Epson 8500UB 200,000:1 CR - Page 22 - AVS Forum | Home Theater Discussions And Reviews
 19Likes
post #631 of 3663 Old 11-21-2009, 06:38 AM
elmalloc's Avatar
Quoted: 141 Post(s)
Liked: 86
not barbaric but puny
Projects:
NOT STARTED - Theater (Sim2 HT380, CIH 13ft wide).
IN PROGRESS (10%) - Home LAN (4 PCs).
Game room:
Epson 5040UBE, Denon S920W, Philips BDP7501, NVidia Shield TV, PS4 Pro, SI 110"
elmalloc is offline
post #632 of 3663 Old 11-21-2009, 07:21 AM
Jason Turk's Avatar
Originally Posted by VideoDrone View Post
Yeah, this is my 5th weekend watching football on a 50 plasma....how barbaric is that?
It's blasphemy! Sad part is I have a high end projector (JVC RS35) and a 10.5' wide 2.35:1 screen with high end sound system. I find that 99% of the time I watch my 50" Panny plasma through the internal TV speakers.
Jason Turk is offline
post #633 of 3663 Old 11-21-2009, 07:52 AM
jhunt17's Avatar
Hey, if you really don't like it that much and would rather watch your tv. I could take it for you to clear up your space. Just trying to be neighborly.
jhunt17 is offline
post #634 of 3663 Old 11-21-2009, 08:50 AM
badgerpilot's Avatar
Quoted: 75 Post(s)
Liked: 45
TV's have speakers?
badgerpilot is offline
post #635 of 3663 Old 11-21-2009, 09:04 AM
sethk's Avatar
I've found myself doing the same recently. Although probably more like 90% in my case. When I have a good movie on Blu-ray, two hours to dedicate, I make a night of it. Otherwise, I just turn on the flat panel to watch CNN or Discovery for a bit - doesn't make sense to go to the HT room, sit in the dark and turn on the PJ for 1/2 an hour, especially for 'regular TV'. All the same, it makes the movie night all that much more of 'wow' experience. It blows me away each time!
Eventually I'll probably get an ultra bright projector for the living room with something like a motorized black diamond screen that just drops in front of the plasma - something that still looks good (and is bright enough) with subdued ambient lighting.
sethk is offline
post #636 of 3663 Old 11-21-2009, 09:20 AM
Greatone666's Avatar
So I am still considering getting a panasonic AE4000 over the Epson unit. Mainly because of their implentation of CFI vs Epsons. But I am wanting to factor in my particular situation. I have the capability of hanging my projector anywhere from 9 to 15 ft from my screen. My screen is a white screen with a 1.1 ratio. I have my lights on a dimmer and I essentially have a cave. 0 light if I choose and dark green walls and a dark blue cieling. I will watch sports during the footbal season but my primary use would be for movies and gaming. If I chose the panasonic how far away should I hang it for a good balanced performance. Also does it make more sense to wait on the Epson? If so why?
Greatone666 is offline
post #637 of 3663 Old 11-21-2009, 09:49 AM
Deja Vu's Avatar
Quoted: 939 Post(s)
Liked: 956
I'm choosing the Epson over the AE4000 because of its FI implementation! I'm familiar with the present implementation of FI and low with movies looks great. I want a more aggressive, artifact free, FI in normal and high modes for animation and music concerts.
I just reread Cine4Home's Epson review again and these guys were really impressed with the FI in all modes.
Deja Vu is offline
post #638 of 3663 Old 11-21-2009, 11:20 AM
dunb440's Avatar
Link to the rebate in case anyone wants to get a head start filling it out...
http://www.bhphotovideo.com/FrameWor...SON_8500UB.pdf
CkOut The Rainforest Theater!
http://www.htnut.com/
dunb440 is offline
post #639 of 3663 Old 11-21-2009, 11:21 AM
dunb440's Avatar
Hey Jason, Can you post a link to the PDF manual for the 8500 when you get it pleaze?
dunb440 is offline
post #640 of 3663 Old 11-21-2009, 01:46 PM
cdnscg's Avatar
Quoted: 381 Post(s)
Liked: 77
Does anyone know if the 8500ub has the input to hook up a 12V trigger to activate an electric screen?
cdnscg is offline
post #641 of 3663 Old 11-21-2009, 02:15 PM
rprice54's Avatar
Quoted: 94 Post(s)
Liked: 45
Also, what kind of cable would one use to trigger a screen? Could I use a 50' cable?
rprice54 is offline
post #642 of 3663 Old 11-21-2009, 02:20 PM
Yes it does.
http://www.projectorreviews.com/epso...500ub/tour.php
post #643 of 3663 Old 11-21-2009, 02:24 PM
I looked at the picture of the back panel of the projector. It looks like a simple 1/8" mono cable. These things require a relatively low voltage. I would guess a 50' mono cable would work fine.
post #644 of 3663 Old 11-21-2009, 03:27 PM
cdnscg's Avatar
Quoted: 381 Post(s)
Liked: 77
If someone can confirm exactly what type of cable (including ends) that would be great. I need to run the cable through the ceiling soon before they finish the plastering of my basement. Also, I trust most electric screens have the trigger cable input. I'm looking at the Da-lite Tensioned Cos. Electrol. I'm trying to avoid paying for the expensive addition of the RF remote control for this unit. In Canada they are asking $300-350.
cdnscg is offline
post #645 of 3663 Old 11-21-2009, 05:11 PM
dunb440's Avatar
If you run a simple CAT5 or even speaker wire, you can put the mono 3.5mm end on later.
http://www.tvcables.co.uk/images/ite...ca-adapter.jpg
the projector end will look like this, the other end depends on your trigger input, maybe this or RCA...
Probem solved.
dunb440 is offline
post #646 of 3663 Old 11-21-2009, 05:17 PM
rprice54's Avatar
Quoted: 94 Post(s)
Liked: 45
I found a stereo 50' cable on amazon but no mono. Will stereo work?
rprice54 is offline
post #647 of 3663 Old 11-21-2009, 05:25 PM
dunb440's Avatar
You need mono.
Do you have a radio shack nearby?
Just get a 50' spool of speaker wire and a 3.5mm to 3.5mm 3' cable for $2.
Cut the mono cable and add the two ends to the speaker wire..
All done for under $10.
dunb440 is offline
post #648 of 3663 Old 11-21-2009, 05:35 PM
robber616's Avatar
will buy epson 8500ub soon but i'm worry about stuck/deah pixels. should i buy QC service to check for dead/stuck pixels, dust blobs, convergence errors, etc...?
robber616 is offline
post #649 of 3663 Old 11-21-2009, 06:20 PM
richardyc's Avatar
Quoted: 25 Post(s)
rebate doesn't work for bestbuy instore or online purchase, maybe they will have it as an instant rebate?
richardyc is offline
post #650 of 3663 Old 11-21-2009, 07:32 PM
noah katz's Avatar
Quoted: 1021 Post(s)
Liked: 351
"I just reread Cine4Home's Epson review again and these guys were really impressed with the FI in all modes."
Got a link? For the life of me I can't find anything recent at the cine4home site on Epson.
Noah
noah katz is online now
post #651 of 3663 Old 11-21-2009, 08:40 PM
Jackattack51's Avatar
Quoted: 23 Post(s)
If you are worried about QC issues order it from AVS and ask Jason to perform his check over it. Plus if you call him soon you should be pleasantly surprised about how much it will cost after everything is said and done.
Jackattack51 is offline
post #652 of 3663 Old 11-21-2009, 09:28 PM
robber616's Avatar
Will order from Jason soon, i just worry because look like 6500 have some problems
post #653 of 3663 Old 11-22-2009, 02:04 AM
Petepurple's Avatar
__________________
I'd like that link too. Does anybody know of such a thing?
Peter
Petepurple is offline
post #654 of 3663 Old 11-22-2009, 05:46 AM
VideoDrone's Avatar
I have never seen a Panasonic you could watch in daylight, with my old Epson 6100 I could turn on 10 can lights in the basement and still have a watchable picture. My buddy has a Panny 3K and you need all lights out, and then the image is soft with that smooth screen stuff. Even the reviews support the same for the new 4000 vs 8500, its Epson all the way for me.
AV since 1980
VideoDrone is offline
post #655 of 3663 Old 11-22-2009, 12:24 PM
daiglem's Avatar
I've got an 8500 on order. In my current setup (Epson Cinema 550), I simply have it mounted via a plumbing pipe on a piece of black particle board with holes cut in the right location for the mounting screws.
Might do the same with the 8500, but toying with the Monoprice mount. Anyone have experience with this mount, and any knowledge if it will fit the 8500?
thx for any info or experience with the 6500, 6100 or 8100.
Cheers!
-M
daiglem is offline
post #656 of 3663 Old 11-22-2009, 01:20 PM
Deja Vu's Avatar
Quoted: 939 Post(s)
Liked: 956
Check page 4 of this thread - Darinp2 gives the link. I just tried the link again and it doesn't work now. At the time I printed out the whole review. What would you like to know?
Deja Vu is offline
post #657 of 3663 Old 11-22-2009, 02:27 PM
noah katz's Avatar
Liked: 351
"What would you like to know?"
What on/off and ANSI CR he got, brightness, how much highlights were dimmed by the DI in dark scenes.
Noah
post #658 of 3663 Old 11-22-2009, 08:10 PM
stuuke's Avatar
Originally Posted by conan48 View Post
I wonder what people did back in the day before there were projectors Instead of staring at a blank wall you could do a puppet show for the family, or play board games, or talk to each other, or sing songs, or cancel thanksgiving because the damn projector won't be there on time and just tell them to come over for Christmas instead.
If I could pull off a puppet show or board game in 1080p with 7.1 surround sound I would be all over it. and the idea is to not talk to my family
stuuke is offline
post #659 of 3663 Old 11-22-2009, 11:20 PM
Dr Lecterr's Avatar
I am about to pre-order the 8500UB. Where do I go to order it from Jason? I would like to support the foum, but just not sure where to look. Thanks
BTW - started working on the theater about a week ago. I will have a theater build thread starting pretty soon. watch for it!
Dr Lecterr is offline
post #660 of 3663 Old 11-23-2009, 12:56 AM
rwestley's Avatar
Quoted: 144 Post(s)
Liked: 97
Go to the AV Science Store link at the top of the page to order from Jason.
rwestley is offline
Epson Powerlite Home Cinema 8500 Ub Lcd Projector V11h337020
