(s)
Liked: 64
The TV is not. It's a Toshiba LCD about 6 years old. It worked with the composite input but not HDMI.
I'm returning the Denon today, and I'm going to wait to buy a 4k receiver until I buy a 4k projector.
Jim McC is offline
post #6576 of 6577 Old 07-23-2017, 04:40 PM
Legairre's Avatar
Quoted: 642 Post(s)
Liked: 337
Ah ok then maybe it was an HDCP 2.2 issue since neither the TV or projector are HDCP 2.2 compliant and neither worked over HDMI.
Have you decided which other receiver to buy?
Legairre is offline
post #6577 of 6577 Old 07-23-2017, 08:38 PM
Jim McC's Avatar
Quoted: 177 Post(s)
Liked: 64
I'm not buying one until I get a 4k projector. I'm using the one I had hooked up before this whole fiasco. The lightning apparently ruined the HDMI audio, so I'm using it with digital optical.
Jim McC is offline
Mitsubishi Hc3800 1080p Home Theater Dlp Projector
