Panasonic PT-AE4000 MSRP $1999 - Page 54 - AVS Forum | Home Theater Discussions And Reviews
 24Likes
post #1591 of 8676 Old 11-13-2009, 10:47 AM
jeepster360's Avatar
Originally Posted by jsm88 View Post
That doesn't make any sense, clearly if you are at the max of either lens shift or zoom then you might have a problem, but the 2.35 picture is just a zoom of the 16:9 picture - if you can place that below the lens without keystone, which you can, then you can place the zoomed 2.35 image there - assuming you have the zoom to work with.
Let me try to explain this................When you are shifting the lens with the manual wheels you are moving the whole lens to make the shift. you can shift the image a long ways above or below the lens.
the reason the lens has to be with in the screen with the 2.35 feature is because the lens itself is not moved at all(except to focus). the image is electronicly shifted up to the top of the screen & zoomed out to make it wider, filling the screen. the lens can't be higher than the screen because
there isn't enough electronic vertical movement to keep on the panel to compensate for the angle of the internal light path with out cutting it off at the screen.
If thee whole lens was shifted to make the feature work then you could get away with the lens being higher than the screen.
thats may take anyways.
john
jeepster360 is offline
post #1592 of 8676 Old 11-13-2009, 11:34 AM
Charles R's Avatar
Liked: 536
Originally Posted by Ed Snape View Post
What you reported earlier is what I had expected. Everything off this 4k is soft. Tech support at Projector People said it was because of Pany's anti screen door technology. Not sure I buy that. Furthermore, he refused to point me to any kind of resolution test BD.
Resolution and sharpness are two completely different things. As an example you can compare a focussed image to a non-focussed image (up to a certain degree) and they will contain the exact same amount of detail (resolution).
The sharpness or softness of the image will be determined by contrast level, visible pixel outline and how good the lens and panels' alignment are along with a number of other items including Panasonic's Smooth Screen. My guess is any variations between the same model would mostly be the result of panel alignment differences.
A long time ago I compared the PT-AE2000U to the at the time current Epson model and on the surface the Epson looked dramatically sharper. However both had the same amount of detail it was just the screen door affect giving the Epson a perceived sharpness (that some prefer and other's don't).
| 120" Screen | 1080p Projector | 7.2.4 Boston Acoustics & Power Sound Audio | Yamaha RX-A3060 & AudioSource AMP110 | Philips BDP7501 | LibreELEC/ODROID-C2 Media Client | Ubuntu/ODROID-XU4 Server via Kodi/Plex Media Server : LG 65EG9600 OLED TV | TiVo | Premiere+ | Blu-ray Movies for Sale | Digital HD Codes for Sale |
Charles R is offline
post #1593 of 8676 Old 11-13-2009, 11:54 AM
allroadCole's Avatar
Originally Posted by naturr View Post
This is the mount I am using. Looks great in fact looks expensive. Lots of adjustability and you can hide your wires down the centre shaft.
Price is great even with shipping. Their cables are terrific also I use them all the time with clients for networking and grabbed a 45 foot HDMI cable for the projector that works great.
That mount looks nice, can you adjust the length of the shaft? If so, what are the min and max drops from the ceiling to the center of the lens (roughly)?
TIA!
allroadCole is offline
post #1594 of 8676 Old 11-13-2009, 12:04 PM
Smarty-pants's Avatar
Quoted: 747 Post(s)
Liked: 621
TIA!
I have that mount without the extra shaft extention.
I bought it a couple years ago for my Epson pj, but I ended up having to buy 2 to get enough parts to stretch the spider brackets out far enough to the holes.
The mount is solid, but you get what you pay for.
More expensive mounts are a lot easier to work with, while this mount comes in pieces, needs assembled, and takes lots of tweaking to get it right. All the adjustments and screws take allen wrenches to adjust (which they provide), but not as easy as the better mounts that have nice turn dials and built in leveling and all that.
If you want easy, buy one for $100.
If you don't mind taking the extra time it takes to tweak this one till it's right, then it's a money saver.
Again though, for my Epson I had to buy 2 to get more parts to reach the mounting holes on the pj.
Don't know if it would be the same for the 3000/4000.
BTW, that's what SHE said...
Smarty-pants is offline
post #1595 of 8676 Old 11-13-2009, 12:57 PM
501transpo's Avatar
More Mounting systems:
I recycled my Chief RPA system and added the PT-AE4000U plate (SLB181). The mount has the optional lateral shift rails (LSB100) and the Panamorph bracket. With the relative light weight of the 4K. I used PVC plumbing parts, much easier to work with than 1 1/2 inch threaded steel pipe, for the ceiling mount.
Steve
501transpo is offline
post #1596 of 8676 Old 11-13-2009, 02:09 PM
Bronco70's Avatar
Steve
Nice pics.
Where did you purchase the SLB-181? I also have the RPA mount.
As an alternative it looks like it might be fairly easy to buy a piece of plexiglass and make an interface bracket.
Joe
Bronco70 is offline
post #1597 of 8676 Old 11-13-2009, 02:14 PM
CCONKLIN1's Avatar
Oh MY! Just hooked up this bad boy to my bedroom system! Holy CRAP! Had UP in the blu ray player, did a few quick and dirty tweeks and next thing I know I have lost an hour watching it! This is on a 72" Carada grey screen and it is spectacular! I plan on taking it down to the basement theater tomorrow to compare/contrast with my Pioneer RS2 clone.
CCONKLIN1 is offline
post #1598 of 8676 Old 11-13-2009, 02:24 PM
ferbal's Avatar
Originally Posted by CCONKLIN1 View Post
...I plan on taking it down to the basement theater tomorrow to compare/contrast with my Pioneer RS2 clone.
CCONKLIN1
I'm interested! Please post your observations.
ferbal is online now
post #1599 of 8676 Old 11-13-2009, 02:40 PM
501transpo's Avatar
Originally Posted by Bronco70 View Post
Nice pics.
Joe
I ordered it with the AE4k from PP but Google Chief mounts and there are other retailers listed. If you already have the RPA, I would add the lateral rails they are "cheap" ~$38.00 and the SLB181 (not cheap ~$136.00). The Chief mounting system is very secure and easy to mount the PJ. Why risk a $2k PJ with a DYI..if you looks at the Pics, you can see the multiple fixation points. With the PRA and "rails" you have control over R & L, Pitch and Yaw.
Using PVC for the ceiling drop, it is relatively easy to adjust the vertical...I lowered mine an additional 7" after the initial install.
post #1600 of 8676 Old 11-13-2009, 02:48 PM
caesar1's Avatar
Originally Posted by johnstewart View Post
Sure you can; you just need to manually turn the dial for the vertical shifting required when you go between 16:9 and 2.4:1. The electronically-controlled (thus, "automatic" capable) shifting doesn't move far enough.
If it ain't automatic it ain't worth doing. It should be clear that it can't be automatic unless the lens is within the screen frame? Or is it at the screen frame?
caesar1 is offline
post #1601 of 8676 Old 11-13-2009, 02:55 PM
501transpo's Avatar
Another thought, if you want to run the cables above the ceiling, use the 3" PVC pipe for the majority of the "pole" and then cut a 1-1 1/2" hole a run cables up the 3" pipe.
Steve
post #1602 of 8676 Old 11-13-2009, 03:17 PM
JayMan007's Avatar
Originally Posted by RapalloAV View Post
Some of my favorite things....
5. The thing that's got me really excited which probably most wouldn't even use are the 4 masking features, this is maybe too involved to go into here but I'm using this feature and for my setup it really makes a very professional presentation. There are other posts I have already made here in other threads about the digital masking feature.
Started reading this thread yesterday, and just came across your post..
Maybe you could post some picture of this, and how it looks.
I'd recommend with enough light to see what is being masked.
JayMan007 is offline
post #1603 of 8676 Old 11-13-2009, 04:02 PM
Bronco70's Avatar
Thanks for the reply.
The RPA is an excellent mount. I've been using one for 4 years with a BenQ 7700. The ease of taking the pj down has been a plus with sending the 7700 in for repair x4.
Not sure the rails are really necessary with the lens shift on the 4000.
Looks like the SLB-181 is available for just under $100. Noticed it uses all six mounting points. No doubt very secure.
Joe
Bronco70 is offline
post #1604 of 8676 Old 11-13-2009, 04:30 PM
MassGT's Avatar
I pulled the trigger on my early xmas present. I have the AE4K coming next week. My question is I use to have a yamaha LP510 720i that I paid good bucks for 4 years ago. How much of a difference will I see in the new Panny? The yamaha crapped out about a year ago so I'm all excited to get my room back running.
MassGT is offline
post #1605 of 8676 Old 11-13-2009, 04:56 PM
501transpo's Avatar
Probably not but they were useful with my old HT-1000. But you are right about the 6 point mount and the ease install and remove.
Steve
post #1606 of 8676 Old 11-13-2009, 09:55 PM
dynamowhum's Avatar
Just ordered mine. This will be my first projector. Can't wait for it to come in.
The only difference between outlaws and inlaws is one of them is wanted.
dynamowhum is offline
post #1607 of 8676 Old 11-14-2009, 01:59 AM
Beta Tester's Avatar
While I am pleased with the brightness, contrast, and color rendering of our new 4k, there does not seem to be the sharpness of the retired PT a900, as unlikely as this seems.
I am surprised to hear this. I consider the picture of an AE900 to be soft.
Beta Tester is offline
post #1608 of 8676 Old 11-14-2009, 05:50 AM
CCONKLIN1's Avatar
I had a direct comparison to the ae 700 and this one. I was happy with the picture of the 700 but in a side by side comparison, it is a different story! 700 was fine as long as I did not watch the 4000! The 4000 on my 72" grey carada screen is razor sharp. I CAN see pixels if I get close enough to the screen. The 700 was "mushy" compared to the 4000. Now, I know I am going to get crap for this, but I love "frame creation setting 1"!!! 2 and 3 seem funky to me, but I love what #1 does! Next up this afternoon is bringing this bad boy to my basement to compare with my pioneer rs2 clone. I plan on watching a lot of action and fast moving stuff. I have a feeling I am about to experience the dreaded "motion blur" on my pio, even though I previously have been real happy with it.
Sigh...somedays I really hate and love this hobby equally..
Best,
Chris
post #1609 of 8676 Old 11-14-2009, 06:20 AM
scottyb's Avatar
Quoted: 18 Post(s)
Best,
Chris
hey chris,
Will you be posting results here?
This unit is high on my list.
Scott
scottyb is offline
post #1610 of 8676 Old 11-14-2009, 07:05 AM
CCONKLIN1's Avatar
yeah, i will post my observations here. I sure as hell wish there was only one thread on this thing! I am getting confused between the two! Probably because I am old and my mind does not work as well as it used to...
Best,
Chris
post #1611 of 8676 Old 11-14-2009, 07:27 AM
afcooper's Avatar
Could someone point me to the other AE4000 thread? I have looked for it with no success.
afcooper is offline
post #1612 of 8676 Old 11-14-2009, 09:38 AM
frank1940's Avatar
Look in the Projectors OVER $3000 forum
frank1940 is offline
post #1613 of 8676 Old 11-14-2009, 10:20 AM
DPWN's Avatar
I replaced a Yamaha LPX-510 720p projector with the PT-AE4000U. While I am pleased with the Panasonic I found the picture was not as bright (using a Da-lite HP 120" 16:9 screen), the blacks were very much improved, sharpness and detail were not dramatically improved and the color accuracy needed a lot of tweaking in modes other than Cinema 1. The 24 frame interpolation modes have really helped to get rid of the judder that was sometimes very annoying on fast panned scenes on the Yamaha. The Panasonic is definitely a little quieter running than the Yamaha (both in Eco-mode).
I will be keeping the Yamaha as a spare in case the Panasonic should suffer from one of the problems seen by other members.
DPWN is offline
post #1614 of 8676 Old 11-14-2009, 10:36 AM
AugDog's Avatar
Can someone tell me what the expanded HDMI setting does? Seems to kill the black level for one, but sure what the difference or purpose is.
AugDog is offline
post #1615 of 8676 Old 11-14-2009, 10:39 AM
VirTERM's Avatar
Quoted: 37 Post(s)
standard: 16-235 => normal movie mode
extended: 0-255 => PC etc...
Wojtek
VirTERM is offline
post #1616 of 8676 Old 11-14-2009, 10:42 AM
AugDog's Avatar
Wojtek
Thanks. What do the numbers represent? Would extended be used for game systems as well?
AugDog is offline
post #1617 of 8676 Old 11-14-2009, 11:12 AM
rprice54's Avatar
Quoted: 92 Post(s)
Liked: 45
Pardon my ignorance, but I seem to be getting conflicting information. I just want to mount my PJ as close to the ceiling as I can my screen will be about 12" from the ceiling, and from what I read about the lens shift, this shouldn't be a problem.
If I get the Chief RPA-U mount (say from Amazon) do I need anything else? What about plates and rails? Does the mount itself not come with everything I need?
rprice54 is offline
post #1618 of 8676 Old 11-14-2009, 12:05 PM
Bigbluedude's Avatar
I am ready to hook up my screen etc. to the Panny trigger out/in plug and not sure what jack is used for the trigger. Looks like mini banana? Is that correct? Thanks
Bigbluedude is offline
post #1619 of 8676 Old 11-14-2009, 01:03 PM
501transpo's Avatar
I am not an expert, but the RPA-U doesn't need an adapter plate and with the horz. lens shift, lateral rails aren't needed either. What you will need is the hardware to mount to the ceiling studs, trusses etc. Google Chief mounts and go to a site that has pdf downloads for mounting procedures or call a Chief retailer and discuss what you will need.
Steve
post #1620 of 8676 Old 11-14-2009, 01:04 PM
Sunil's Avatar
You will have no problem just projecting to a screen below the Projector. But if you want to use a 2.35:1 screen and zoom 2.35 material to fill the screen and zoom out to view 16:9 material (you can use the lens memory feature to do it at the press of a button or even have the AE4000 do it automatically), you will need the lens to be within the screen area. You can still do it if that is not the case but you will have to either:
a. Get up and go to the projector and use the lens shift dials every time you switch aspect ratios.
or b. Slant the PJ down, but you will get keystone distortion and will have to use keystone adjustment to fix it.
Sunil is offline
