New Lamp for Sony Projector !! HELP !!! - AVS Forum | Home Theater Discussions And Reviews
post #1 of 5 Old 11-23-2009, 07:49 PM - Thread Starter
tannoy5's Avatar
I just got a replacement lamp for my Sony Hs 20 projector. Put it in and it looks like crap.
The light is uneven and color balance is all off.
Plus there is a stinky smell coming from the lamp.
Is this normal ?
I got it from Pureland supply.
I asked them If it was am original replacement made by sony and they said that Sony does not make the lamps them selves.
So they told me that this lamp was a good as the original.
I dont think so !
So where do I go to get a good original Sony replacement lamp ?
tannoy5 is offline
post #2 of 5 Old 11-24-2009, 10:32 AM
Fade2Black's Avatar
Funny you should post this.
FedEx just dropped off my bulb from Mack Warranty via Pureland supply for my Sony VPL-VW40.
It is a generic. Product code: PL9784 (alternative to LMP-H200). There is even a Pureland sticker on the housing.
I can't say whether Sony is still making bulbs for mine, but they are listed on the Sony site for purchase.
Fade2Black is offline
post #3 of 5 Old 11-24-2009, 10:57 AM
airscapes's Avatar
Quoted: 350 Post(s)
Liked: 284
Think this one would be of the official SONY type..
http://www.provantage.com/sony-lmph200~7SONP051.htm
Doug
Planar PD8150 with DC4 DMD paired with a Dalite HP 2.8 110"
http://www.airscapesart.com
airscapes is offline
post #4 of 5 Old 11-24-2009, 07:59 PM
reconlabtech's Avatar
Pureland has a HORRIBLE rep as far as can be found on the forums. PM mackcamera and find out why Mack is dealing with a scam company like them. If this is the path Mack has decided to take, it's time to stop recommending a Mack warranty and tell everyone to steer clear of them.
// Front Projection Enthusiast //
BenQ W1070 - 103" EasyFlex Painted Screen
Onkyo TX-NR646 - JBL Northridge 5.1 - SVS PB-1000
Roku 3 - Amazon FireTv - Sony BDPS5500 - Kangaroo PC
reconlabtech is offline
post #5 of 5 Old 11-24-2009, 10:44 PM
rbs-LG's Avatar
Hey tonnoy5, check out this lamp Sony VPL-HS20 Replacement Bulb. I have got mine from them, they are offering money back guarantee on thier item, worth looking. They told me it would be as good as original and it was.
rbs-LG is offline
