Official Sony VPL-HW15 Thread - Page 23 - AVS Forum | Home Theater Discussions And Reviews
post #661 of 682 Old 06-14-2012, 09:16 AM
Giganer's Avatar
Hello to all enthausiastic users of sony VPL-HW15,
my unit is working now since 2009. It is still a pleasure for me to look Blurays.
But now i want to start a new project. My uncle gave me his whole LD Collection including Pioneer CLD 1750 PAL/NTSC Player. Iam trying to get the best picture quality of my LDs.
Does somebody use the Sony HW15 with a LD Equipment? Any advice for me? I know that i have to use the Composite out and in best case i have television or beamer with an 3d comb filter. Is there an 3d combfilter inside the hw15 or not? Iam searching now for many days but i could not find any information about this tech spec.
Thanks in advance folks
Giganer
Giganer is offline
post #662 of 682 Old 06-16-2012, 07:35 PM
LARUE's Avatar
To really get the most from the LD collection, I'd look for a new player.
I've never seen video of quality come out of a Composite-jack.
Look for a Pioneer with Component video outs.
just my $.02
LARUE is offline
post #663 of 682 Old 06-20-2012, 03:10 PM
Giganer's Avatar
But even a Pioneer LD/DVD combo player with YUV Output only uses YUV for the DVD part. Nobody, who knows if the HW 15 has a 3d comb filter?
Giganer is offline
post #664 of 682 Old 09-27-2012, 02:34 PM
Mac.Concierge's Avatar
If I want to use Anamorphic Lens with this projector, which screen mode should I select? Normal? Full? Zoom? Wide? Wide Zoom? Full1? Full 2?
Vertical squeeze will be done by Lumagen Radiance
Mac.Concierge is offline
post #665 of 682 Old 05-14-2013, 12:24 AM
JulianS-ZA's Avatar
Hi
Has anyone else encountered a green cast in parts of the projected image?
I've just bought an HW15 2nd hand and am trying to determine whether the unit is defective.
The following projected image : https://dl.dropboxusercontent.com/u/92590676/grey-hw15.jpg
Is the projection of this plain grey image: https://dl.dropboxusercontent.com/u/92590676/Grey.jpg
The image being projected has various colour tints, the most noticeable being the green tint in the upper right section of the image.
Here a few frames from movies where this tint is clearly visible:
https://dl.dropboxusercontent.com/u/92590676/_DSC9972.jpg
https://dl.dropboxusercontent.com/u/92590676/_DSC9976.jpg
https://dl.dropboxusercontent.com/u/92590676/_DSC9984.jpg
I'd appreciate anyones feedback on this.
Julian
JulianS-ZA is offline
post #666 of 682 Old 05-14-2013, 01:51 PM
LARUE's Avatar
Is it evident in color shots?
I'm sure I've viewed B&W stuff occasionally and not noticed any color-impurities. But I'm at the point now where I just enjoy my setup without an eye for constant tweaking.
Your problem kinda looks like the old degauss problem on a CRT monitor.
If I get a chance I'll dig out Hard Days Night or something and give a critical look-see.
Anyone else? (It would be nice to know if there are other VPL-HW15 viewers still out there!)
~LARUE
LARUE is offline
post #667 of 682 Old 05-14-2013, 01:58 PM
JulianS-ZA's Avatar
Yeah it is just as visible in color shots - skin tones take on a green hue when the actor is positioned in the affected areas of the frame.
I've done some digging and appears in the service menu there is an extra calibration section for gamma rgb levels.
I've found that anywhere I'm seeing the green shift, the green has been adjusted signficantly up compared to where I'm not seeing the hue.
I don't know if there is a way to do a factory reset on these settings, as it is going to be very time consuming to fix these settings.
There are about 127 positions to adjust, multiplied by 11 different gamma levels.
If anyone know's of such a feature, please let me know.
post #668 of 682 Old 05-15-2013, 09:56 AM
convexion's Avatar
Have you thoroughly cleaned the lens and lamp? It's possible that there is something in the light path that is causing that. Just don't use canned air or anything like that, a camera lens cleaner might do the trick. I also wonder if maybe the alignment was thrown off through the act of shipping. It could be ever so slightly deviated. Have you tried shifting the panels out of sync with one another to see if the problem still exists as shown?
convexion is offline
post #669 of 682 Old 05-17-2013, 09:18 AM
JulianS-ZA's Avatar
Yip I have tried using the builtin function, the panel alignment is spot on.
correct me if I'm wrong, but In theory misaligned panels would cause a loss of sharpness, and potentially a color shift in the entire image?
post #670 of 682 Old 05-19-2013, 02:50 PM
convexion's Avatar
A slight misalignment would definitely cause blurring and color separation. If the picture looks sharp it's probably not that. Hopefully someone with more technical knowledge on this projector can chime in as I'm only familiar with the basics of it.
post #671 of 682 Old 09-17-2013, 06:33 PM
LARUE's Avatar
Anyone replaced the bulb in their HW15?
LARUE is offline
post #672 of 682 Old 09-18-2013, 07:12 AM
FeeFi's Avatar
Yes I am on my third bulb.  Why do you ask?
FeeFi is offline
post #673 of 682 Old 09-18-2013, 08:54 AM
LARUE's Avatar
I guess I was wondering if anyone had any tips or cost saving measures.
Things have gotten tight here but I hate to have my projector sit dormant.
I've even considered doing a bulb transplant.
Any tips FeeFi?
LARUE is offline
post #674 of 682 Old 09-19-2013, 05:43 AM
FeeFi's Avatar
Since this was my second projector that I owned I learned from the first one that the best deal on the bulbs is when the projector first comes out.  The longer in time you keep it the more expensive the bulbs get.  Just like printer ink.  I bought 3 bulbs 6 months after this projector came out.  I haven't put in my last bulb yet.  So I can't help you on getting a good deal but the replacement is very easy if you don't have it mounted up to high or if you can't access it without taking it off the mount.
FeeFi is offline
post #675 of 682 Old 09-19-2013, 09:45 AM
LARUE's Avatar
That's a great tip on bulb buying! Do you remember what a bulb was selling for?
LARUE is offline
post #676 of 682 Old 09-19-2013, 09:46 AM
FeeFi's Avatar
No not at this time.
FeeFi is offline
post #677 of 682 Old 04-06-2014, 12:24 PM
drjay71's Avatar
Hello all. I was wondering what your opinion of the HW15ES is as a 2D projector in a dedicated theater room? I am able to get a good deal on this projector and would like to know if you would rather get this projector compared to a BenQ1070 or an Optoma HD25 if you are only interested in watching 2D in a dedicated room
drjay71 is offline
post #678 of 682 Old 04-06-2014, 06:58 PM
jjgriffi's Avatar
The Sony is still a very good projector for 2D in a dedicated theater room. Beautiful picture. The only thing the newer projectors have is slightly better absolute zero blacks and 3D (which is not a feature of this projector). I use one to this day since it came out. I am only going to upgrade when I find a good 4K projector (at a reasonable price) in a couple of years.
Just bought a bulb from B&H - real SONY factory bulb, housing, filter, etc... not a knock off like most are for the similar or lessor price.
jjgriffi is offline
post #679 of 682 Old 07-09-2014, 10:10 AM
punkguy666's Avatar
Magically I'm still on my first bulb but mine just popped up with a warning to clean the filter. I have two questions. Do I clean the filter or replace the filter? Also should I swapp out my bulb now while it is down or wait for it to crap out? I'm going to remount it to get rid of a small horizontal keystone issue
punkguy666 is offline
post #680 of 682 Old 07-10-2014, 02:10 PM
jjgriffi's Avatar
If the brightness is good, I would clean the filter and reset the timer. I did this with my original bulb. After about 3050 hours the bulb finally died. New bulb was brighter but the colors were still the same.
jjgriffi is offline
post #681 of 682 Old 08-09-2014, 09:17 AM
omholt's Avatar
I bought a used HW15 recently. I was wondering if anyone can give some tips regarding calibration and settings. I understand a projector is best calibrated individually in the room, but I assume colours and some other features are more or less similar and it doesn't have to be perfect. It's the colours I'm reacting too and they are obviously not correct set up with neither of the modes. I really would like to get the colours more accurate. Contrast and light is something I can do myself based on a test disc.
My bulb in the projector is close to 1800 hours. However, I have a new bulb and can replace it if that's important to calibration.
omholt is offline
post #682 of 682 Old 08-11-2014, 10:43 AM
YONEXSP's Avatar
Has anyone upgraded to the VPL-HW40 or VPL-HW55 recently from the HW15?
Was it worth it?
Do you see a big difference in 2D quality? 3D I don't care about
I am at the end of my 2nd bulb and the projector is mostly used for kids movies & the XBONE
Wobdering if the picture quality is worth the expense, as I would like better black sin darker scenes, but the kids don;t care. It has been a great machine for gaming
YONEXSP is offline
Sony Vplhw15 Home Theater Sxrd Projector
