Panasonic PT-AE4000 MSRP $1999 - Page 218 - AVS Forum | Home Theater Discussions And Reviews
 24Likes
post #6511 of 8676 Old 02-06-2011, 06:03 AM
korkster's Avatar
Quoted: 48 Post(s)
Liked: 24
Thanks. I have the auto sensing switch as set to manual so that I chose which input to use with my remote. And I had the Oppo off when I first hooked it up. It just seems the pj doesn't like the signal for some reason, regardless of which input. I even used the input that I had the Oppo plugged into since that has been working flawlessly for Blu-Ray. The same thing happened. I have no issues with the component input from the cable box, so I guess I'll have to stick with that. I wanted to use the HDMI to a switcher so that I would have the option of using the same cable box for my flat screen as well, but the box disables the component output once you hook up a HDMI cable, so I can't use both.
korkster is offline
post #6512 of 8676 Old 02-06-2011, 11:16 AM
wruss64's Avatar
Have you already purchased the HDMI switch? Been awhile since I bought mine but I am just wondering if any of them come with some type of signal booster. I know it is only a 12' cable and should work on anything, but I just cannot imagine it being anything else, but like you said, doesn't make sense really. I see an OPPO out there that gets some good reviews from guys that have had the same problem and the OPPO corrected the issue, but it appears to be dq'd. There are others, but hard not to trust OPPO since you already have their DVD player, as do I. Talk about getting ride of Blu Ray issues, I love it.
Another grabbing at straws thought, on the pj do you have signal set for "normal" and not "wide"? Doubt it makes a difference on whether or not the pj pics up signal, but I feel your frustrations.
wruss64 is offline
post #6513 of 8676 Old 02-08-2011, 12:42 PM
SD Vidiot's Avatar
Korkster,
I would try switching cable boxes. If your cable company has different brand boxes, you should check that out. Those HDCP handshakes are very idiosyncratic: what works on one box may not work on another despite adhering to the standards. On my Panasonic plasma, the Scientific Atlanta box had all kinds of problems but the Pioneer stb works smooth as glass.
HB
Bear's Lair Home Theater
Howie: "I think my screen may be TOO big."
Norm: "Screens are like breast implants..."
SD Vidiot is offline
post #6514 of 8676 Old 02-09-2011, 02:07 PM
JCAnderson's Avatar
I just installed my new AE4000 and the picture is great, but there is a slight difference with the audio/video sync. The video is slightly behind the audio. I replaced an AE900 with the 4000 changing nothing else. The sync on the 900 was perfect. I am using DirecTV as my input to a Sony STR-DG720 receiver and HDMI to the projector. Any thoughts on what my problem could be?
JCAnderson is offline
post #6515 of 8676 Old 02-09-2011, 02:29 PM
Quoted: 14 Post(s)
Great question JCAnderson, I also have this issue with my PT-AE4000U projector. I'm also using DirecTV going thru a Denon AVR-2809CI. I only notice the problem when on SAT but when using Blu Ray the problem is not there. It would be great to figure out how to eliminate this issue!
HiDef Lover is offline
post #6516 of 8676 Old 02-09-2011, 02:30 PM
Bob Whitefield's Avatar
Quoted: 13 Post(s)
Welcome to the joys of lipsync. The AE4000 performs significant processing in some of its frame interpolation modes, which delays the video with respect to the audio.
Looking at the manual for the STR-DG720, looks like your sole remedy is to set the AV SYNC setting in the AUDIO menu to yes, which will delay the audio by 60ms.
http://a248.e.akamai.net/pix.crutchf...158STDG720.PDF
You can minimize the delay on the AE4000 by setting frame creation to mode 1 or off, although I find mode 1 essential to reducing judder, while the higher modes can be distracting. There's also a frame response option you can set to fast, but that's intended for games.
Try turning on receiver AV SYNC and setting the AE4000 to mode 1, see how that looks.
Bob Whitefield is offline
post #6517 of 8676 Old 02-09-2011, 02:46 PM
mjg100's Avatar
Originally Posted by StevenC56 View Post
I have an HVAC return in the ceiling at the center back of my HT. My 2 choices for ceiling mounting a projector are either just in front of the return or just behind it at the very back of the room. If I mount it behind is there a chance that the air pulling into the return would have an effect on the picture more that mounting it in front of the return? The projector will most likely be right at 2' down from the ceiling.
A return should not pose any problems.
mjg100 is offline
post #6518 of 8676 Old 02-09-2011, 03:10 PM
gtbuzzzz's Avatar
I've been looking to pick up an AE4000 but budget has kept me out of the game for a while. A number of times I've come across a New BUT damaged AE4000 up for sale. The most recent is a new PJ but has damage to the rear vent area in which a 4x5 chunk of the plastic has broken off. Add says - "This item does have some damage .... The box is also damaged. I plugged the item up and it did power on and the bulb did work, however we have not tested all its functions." Similar to others I've seen. My guess is some sort of shipping damage and insurance is taking care of the replacement costs. Would this be something to consider for 1/4 of the new price, or not even worth thinking about even if it was $50? And more general, if you take any projector and oops drop it....is it toast?
gtbuzzzz is offline
post #6519 of 8676 Old 02-09-2011, 03:21 PM
mjg100's Avatar
I would not buy it and yes if you drop a projector it is toast.
mjg100 is offline
post #6520 of 8676 Old 02-09-2011, 03:24 PM
JCAnderson's Avatar
Thanks Bob for the suggestions. I tried AV Sync to yes on the receiver and that didn't help. I had Frame Creation on the 4000 at Mode 1 and turned it off and that seems to have worked. I'll try other inputs, but I think you have solved my problem.
My wife was giving me a hard time about the 4000 being black and so much bigger than the 900, I didn't need a problem with the 4000.
I really wanted to keep the 4000 and my wife.
post #6521 of 8676 Old 02-09-2011, 10:46 PM
gadget-zilla's Avatar
Quoted: 21 Post(s)
do panasonic projectors suffer the fate of dust blobs as frequent as Espons do ?
gadget-zilla is offline
post #6522 of 8676 Old 02-09-2011, 11:01 PM
avswilier's Avatar
I find the black makes it less conspicuous in my living room. Just likewith clothing, black makes it look slimmer! That's one of the reasons I chose the 4000 over the Epson 8350 (white)
avswilier is offline
post #6523 of 8676 Old 02-10-2011, 01:27 AM
gamelover360's Avatar
Yes. But I have just cleaned mine using compressed air. Takes 30 mins. Really easy. All blobs gone. So now i feel confident that I can do it again if it becomes neccessary.
gamelover360 is offline
post #6524 of 8676 Old 02-10-2011, 08:27 AM
Quoted: 21 Post(s)
awesome !! thank you.
If perhaps, the next time you perform that cleaning, if you could post some pictures, that would be great. I'm always fearful of opening an electronic item. They are full of 'snap in' style cases and I end up breaking some
post #6525 of 8676 Old 02-15-2011, 07:41 AM
JamesN's Avatar
There is a tutorial posted here with an informative picture.
JamesN is offline
post #6526 of 8676 Old 02-15-2011, 08:02 AM
dzirkelb's Avatar
Quoted: 45 Post(s)
I noticed on a couple movies that the panning from side to side is a little choppy. There are numerous things that could cause this, but I'll start with the projector. Is there anyway to make the panning smoother so it isn't as choppy?
Basically, the projector is out of the box with no settings changed. I did turn on cinema smoothing or whatever it is called, and that seemed to help a bit.
dzirkelb is offline
post #6527 of 8676 Old 02-15-2011, 08:32 AM
Quoted: 13 Post(s)
Not sure what cinema smoothing is, but in the PICTURE menu, you should set FRAME CREATION to MODE1, and see if that helps.
Make sure FRAME RESPONSE in the OPTIONS menu is set to NORMAL.
You can also assign FRAME CREATION to the FUNCTION BUTTON if desired, makes it easy to compare the modes. I leave mine on MODE1, the higher modes can be inconsistent in effect, which I find distracting.
post #6528 of 8676 Old 02-15-2011, 08:35 AM
dzirkelb's Avatar
Quoted: 45 Post(s)
awesome, I'll check the settins soon, thanks!
dzirkelb is offline
post #6529 of 8676 Old 02-15-2011, 07:37 PM
deromax's Avatar
Quoted: 13 Post(s)
As it was said, the Frames Creation option is what you need to smooth this out.
But it should be noted that the choppy pans are normal and can be seen in real theaters as well. Film is 24 images per second, so it will be choppy when presented the right way. I think it's part of the experience.
It's like the natural film grain : it's normal and intended IMHO!
deromax is offline
post #6530 of 8676 Old 02-15-2011, 07:41 PM
dzirkelb's Avatar
Quoted: 45 Post(s)
I 100% agree, I have a 120hz lcd tv that I upgraded to a pioneer krp500m because I didn't like the smoothness, seemed to soap opera-ee.
There was one movie wher eit was really bad. They did a complete 360 of their viewing area, not fast either, and i couldn't really tell at all what they were looking at because it was so bad. But, in the rest of the movie it was all normal, so maybe just a bad scene.
dzirkelb is offline
post #6531 of 8676 Old 02-15-2011, 10:26 PM
Quoted: 21 Post(s)
are there any words about a new model of panasonic projector coming out anytime in the near future - a replacement for the current AE4000U which was released in 2009 ?
post #6532 of 8676 Old 02-15-2011, 10:47 PM
chadnliz's Avatar
While choppy motion pans in movies is pretty normal I doubt anyone says "we want it this way" when they make the film. Its probably just too expensive to justify improvement.
chadnliz is offline
post #6533 of 8676 Old 02-15-2011, 10:58 PM
RapalloAV's Avatar
Quoted: 1299 Post(s)
Liked: 292
http://www.screenscribe.tv/home-thea...jector-due-3q/
Murray Thompson
X Owner RapalloAV
Absolutly no connection with RapalloNZ
CinemascopE Home Cinema Build & 2014 rebuild
RapalloAV is online now
post #6534 of 8676 Old 02-16-2011, 07:32 AM
Mopar_Mudder's Avatar
Quoted: 25 Post(s)
Liked: 32
That is the way is was intended 50 years ago and no one has bothered to keep up with tech in the film industries it seems. No reason they can't be shooting digital at 120hz, oh well some day. It is like saying their is a hand crank in front of the car to start the engine and that is the way they are suppose to be, times change.
Personally I run my frame creation at 3 all the time and like it the best, I don't like choppy pans either.
Mopar_Mudder is offline
post #6535 of 8676 Old 02-16-2011, 10:07 AM
Quoted: 13 Post(s)
I'm all for frame rates higher than 24fps, and tried very hard to like frame creation modes 2 and 3 on the AE4000.
But in those modes FC often calls attention to itself. When it works, it looks great, with smooth motion. But then the next scene will be too complex for the algorithm, and reverts to essentially what you see in mode 1. The constant switching is what I found distracting. At least in mode 1 everything looks the same.
Maybe the AE5000 will have improvements in this area, if it has faster hardware and/or better algorithms.
post #6536 of 8676 Old 02-16-2011, 10:34 AM
tony123's Avatar
Liked: 38
My projector has developed a "Tannish / yellow" cloud in the bottom left portion of an image. It's only detectable with a white background. It seems to be growing and now takes up about 10% of the total image.
Any comments? I've done a search through the thread with no luck.
The "Twinseltown" Theater
Construction Thread
tony123 is offline
post #6537 of 8676 Old 02-16-2011, 10:50 AM
m. zillch's Avatar
Quoted: 1827 Post(s)
Liked: 1172
^ My guess: burnt polarizer. Most common cause is due to a power failure during operation which shuts down the cooling fans before they have time to cool the unit properly, which is why in normal operation shut down takes a minute or so and isn't instantaneous. Killing the power with the main toggle switch instead of the on/off push button or accidentally yanking the power cord would be two examples. Anyone operate the unit besides you?
In A/V reproduction accuracy, there IS no concept of "accounting for personal taste/preference". As art consumers we don't "pick" the level of bass, nor the tint/brightness of a scene's sky, any more than we pick the ending of a novel or Mona Lisa's type of smile. "High fidelity" means "high truthfulness", faithful to the original artist's intent: an unmodified, neutral, accurate copy of the original master, ideally being exact and with no discernable alterations, aka "transparency".
m. zillch is offline
post #6538 of 8676 Old 02-16-2011, 11:08 AM
tony123's Avatar
Liked: 38
Thanks Zillch. I've been the only operator. Over the last year, we have had maybe two power outages that could have done this. Doesn't sound like there would be an easy or inexpensive fix? Will a new bulb resolve this? I assume not.
Do you think the "cloud" might continue to grow?
Thanks again for your insight.
Construction Thread
tony123 is offline
post #6539 of 8676 Old 02-16-2011, 03:49 PM
luismanrara's Avatar
Quoted: 143 Post(s)
Liked: 97
Is your projector hanging upside down?
Do not steal, The powers that be do not like the competition.
luismanrara is online now
post #6540 of 8676 Old 02-16-2011, 04:56 PM
tony123's Avatar
Liked: 38
Yes it is.
Construction Thread
tony123 is offline
