Panasonic PT-AE4000 MSRP $1999 - Page 267 - AVS Forum | Home Theater Discussions And Reviews
 24Likes
post #7981 of 8676 Old 02-20-2012, 06:15 PM
taffman's Avatar
Originally Posted by forestmoonstudio View Post
. I love love love this projector!!!!
+1
taffman is offline
post #7982 of 8676 Old 02-21-2012, 04:35 AM
dgkp's Avatar
Originally Posted by frank1940 View Post
You need to get a Setup (or test) disk to set both Brightness and Contrast. You really can't do it by eyeball. By the way, Contrast controls the maximum white level and Brightness sets the black level. (As I recall, there used to be a primitive display setup utility on DVD's with THX certification. Not sure if they included that on THX certified Blu-ray's.)
Another item is that grayscale is actually the balancing red/blue/green so that the color of a 'white' screen is maintained from minimum brightness level (very dark gray to black) to maximum brightness and the color temperature is 6500K. That is a very, very difficult adjustment to make without professional calibration equipment.
This is calibrated using good old GetGray and the HD AVS disc. On both if I use the OTB settings then the calibration is clearly way, way off on contrast and brightness. To get my 1% or 2% whites or blacks just visible with no clipping I'm in the +20s for Contrast and the -20s for Brightness. I'm not complaining, once set up its fine. I'm just reporting a very different experience from some others.
dgkp is offline
post #7983 of 8676 Old 02-23-2012, 02:54 PM
cybrsage's Avatar
Liked: 154
I received my projector!
I am now happy. I will have to figure out the dimensions and tape off my area, then save projector zoom settings. Then paint.
cybrsage is offline
post #7984 of 8676 Old 02-24-2012, 08:37 AM
cybrsage's Avatar
Liked: 154
How do I send in both forms with one UPC? The rebate and the extended warranty? I want both!
I just sent a request to the Projector People, asking them how to handle it.
EDIT: The rebates say they cannot be combined with any other offer except for each other. I called the Rebate Center phone number on the rebate (which happens to be the same on both) and asked how to send them in, since both rebates need the original UPC. The woman who answered was both very nice and helpful...oh, and she is a native English speaker somewhere in the US. She said Panasonic has given them the OK to use a photocopy of the original UPC for the $250 rebate and the 2 year warranty, since they know it will be needed on one of them. She said to send them in two different envelopes as they go to two different departments at the center (one is not authorized to handle money, making it a cheaper center to staff).
cybrsage is offline
post #7985 of 8676 Old 02-24-2012, 10:36 AM
taffman's Avatar
You have to send in a form for the $250.00 rebate and a form for the warranty extension separately to two different Panasonic adresses. You will have to cut the UPC code off the box and send with one claim, and use the UPC label attached to the box for the other claim. PP can send you the claim forms if necessary, or you can download them as pdf files.
I got my $250.00 rebate last week, it took about 10 weeks.
What a deal, this projector is a steal at the current rebate price.
taffman is offline
post #7986 of 8676 Old 02-24-2012, 11:06 AM
sog35's Avatar
Liked: 27
i just got this projector. Projector people said i got the last one. For the price it was an awesome deal
sog35 is offline
post #7987 of 8676 Old 02-24-2012, 11:33 AM
cybrsage's Avatar
Liked: 154
My box only came with one UPC on it. It is a sticker stuck to the side of the box. It also came with a second sticker which only has the product number and the serial number on it (and also a very tiny third sticker with product and serial number on it - I stuck that in my manual).
Only one UPC found, though.
cybrsage is offline
post #7988 of 8676 Old 02-24-2012, 11:35 AM
cybrsage's Avatar
Liked: 154
And it appears you did! The 4000 no longer appears on their site for sale.
cybrsage is offline
post #7989 of 8676 Old 02-24-2012, 05:06 PM
sivartk's Avatar
Mine was the same way. I sent the original UPC with the $250 rebate and photocopy with the warranty extension with a note on the photocopy mentioning I sent the original with the $250 rebate. If they screw up one, I would want it to be the warranty (I've had good luck with all my Panasonic products, including the "boom box" from the 1980's which is still working out in the garage )
At no point in your rambling, incoherent post were you even close to anything that could be considered a rational thought. Everyone in this forum is now dumber for having read it.
My Little Theater
sivartk is offline
post #7990 of 8676 Old 02-25-2012, 08:45 AM
crunchyfrogs's Avatar
I called them as well and was told originals with the rebate, copies with the warranty fwiw.
crunchyfrogs is offline
post #7991 of 8676 Old 02-25-2012, 08:56 AM
mcfingrs's Avatar
...I got my $250.00 rebate last week, it took about 10 weeks.
That's good to know. The form claims 6-8 weeks, and I set a reminder at 8 weeks. Maybe I'll hold out a couple more before following up.
mcfingrs is offline
post #7992 of 8676 Old 02-25-2012, 01:57 PM
taffman's Avatar
Does that mean that the AE4000 is no longer being made? If so, I do not think that Panasonic have really a replacement for it. The AR100, by all accounts is a media room projector and is too bright and has poor contrast for a dark HT room projector. The AE5000 is 3D and about $1000.00 more expensive than the original MSRP for the AE4000, so as I see it Panasonic really has nothing in their catalog to replace the AE4000.
taffman is offline
post #7993 of 8676 Old 02-25-2012, 04:04 PM
CochiseGuy's Avatar
Yes, the AE4000 is discontinued. There is no AE5000, Panasonic skipped a couple model numbers. The AE7000 is the current top of the line model with 3D, and yeah, the MSRP is $2,999. The AR1000 is a decent home theater projector, but it is more a replacement for the AX200, which was only 720p (the AR100 is 1080p). The AR100 has 2800 lumens and 50,000:1 contrast, which is decent. There's probably a few places with some stock of the AE4000 is you scour the web hard enough. Actually, I just did a Goggle shopping search and Amazon has some from 3rd party sellers starting at $2320.
I've had mine for 2 years last December and love it, it's a keeper. I have 2 projectors. I started with a AX200 to see how I'd like projection HT, and loved it so I bought the AE4000. Rather than sell the AX200 for half of what I paid for I kept it and used it for TV sports & DVD and reserved the 4k for only Blu-ray, to keep the hours down. It worked, I have only 1260 hours after 26 months. But I recently saw the deal for the Epson 8100 1080p pj closeout at $749, marked at "refurb" but comes with 2 yr. warranty on pj & bulb, so I upgraded to that and eBayed the AX200 for $450, so the upgrade only cost me $300. The AX4000 will be around my house for a long time. The PQ is outstanding, and I love the auto load memory - I prefer 2.35:1 movies lowered down to the bottom of my 16:9 screen so there's just one wide bar at the top and the movie is more at eye level, and the 4k does this automatically for me.
CochiseGuy is offline
post #7994 of 8676 Old 02-26-2012, 07:11 AM
Mr.G's Avatar
Quoted: 603 Post(s)
Liked: 308
You obviously have never seen one in action, both of your statements are false.
All I Really Need to Know I Learned in Kindergarten Movies
Mr.G is offline
post #7995 of 8676 Old 02-26-2012, 08:08 AM
taffman's Avatar
Just going by the Projector Central review for the AR100. In fact I was definately in the market for the AR100, until I read that review, which convinced me to get the AE4000 instead.
taffman is offline
post #7996 of 8676 Old 02-26-2012, 06:10 PM
sog35's Avatar
Liked: 27
Kinda sucks that you have to pay close to $1k just to have 3d (price difference between 4000 vs 7000). I'm just glad I got the 4000 before they are all gone. They have some at Amazon, but I'm not sure if they are authorized dealers thus no warranty
sog35 is offline
post #7997 of 8676 Old 02-27-2012, 08:17 AM
neverfaithful's Avatar
I have had my 4000 for 2 years now and I am on my second blub with 1150 hours on it. I could not be any happier with it. I had to clean the lenses inside from dust blobs one time and never had any since. Love this projector.
neverfaithful is offline
post #7998 of 8676 Old 02-28-2012, 08:59 AM
Viche's Avatar
Quoted: 424 Post(s)
Liked: 105
Yeah, I agree. I think they screwed up, or maybe they don't mind sacrificing sales in the near term in order to keep up with the Joneses, and hope to sell more later when 3D really takes off (sarcasm intended). The movie studios are doing the same thing. From the money people's perspective they are saying "if you have the opportunity to increase the cost of the product that you are selling, then you would be stupid not to." This is pretty much a direct quote from a financial manager friend of mine who works for Disney. Somehow the green has caused them to lose site of the fact that people might NOT WANT THEIR LAME 3D TECHNOLOGY. Movie theater attendance is on a sharp decline. In this economy, people are saying that they can no longer afford going to the movies, and they don't want to pay extra for 3D. Some people are actually coming to their senses and realizing that the 2D experience is ACTUALLY BETTER than its 3D counterpart. I've pretty much signed Panasonic off for this round. I want a true update to the 4000 or I am going to wait for another company to fill the gap in the $2000 price range, or for 3D projectors to come down in price (maybe close out pricing on the 7000). Then the question becomes, do these newer projectors have more lag in gaming?
Viche is offline
post #7999 of 8676 Old 02-28-2012, 06:38 PM
taffman's Avatar
I was hoping that the AR100 would be the same projector as the AE7000 - minus the 3D capability. Obviously it is not, even though it has the same chassis. So, if anyone from Panasonic is listening, that is the projector you need to bring out in the $2000.00 MSRP market.
taffman is offline
post #8000 of 8676 Old 02-29-2012, 09:17 AM
Viche's Avatar
Quoted: 424 Post(s)
Liked: 105
Yep. That would sell like hot cakes. I'd buy one tomorrow....well as long as the lag wasn't too bad. In their minds though, they would be sacrificing $1000 of potential revenue. So instead, I'll by someone else's projector. Lame.
Viche is offline
post #8001 of 8676 Old 02-29-2012, 06:24 PM
sog35's Avatar
Liked: 27
How do you adjust vertical/horizontal lense shift digitally with the remote? I can't find anything in the manual that tells me how.
sog35 is offline
post #8002 of 8676 Old 02-29-2012, 07:35 PM
deromax's Avatar
Quoted: 13 Post(s)
You don't! You have to use the actual knobs on the projector itself.
deromax is offline
post #8003 of 8676 Old 03-03-2012, 10:27 PM
sog35's Avatar
Liked: 27
Does anyone have a link to the $250 rebate form and 1 extra year warranty? I can't find it anywhere on the net.
sog35 is offline
post #8004 of 8676 Old 03-04-2012, 07:49 AM
cybrsage's Avatar
Liked: 154
cybrsage is offline
post #8005 of 8676 Old 03-04-2012, 08:26 AM
sog35's Avatar
Liked: 27
Here is the one for the $250:
http://www.panasonic.com/business/pr...FormAE4000.pdf
The warranty extension is here:
http://www.bhphotovideo.com/FrameWor..._PT-AE4000.pdf
Thanks! you are a lifesaver!
sog35 is offline
post #8006 of 8676 Old 03-05-2012, 01:51 PM
Got my rebate back on Friday, took about 3-4 weeks.
post #8007 of 8676 Old 03-09-2012, 05:01 PM
Sodbuster's Avatar
Anyone have discrete IR codes for the inputs to the PJ? Mostly I use one of the HDMIs, but would like to be able to program my remote to go right to the desired input instead of cycling through the selections.
Bill Bunker
Sodbuster is offline
post #8008 of 8676 Old 03-10-2012, 07:03 AM
Mopar_Mudder's Avatar
Quoted: 25 Post(s)
Liked: 32
Check this thread, only way to do discrete codes I believe. It is what I use and never use IR codes any more.
http://www.avsforum.com/avs-vb/showthread.php?t=1206105
Mopar_Mudder is offline
post #8009 of 8676 Old 03-10-2012, 08:04 AM
frank1940's Avatar
AMEN!!!! This is the only way to get direct jumps to the proper input. My IR-to-RS232 setup is completely reliable and foolproof. The projector never been on the wrong input in the two plus years since the IR unit was installed. Discrete RS232 codes exist for most menu selections that you would normally use for viewing.
frank1940 is offline
post #8010 of 8676 Old 03-10-2012, 10:29 AM
Sodbuster's Avatar
Thanks, I reviewed that thread and found it most interesting. I am strongly committed to IR for nearly everything, and just recently added a Global Cache WF2IR device so commands can be sent over the LAN via my iPad (or iPhone) and translated to IR. GC has another gizmo which will convert commands to serial format, and that would be easy to install...but it costs $88, too steep for just using it with the PJ. It could also control my BR player if desired, but not my AVP which is an older model.
This is about fine-tuning control, since 99% of the time I use only a single HDMI input on the PJ and switch inputs on the AVP. The only reason to shift the PJ input is to play legacy VHS tapes via S-video. The projector is 40 feet from the other components, but since the GC device works over the LAN it could be placed near the projector thereby avoiding any long cable runs (the HDMI cable was added long after the room was constructed when everything was component, and had to be run on the surface).
So I will likely keep things the way they are, but it's good to learn there is a solution.
Bill Bunker
