Do passive HDMI extenders work? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 8 Old 12-11-2009, 06:06 PM - Thread Starter
twstand's Avatar
Has anyone tried the passive HDMI extenders like this one?
I can get a signal passed through my current 35ft HDMI cable but would like to extend it with an additional 10ft cable and wondered if this will do the trick.
twstand is offline
post #2 of 8 Old 12-11-2009, 06:15 PM
Jerrym303's Avatar
They can help, you just have to try it. You want it near the pj end.
Jerrym303 is offline
post #3 of 8 Old 12-11-2009, 07:30 PM - Thread Starter
twstand's Avatar
Thanks Jeremy. Hopefully this is the last run to the parts store before my big cable run underneath a floor with dirt beneath me. Yuck.
twstand is offline
post #4 of 8 Old 12-11-2009, 08:36 PM
lewke's Avatar
Quoted: 41 Post(s)
Liked: 25
I did the same exact thing for my setup, just my 35 footer went up and over in the walls. I used an coupler for the last 10 feet to my projector, I purchased monoprice but I recall them having much cheaper ones......
This one worked for me.....
Are you running anything else, I ran component as backup, as you won't get the chance again.........
lewke is offline
post #5 of 8 Old 12-11-2009, 11:37 PM - Thread Starter
twstand's Avatar
I'm doing all my testing of cables beforehand. If something goes wrong once installed, I can still run a long component cable I have "above ground" for trouble-shooting.
The prices at monoprice are unbelievable.
twstand is offline
post #6 of 8 Old 08-09-2012, 08:43 AM
Brian Hampton's Avatar
Quoted: 583 Post(s)
Liked: 311
Monoprice put one of these into an order by mistake and when I alerted them they didn't want it back.
I can't imagine how these would work.
-brian
Brian Hampton is online now
post #7 of 8 Old 08-09-2012, 10:26 AM
speavler's Avatar
Quoted: 12 Post(s)
Liked: 26
i bought one of those a while back. Did not work for me. sitting in a box along with one of their hdmi matrix
speavler is offline
post #8 of 8 Old 08-09-2012, 02:32 PM
BobL's Avatar
Liked: 58
Whenever you have a passive device, it is robbing peter to pay paul. Usually, these passive devices just change capacitance but if it is a circuit then it is powering it off the 5V line and could drop the voltage too low. It is a crap shoot whether it will work or not.
You are always better with one long cable then adding multiple connections. If your cable will be difficult to change I would future proof and run conduit if possible, or at least a solution that can handle full HDMI bandwidth (i.e. high speed). That way you won't have a problem when you upgrade your equipment down the road. If the cable is easy to change then try cheap first and if it doesn't work use a better solution.
BobL is offline
