Panasonic PT-AE4000 Projector Unveiled - Page 30 - AVS Forum | Home Theater Discussions And Reviews
 4Likes
post #871 of 874 Old 08-24-2010, 10:25 AM
Alan Gouger's Avatar
Quoted: 31 Post(s)
Liked: 57
Originally Posted by JoeTiVo View Post
I'm considering this projector as an upgrade to my existing AX200U. From the specs I've read and using the above posted calculator, I believe it will work in my theater. However, I'd love some confirmation as I've read a few things that make me wonder.
My theater is completely light controlled. The projector will be 22' from a 126" 16:9 screen. The AX200 performs very well within these parameters. Shouldn't the AE4000 do just as well?
Joe looking on projector central the AX200U has a slightly longer zoom range. Both are the same but the AX200 can go a little closer.
AX200U: Zoom: Manual, 2.00:1 Throw Dist (feet) : 7.9 - 20.3
AX400U:Zoom: Power, 2.00:1 Throw Dist (feet) : 11.5 - 19.7
Alan Gouger is offline
post #872 of 874 Old 08-30-2010, 05:36 PM
dogone's Avatar
It will work fine...I replaced the AX200 with the AE4000 and from the same distance, I didn't notice any change...I have mine projecting from 23 ft and there is plenty of room in both directions... I'm just confused as to why this projector is not in the "under 3000.00 thread?"...It should not be in this thread...
dogone is offline
post #873 of 874 Old 08-31-2010, 01:40 PM
Chiahead's Avatar
This thread was created before the price was released. So it has stuck around in this area since then. There is another thread in the under 3000 section that gets way more eyes.
Remember the 3000 on release date was allot more than the 4000. The 4000 was a really nice surprise when the price came in.
http://www.avsforum.com/avs-vb/showthread.php?t=1186232
Michael
PSN: Chiahead
Chiahead's Man Cave - Indexed
Loganed on 8/29/2008
Chiahead is offline
post #874 of 874 Old 09-01-2010, 09:33 AM
JoeTiVo's Avatar
Quoted: 45 Post(s)
Liked: 41
Originally Posted by dogone View Post
It will work fine...I replaced the AX200 with the AE4000 and from the same distance, I didn't notice any change...I have mine projecting from 23 ft and there is plenty of room in both directions......
Excellent! That's just what I was hoping to hear. Thanks for replying with your experience.
Steve
"If you choose not to decide, you still have made a choice."
My DVDs
My Theater
Theater Construction Album
JoeTiVo is offline
