Rebuilding blue polarizers - can it be done? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 40 Old 11-27-2009, 01:02 PM - Thread Starter
Billw12345's Avatar
In reading through the vast knowledge base of the forum, I've come to the conclusion that blue polarizer burning is one of the most common failures (other that lamps) for projectors.
For my Proxima DP6800 (a.k.a. Hitachi CP-X950), I've become the victim of the yellow spot condition.
I've spent several weeks trying in vein to find a replacement filter, but no joy. The best I can find from Hitachi (forget Proxima) is that they only sell the complete optics engine for $450.00. Not quite palatable for an XGA projector.
I've also read about someone in the UK adapting filter from another basket case projector with acceptable results, but this was only one instance of this repair. As for my specific projector (which is probably similar to others), the blue polarizer is loosely placed between the the light channel, the LCD panel, and the optics mixing prism.
I also know that lateral position of a polarizer is not critical, but rotational position is. However, being new to LCD projectors and its optics path, there must be a mating polarizer somewhere in else to mate with the burnt one.
My question is, as the UK repair had shown, is it possible for any blue polarizer (size permitting) to be used as a replacement (assuming that there is some de facto standard for 3-LCD optics?
Also, is the blue polarizer film itself available from other sources, or generic blue polarizer filters available from optics suppliers?
Billw12345 is offline
post #2 of 40 Old 11-27-2009, 08:52 PM
jsmith967's Avatar
I should like to know the answer to this question also. But more fundamentally, how did you know that polarizers must be mounted in the correct rotation position, but not laterially? I just recently opened up a projector of mine to clean the panels, only to have to re-converge the panels. However, now my uniformity is way off, do you think that this could be my polarizer orientation? Thanks, keep us posted.
J
jsmith967 is offline
post #3 of 40 Old 11-27-2009, 09:02 PM
K-Spaz's Avatar
That's how polarizers work, they pass light differently depending upon the azimuth, (rotational orientation).
Consider a "Circular Polarizer" for a camera lens, you rotate it to give the desired effect.
K-Spaz is offline
post #4 of 40 Old 04-19-2013, 06:32 PM
peteleoni's Avatar
One will notice that questions of this nature never get answered properly. Its almost as if this knowledge was being kept purposefully sacrosanct.
"I'm a dead hood who could sing a bit and liked to flaunt my Lamborghini at guys who drive Ferraris
..Frank Sinatra
peteleoni is offline
post #5 of 40 Old 04-19-2013, 08:34 PM
peteleoni's Avatar
In other words this forum is full of people who have the ability do do things themselves without resorting to "This is a complicated operation and shouldn't be attempted by yadayadayada. I sometimes think that some information is not shared or tacitly discouraged from being shared, if not overtly than by association with servicemen etc. I have noted that parts are hard to come by and dealers won't sell "you must be an authorized blah blah" Please forgive me but I find this sort of protectionism a bit offensive. I admit to frequenting forums such as this because I often find that there are many people such as I who willingly share "inside" tips. I have found that my sharing leads not to a loss of business but to an increase in good will and therefore it is conducive..I think this inability to find polarizing filters for older projectors fall squarely in this realm.
..Frank Sinatra
post #6 of 40 Old 04-20-2013, 12:49 AM
LavaASU's Avatar
I'll try to get time to try this next week. In theory it would work, though the color might not be quite as good due to having non-matching components. The rotation is critical as was stated above. Thats why it has to be adjusted.
LavaASU is offline
post #7 of 40 Old 04-20-2013, 11:22 AM
Tinman's Avatar
Liked: 33
Yes, you can use ANY good quality polarizer as long as it fits and you rotate it for optimal result. I did this a long time ago on an old Sony LCD projector with a bad blue polarizer.
As is typical, that part is never available. Would be too easy, right?
Well, this was a dumpster find anyway, so I took a plastic polarizer from a calculator and cut it to size and stuffed it in there. With the projector on, I rotated the polarizer until I got the best "black".
Taped the damn thing in place and used the projector for quite a while before I upgraded to a CRT.
It worked just fine. Using a glass polarizer would be better, but any GOOD polarizer will indeed work just fine. The polarizer doesn't make the color. The Dichroic mirrors in the light path do.
It's not rocket science at all. The manufacturers just like to make it difficult, so we just buy a new product.
Welcome to the darkside.....
Tinman is offline
post #8 of 40 Old 04-20-2013, 12:27 PM
LavaASU's Avatar
I'm not sure what the difference is, but the different color polarizers are different. If you look at the three from a projector the color of them is slightly different. Shrug. I might also try swapping two of the colors to see what impact that has on the image.
LavaASU is offline
post #9 of 40 Old 04-20-2013, 01:41 PM
peteleoni's Avatar
Wow! You guys are great! This is the first straight answer I have gotten on this here! Thanks please share more if possible!
..Frank Sinatra
post #10 of 40 Old 04-20-2013, 04:00 PM
Bohanna's Avatar
Liked: 24
The dicronic lens and mirrors are part of the color separation process but there ARE different colored Polarizers. The one I'm guessing you are looking for is the yellow colored one that blocks the most UV light. Its generally the one that cooks followed by the LCD Panel itself. if you can get one that blocks the path of the light before the panel it doesn't really matter what shape it is .. You will need one made of glass since the plastic ones will cook. You can fool around with one from a cheap pair of UV blocking (sunblockers type) sunglasses that you pick up for cheap at a dollar type store. The ones that the projector makers use are generally fitted to the projectors light path. but if you can get one off another projector as long as you get it to block the light between the light path and the actual panel you should be good to go. If you can get one made out of Glass and can cut it down without cracking it. Make sure to put the coated part of the glass polarize facing the LCD panel.
Good Luck
Bohanna
BTW If you are just using the projector for data you can swap out a panel and polarozer from a matching projector that has the same style panels and polarizers in it but you will not get accurate colors like you would with factory panels. For example If you take two matching projectors that have burnt out blue panels which is common you can replace the Blue ones with green or red panels and polarizers and you will get a decent picture. its best to start with the green panel. I'm pretty sure since you have the yellow spot already you will also have replace the LCD panel.
ALSO NEVER take the panels off the optical block if you don't have to or you will have a alignment nightmare. Just take out the burnt out one and alighn it to the factory set panels
Bohanna is offline
post #11 of 40 Old 04-20-2013, 04:21 PM
peteleoni's Avatar
What I have are some truly workhorse NEC Vt units running 24-7 using a custom I have driver written in powers trip to give me 576 x 1024 picture is sharp and remarkable for blu rays other than an even slow skew toward yellow green over about a year. Of course this will be the blue pol. If I could fix this I would be overjoyed with these units
..Frank Sinatra
post #12 of 40 Old 04-21-2013, 09:23 AM
Tinman's Avatar
Liked: 33
I won't argue that the polarizers in projectors are different and "tuned" for each color to achieve the optimum levels for each. The point was that any polarizer WILL work, for the sake of experimentation.
I got surprisingly good results from my own tinkering, but the color balance, in particular BLACK, was a bit off. Not a lot, though, and it made the projector perfectly watchable again if you don't go probing
with a color analyzer.
So if you have a doorstop, you really have nothing to loose by trying.
Tinman is offline
post #13 of 40 Old 04-21-2013, 10:19 PM
peteleoni's Avatar
Amazing. I have just put all of this to test. So basically 1000s of projectors have been thown away completely wasted for no good reason at all. I wonder if we could find a source of bulk material and put this nasty little bit of secrecy to bed once and for all. I find this sort of thing offensive and wasteful.
..Frank Sinatra
post #14 of 40 Old 04-21-2013, 10:28 PM
peteleoni's Avatar
And here are all the clues needed to find and perfect this from the perfectly acceptable but bakable blue block sunglass lens I tried via advice.......http://www.lhup.edu/~dsimanek/14/polaroid.htm
..Frank Sinatra
post #15 of 40 Old 04-21-2013, 10:34 PM
peteleoni's Avatar
So really all the yellow tint for is optimization. Any of them would probably work well albeit with reduced efficiency require calibration of three colors? Ie...less lumens or black level but good color still?
..Frank Sinatra
post #16 of 40 Old 04-21-2013, 10:43 PM
peteleoni's Avatar
So basically cut to size, this is the multi hundred dollar repair
http://shop.mobileweb.ebay.com/searchresults?cmd=SREF&catid=&kw=New+Polarized+Glare+Block+Sunglasses+UV400+New+Polarized+Glare+Block+Sunglasses+UV400
Disgusting.
..Frank Sinatra
post #17 of 40 Old 04-21-2013, 11:05 PM
peteleoni's Avatar
Obviously plastic, as noted by others here will melt. Therefore a source for yellow tint polarized glass filters that can simply by anyone other than a gorrilla, be cut to size. Hundreds of projectors saved, a few less than forthcoming techs drive Kia's instead of Mercedes?
..Frank Sinatra
post #18 of 40 Old 04-22-2013, 08:05 AM
peteleoni's Avatar
Here is another responce from NEC
Unfortunately, internal parts are not available to end-users. Only authorized
NEC servicers have access to these parts. Because of this we can not sell any
internal parts to you. Sorry for any inconvenience this may cause.
Thank you,
Keslie.
Total
BS
..Frank Sinatra
post #19 of 40 Old 04-22-2013, 08:56 AM
peteleoni's Avatar
The sad thing is I have some freinds who are missionaries in Haiti and I can fix all of their machines in the schools but Kelsie at NEC wont sell us parts. Some times you don't want anything but to pay for a part.
..Frank Sinatra
post #20 of 40 Old 04-22-2013, 09:30 AM
peteleoni's Avatar
There has got to be a source.
..Frank Sinatra
post #21 of 40 Old 04-22-2013, 09:27 PM
Bohanna's Avatar
Liked: 24
Been tied up that last couple of days. Fading fast!! The blue LCD screen and polariser are the weak link in the LCD technology. the Color wheel and the DLP chips are the weak links in DLP technology. choose your poison. Like said you can salvage projectors by using other panels even though the colors will be a bit off. But for schoolchildren in under developed countries it could be a perfect solution if they have a zero budget,
Bohanna
Bohanna is offline
post #22 of 40 Old 04-22-2013, 10:10 PM
peteleoni's Avatar
Well if that's the best we can do its the best. Really do appreciate your help.
..Frank Sinatra
post #23 of 40 Old 08-16-2013, 10:04 PM
mikebrouss's Avatar
yep
it can be done. did it for about $50.
there's a place in texas that sells a high heat plastic polarizer sheet.
http://www.polarization.com/polarshop/product_info.php?cPath=21&products_id=46
i was going to bond it to a quartz microscope slide or coverslip, but so far i just mounted the plastic.
http://www.tedpella.com/histo_html/quartz-micro-slides.htm
mikebrouss is offline
post #24 of 40 Old 02-15-2015, 09:25 PM
Liked: 0
Ok guys I found a cheap trick for a blue polarizer. I took my mitsubishi projection tv apart to clean it. While apart I broke the blue polarizing filter. It left the whole screen with a blue tint. I read that the 3d glasses you get at the movies are polarized. You can look up the effects of the glasses on a computer, tv(projection, lcd, dlp etc), or I used my iPad. As you turn the glasses it changes the colors wave lengths as they go through. I took a pair of the glasses. I cut out a square. Before I did this I laid it on my iPad and turned it until it went black and marked my bottom. Next you just have to figure put which way you have to turn it so that it filters out the blue color. It took me a couple tries. I had it facing the wrong way the first time. I turned it one way so that my screen looked blue then a yellowish color. The yellowish way worked for my blue. It took all the blueish tint from my tv and works like new. Hope this helps. I can't post pictures on here as I am new to the forum. Mine didn't get a lot of heat so I dunno how it does with a lot of heat. My tv actually has two polarized filters. I thought I'd pass along what worked for me. It's working perfect as of right now.
FASTEDDY46 is offline
post #25 of 40 Old 03-26-2015, 03:06 AM
Liked: 2
I cannot believe this thread came back to life today, during my first attempt at fixing a projector. I got one for free, just tore apart and it is the blue polarizing filter. Since this thread started 6 years ago, is there a good source for cheaply fixing these?
D Dauberz is offline
post #26 of 40 Old 03-26-2015, 04:52 AM
Liked: 2
This seems like a great solution aside from the heat melting it. Mine is a projector so it gets very hot.
post #27 of 40 Old 03-29-2015, 06:49 PM
karras's Avatar
Wow! I haven't logged in in a while and today my guess what...blue polarizer just burnt on my Hitachi 60V710.
I was wondering if anyone tried the link suggested by Mikebrouss:
http://www.polarization.com/polarsho...products_id=46
Also I don't quite understand the description "This dye-type (but neutral gray) polarizer..." how does it replace a blue polarizer.
What about getting another blue one from another projector off eBay that fits into the small metal holder?
They sell so many rebuilt/refurbished light engines when I google this so someone is fixing them or getting parts but I am not willing to dish out $350 to replace the whole thing just because of one polarizer.
Any help or advice would be appreciated.
Make improvements upon something good with an attempt at perfection.
karras is offline
post #28 of 40 Old 03-30-2015, 10:09 AM
karras's Avatar
Anyone at all know where to even purchase one? I've googled till I'm blue in the face
I've contacted many parts distributors...also eBay of course where I did find and buy a used red and green but was pure luck and the guy already sold the blue. I'm down to looking at entire used broken sets for sale to scavenge for parts but closest I came is a 60V500A but does not seem to use the same engine/polarizers.
Does anyone have any information. Do we really throw all these out to the garbage for a small polarizer!?
Have a great day anyone!
karras is offline
post #29 of 40 Old 03-30-2015, 11:58 AM
karras's Avatar
Small follow up:
I contacted Encompass and explained I am a technician looking for a part (which is true) through their website where they have a form to fill out and they can research parts only to get a standard response which is kind of ridiculous and I wonder why they have a form for requesting in the first place:
"Thank you for your inquiry. Unfortunately, due to safety concerns, this part is only available to professional repair centers and not the general public. Please contact your local repair technician for assistance. We apologize for any inconvenience."
I especially like the part "...due to safety concerns..." lol But left like a dog chasing his own tail as I am the local repair technician that I want to contact... ;-)
karras is offline
post #30 of 40 Old 03-31-2015, 05:51 AM
Liked: 2
Originally Posted by karras View Post
Small follow up:
I am in the same boat! I refuse to believe I cannot find something to work. I have a friend that is a top level chemist that is looking into some of his suppliers to see about a glass polarizer that would work. I will keep you posted.
