Holliday Projector Recommendations - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 11-07-2009, 12:41 AM - Thread Starter
Goatz18's Avatar
I am very interrested in the purchase of a sweet HD projector this holiday and am in need of recommendations please. It will go in my basement that has few windows and little light even on a sunny day so it doesn't have to be the brightest projector, just a quality picture. I have ample room to mount the projector from anywhere on the ceiling and the wall has ample room for any size screen, but not too big just as a preference, quality over quantity. The projector would be used for TV, Console Gaming, and Movies (DVD and Bluray). I don't have a preference to 1080p or 720p either, as long as it looks good.
And my budget is $1500. I am hoping Black Friday will bring about some good deals on projectors too so feel free to include any decent ones close to my budget as well. Any info would be much appreciated.
I currently have a 32" Sharp Aquos LC32GP1U and it does the job, I have the settings perfect. But in the big basement 32" just doesn't cut it and since its so dark down there I figure a projector would be better upgrade than a big screen HDTV. Thanks.
Goatz18 is offline
post #2 of 4 Old 11-07-2009, 01:01 AM
hlkc's Avatar
Can you try to swing additional $500? If so, Panny 4K is the best buy IMO. If not, try to pick up a 3K and it is VERY good for the money!
hlkc is offline
post #3 of 4 Old 11-07-2009, 12:25 PM - Thread Starter
Goatz18's Avatar
Yeah after I posted this I found a similar post and the Panasonic AE4000 was mentioned as one of the better buys. Thanks.
Goatz18 is offline
post #4 of 4 Old 11-07-2009, 12:36 PM
hlkc's Avatar
$500 above your budget, if you can swing that, it will be one of the best decision you make this year!
hlkc is offline
