Official Epson Home Cinema 8500UB thread! - Page 15 - AVS Forum | Home Theater Discussions And Reviews
 6Likes
post #421 of 460 Old 07-19-2014, 08:03 AM
Liked: 0
Hi all. I have an EPSON 8500 that I bought new in April 2010. Well the lamp is finally going out. I got about 1300 hours out of it. And I had been away on business for the past year and a half so it had just been sitting there. I think a combination of both did the bulb in. So I was looking into getting a replacement. When I talked to my local HT guy he said that I also need to get the projector Serviced. That seemed reasonable since when I took it down from it's shelf there was a lot of dust in the filter and on the unit it self. But the guy wanted $150 to service the projector and install a new bulb (the price of the bulb was separate of course).
The question I have is what exactly does the technician do when they perform a "Projector Service" and is it something that I could do myself?
Thanks all.
Mark.Leiter is online now
post #422 of 460 Old 07-19-2014, 08:31 AM
ben38's Avatar
Quoted: 331 Post(s)
Liked: 169
Thanks all.
Respectfully request of your HT guy exactly what kind of service he's providing to you for 150 dollars. If the answer is "Clean or replace your filter and change your bulb," I would respectfully decline as these are things you can quite easily do yourself. If he's certified to professionally calibrate, and he's including a quick recalibration of your projector with the new bulb installed, the extra money might be worth it.
ben38 is offline
post #423 of 460 Old 07-19-2014, 05:10 PM
Liked: 0
Thanks for the reply. I think I can handle that myself.
post #424 of 460 Old 07-22-2014, 01:09 PM
cheld's Avatar
Originally Posted by Jeremy Anderson View Post
If you ever need a replacement fan for your 8500UB, I highly recommend scandig as a seller on eBay. He worked with me to figure out which fan I needed, assured me that these are the original OEM parts and provided a PDF of the exploded view of the 8500UB so I could see where each fan was and pick the right one. Very helpful!
Is this publicly available or could you post it somewhere? Thanks!
cheld is offline
post #425 of 460 Old 07-23-2014, 04:53 AM
Jeremy Anderson's Avatar
Quoted: 354 Post(s)
Liked: 661
PM me an address and I can e-mail it to you. It's just an exploded view that shows the location of everything in the projector. I had no clue the thing has 4 fans!
"Never believe any quote you read on the internet." - Abraham Lincoln
Jeremy Anderson is online now
post #426 of 460 Old 08-17-2014, 05:01 PM
kpdowd's Avatar
Any luck with 3rd party replacement Lamps
Has anyone had any luck with 3rd party replacement lamps for the 8500UB? Any input is appreciated.
Cheers
kpdowd is offline
post #427 of 460 Old 12-15-2014, 02:03 PM
BillZ's Avatar
Originally Posted by Curamrda View Post
does anybody know what can cause this color issue? seller is telling me that only hdmi connector has to be replaced...
What happens if you connect a component source to it instead
My nephew has HDADD. High Definition Attention Deficit Disorder. He can barely pay attention, but when he does, it's unbelievably clear!
Steven Wright
BillZ is offline
post #428 of 460 Old 01-20-2015, 06:41 AM
Necrozoupa's Avatar
Liked: 0
red light club.
Waw, this topic still exists.
I just red the thing about the red flashing light club. I hope i'm still out of it but....i have some troubles with it.
First, my projector is the européan version called EH-TW4400 (don't know if it make any kind of difference).
Purchased a new lamp (généric structure, original bulb).
First replacement so far, first lamp lasted 2000h approx (small explosion, no glass shattered, cleaned it to be sure)
Cleaned dust, air filter, replaced lamp.
Nice picture. It's cool. After 25h, lamp stops, projector fan(s) turned to max for 30 sec, then turns off. Red blinking led (of sadness) at the lamp sign.
Thought it was the heat or something so i let it cool down 24h unplugged.
Turned it on, 30 seconds of light, goes of and the evil red dot cycle gets back.
After 3 tries = same failure.
Getting a new lamp soon.
My projector is about 4 years old. Never had a problem until replacing the lamp.
Any clues ? Am i part of the blinking hellred club ?
Please no...
Thanks, really appreciated and sorry for the mistakes.
Necrozoupa is offline
post #429 of 460 Old 01-21-2015, 05:55 PM
taskman's Avatar
Quoted: 17 Post(s)
Yeah, this thread is still alive. 8500UB owners are a stubborn crowd. We love nothing more than to shove $150 bulbs into our beast of a projector.
I'm frankly shocked you made it to 2000H on one bulb, congrats. I don't know of anyone that has achieved that with an 8500UB.
Based on your description, I would say it is likely a bad bulb at the 25H mark. Just wait for that replacement bulb and hope for the best. Let us know how it goes and we can try to help.
Necrozoupa likes this.
taskman is offline
post #430 of 460 Old 01-21-2015, 07:19 PM
Liked: 1
A good buld or a bad buld, I can tell it just from the price. But it's reasonnable and feasible according to your post.
Eauspring is offline
post #431 of 460 Old 01-23-2015, 01:46 PM
kpdowd's Avatar
Well, I am done with Epson now.....Bought an 8500ub in 2010.....Got the purple horizontal stripe at the bottom of the screen in early 2011....they swapped it out no problem....Late in 2011, same issue and they swapped it again... Now on the 3rd 8500UB and it ate through 2 lamps in a hurry and now shows the purple stripe again....Epson said they were sorry
So, we will live with the purple stripe until this bulb dies then move away from the Epson platform....so sad since the price point the the picture were great when they were correct....
kpdowd is offline
post #432 of 460 Old 01-24-2015, 07:07 AM
Necrozoupa's Avatar
Liked: 0
Well, first of all, thanks a lot for the answer and the kinf help
Yeah, i was surprised myself with the bulb. Actually i bought it to a guy who was in touch with Epson guys (he works for a famous french magazine about HC called "les années laser" or he used to) so he got a fully tested and official bulb. Although i've been using only eco mode.
I have to say, starting from 1400, the bulb clearly had a drop of light and making a decent calibration was nearly impossible.
I guess it's a bad bulb, They will send me a new one shortly.
The bulb is original but structure is généric. It's approx 170€ (190$)
Not the cheapest (cheaper than fully official) on the market but original lamp inside seems reliable.
I'll post back my feeling about the new one when it's all set up.
See ya soon
post #433 of 460 Old 02-02-2015, 10:50 AM
Necrozoupa's Avatar
Liked: 0
Hi,
Received new bulb, testing it.
Seems to work so far. So the problem seems to have come from bulb.
Let you know when it crashes
Thanks guys,
See ya soon
post #434 of 460 Old 02-06-2015, 04:19 PM
Quoted: 354 Post(s)
Liked: 661
It's always funny to me when I see people surprised that a bulb lasted 2,000 hours. I'm on my 5th or 6th bulb (I can't recall which) on my 8500UB and every single one has lasted beyond that. My last two bulbs were pulled at just under 3,000 hours just to be on the safe side (because the one bulb I had explode on me was at 3,230 hours at the time). This last one was at 2,930 and when I swapped a new bulb in, it didn't seem particularly brighter... so they're holding up quite nicely for me. I run it in Eco with high altitude enabled.
post #435 of 460 Old 02-06-2015, 04:23 PM
Quoted: 354 Post(s)
Liked: 661
If you look around, getting rid of that purple stripe issue is a fairly simple thing. If I recall correctly, it comes from one of the polarizers shifting up out of position. The solution is basically to open the projector, take off the main circuit board, remove the top of the LCD engine, then push the polarizer back into place until it clicks. If you do some judicious searching, there's a site that shows you how to do it with a similar model (but I don't think I saved the link).
post #436 of 460 Old 02-08-2015, 02:33 PM
Liked: 0
glad to have found this thread.
bought mine used about 2.5 years ago. super pleased with the quality. went through the bulb it came with, and replaced after reading these liked to chew them up much quicker than advertised.
the replacement bulb has about 1k hours on it and worked fine last night. this am, i tried to fire it up and the Epson logo appears, and there's light inside the enclosure, but the aperture seems reduces and the unit is locked up. no image on the screen. no response from the remote, have to hard power it down to get it to shut down. fan was working fine. no funny smells.
i'm inclined to think its the bulb but want to check in before buying one.
thoughts?
assuming you agree, who's the current best seller for an authentic Epson bulb?
Cheers
ymi5150? is offline
post #437 of 460 Old 02-09-2015, 11:57 AM
Liked: 0
thoughts?
Cheers
Contacted Epson - they suspect the main board. ugh...
ymi5150? is offline
post #438 of 460 Old 03-27-2015, 06:18 PM
Diezzler's Avatar
Does anyone have the service manual for the 8500 anymore? I don't have enough post to PM anybody.
I believe my PLC lens has a crack in it, and was hoping there is a product number to replace it, rather than buy the whole optics unit. Thanks!
Cliff
Diezzler is offline
post #439 of 460 Old 06-02-2015, 08:34 AM
tiderfish's Avatar
Epson 8500 Shutdown and Red Light
Greetings,
I have the Epson H337A (8500). It has started powering itself off. Symptoms are as follows:
Power the unit on, it warms up and an image is displayed on the screen. All good.
After between 15 and 25 minutes, the image shuts off, and the unit has the LAMP LED flash. Even with an external fan blowing on the unit's underside.
The previous owner replaced the bulb twice, but didn't fix this issue.
I left it sitting with the red LED flashing for 2 hours. When I returned to it, the fan was not running, however the top left of the unit was very warm, opposite of the bulb assembly, but near the lense. Basically the left half of the top of the unit when the power and source connections are closest to you.
I was hoping to find an exploded view and maybe a teardown of the unit. However I haven't found anything. I tried PMing Jeremy A. but I don't have enough posts to send a PM yet.
Thanks in advance!
Matt|ttaM
tiderfish is offline
post #440 of 460 Old 06-02-2015, 08:36 AM
tiderfish's Avatar
Can you PM me the exploded view? or post it to this thread? I am too noobish to PM you, and I dont' want to spam around just to increase my post count. Thanks!
Matt|ttaM
post #441 of 460 Old 06-07-2015, 10:30 PM
Avax's Avatar
Cheers
I bought my 8500ub when they first came out. The first bulb lasted 900 hours. I was sent a new bulb under warranty. It lasted 1800 or so. My next 2 bulbs were OEM purchased from B&H. They cost about 270 bucks. They lasted 800 and 400 hours.
I then thought what the hell try a cheap ebay bulb for $60. If it lasted 400 hours i'd be ahead of thhe game. My first china cheapy lasted 1950 hours.
My second I replaced before it died at 1500 to regain brightness.
The replacement died at 550 hours but it was tied to a power outage event. Projector was running great prior to the power outage and was dead after the power came back on.
I took the 1500 hour China cheapy from the closet and replaced the power surge bulb and ran it another couple hundred hours before I replaced it with a new one. It was still going.
Just ordered a new bulb from the same folKS yesterday for 30 bucks. Price keeps dropping over time. Just looked, and my current bulb which still looks pretty decent is at 1433 hours.
Just to be fare the china bulbs are a couple hundred lums dimmer than the oem ones. So i don't run at THX cklor mode, but the 30 dollar brick point is well worth it. Not sure all china cheapys are the same but I have had good luck.
Jay
soundnuts likes this.
Avax is offline
post #442 of 460 Old 06-10-2015, 08:43 PM
taskman's Avatar
Quoted: 17 Post(s)
Matt|ttaM
I don't have an exploded view of the Epson 8500 but you likely have a dead bulb. Red flashing is typically a bad bulb. You can check my post here on how to escalate with Epson Support to get a bulb: Epson 8100 - replaced bulb and now Pink / Blue bands
taskman is offline
post #443 of 460 Old 06-22-2015, 08:32 PM
FFWD's Avatar
My 8500 UB developed the pink line at the bottom of the screen about 7 or 8 months after replacing my lamp with an OEM bulb in an aftermarket housing. Thinking it was caused by the lamp, and being just past the warranty period, I figured I'd just live with it until the next lamp replacement. Then while searching for recommendations on replacement lamps, I found a thread on this site with the fix. I only have 4 posts so far, so I will post the link in my next post...
FFWD is offline
post #444 of 460 Old 06-22-2015, 08:33 PM
FFWD's Avatar
Fix for pink/purple line
Here is the thread on this site with the fix for this issue for a number of Epson models, with 8500-specific pictures and info at post 29:
FFWD is offline
post #445 of 460 Old 07-12-2015, 08:50 AM
jtsilence's Avatar
I Upgraded my 6 year old Epson Powerlite Home Cinema 720 to a refurbished 8500ub.
The difference in black levels and PQ is amazing. I love it.
Hopefully I get the same WOW in about 5 years when I can get a cheap 4k projector.
James T. Silence
EPSON 720
Atlantic Technology System 350
jtsilence is offline
post #446 of 460 Old 07-14-2015, 10:12 AM
kpdowd's Avatar
So, I finally got out the screwdriver and started playing with my 8500.... Other than unseating a few items (that I was able to re-seat), I was able to get to the diffuser, click it back into place and presto, the purple line is gone! Thanks for the tip! Looks like I will not be participating in Amazon Prime's big deal tomorrow
Cheers
Jeremy Anderson likes this.
kpdowd is offline
post #447 of 460 Old 07-15-2015, 02:15 PM
Quoted: 354 Post(s)
Liked: 661
Cheers
Glad it worked out for you! Got rid of the purple line on mine that way too. Still have some discoloration on the image, but apparently that will take me opening up the LCD prism and cleaning the panels, and that seems like a pretty frightening proposition.
post #448 of 460 Old 07-20-2015, 03:01 PM
DGeorge's Avatar
Any recommended sellers for bulbs? My PJ with 300 hours on the original bulb (sat in the basement unused since 2012) has gone dim.
Thanks for any recommendations.
DGeorge is offline
post #449 of 460 Old 07-20-2015, 05:27 PM
Quoted: 354 Post(s)
Liked: 661
Look up Pureland Supply. I've bought all my bulbs from them and have gotten great life out of them.
post #450 of 460 Old 07-21-2015, 06:44 AM
DGeorge's Avatar
Jeremy,
Thanks for the tip.
I know I've seen them in my search results. I'll check them out.
DGeorge is offline
Epson Powerlite Home Cinema 8500 Ub Lcd Projector V11h337020 , Mitsubishi Hd1000u , Panasonic Pt Ae4000u 1600 Lumen Lcd Home Theater Projector
